Durability/Resistance of HDMI Socket - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-18-2009, 11:46 AM - Thread Starter
Megalith's Avatar
Quoted: 86 Post(s)
Out of curiosity, how much force can an HDMI socket take? If one were insane enough to put significant upwards or downwards pressure on an HDMI cable that was plugged in, which would be more likely to break: something within the socket, or something on the cable (the male connector)?
I have a habit of wiggling the HDMI connector a lot on my equipment because of dropouts (which, I found last night, can be blamed on my AVR). Unfortunately, OCD kicked in when I was fiddling around with the HDMI connection on my BDP-83, and I probably put more pressure on the socket than I should have---all seems fine as I still get a signal, but my paranoia simply won't budge...
Are most sockets designed like this:
If so, it seems that if an HDMI socket suffered damage, it'd be the actually socket coming loose from the PCB, right?
Megalith is offline
post #2 of 9 Old 09-18-2009, 12:38 PM
t@bes's Avatar
It's hard to say how much stress (since there's so many variances on HDMI Connectors used), but HDMI Inputs are known to be somewhat fragile. Although many people never have issues, many people have had problems with damaging the HDMI Input (as well as HDMI Cables)...it's a well documented issue. I will say that on some components it doesn't take much to damage the HDMI Input.
It seems the biggest problem is the stress placed on the HDMI Input by the HDMI Cable (particularly larger, heavier cables), as well as being bumped around, etc. The traces on the inside of the connector can break, and typically the repair consists of replacing the entire board, as soldering the tiny traces can be difficult. That means expensive repairs if it happens.
There's some solutions available that can eliminate this problem, such as port savers, locking adapters that work with your existing cable, and hdmi cables that screw into the chassis.
There's also some new locking cables out. They help keep the cable from coming loose, but they don't really address the stress.
I'd recommend looking at one of the cables or adapters that remove stress and that take care of your problem.
*edited to add "cables" to last sentence
[email protected] is offline
post #3 of 9 Old 09-19-2009, 09:25 AM
Valence01's Avatar
Yes, that is the typical failure point for surface mounted HDMI connectors. My experience is that even with the 4 little tabs soldered to the PCB, it can still work loose, especially with the less elastic lead-free solder formulations in use today. I've even seen a case where the metal shroud was still firmly attached to the PCB, yet the surface mount pins were detached from the PCB. In that case, putting pressure on the cable in the upward direction would force the pins into contact with the pads on the PCB and it would work, but then relaxing the pressure, one or more contacts would become disconnected. The connector shown in your picture with the screw tab might seem to be the ticket, but that just raises a new problem of tolerances between whatever metal bracketry it is screwed to and the PCB mounting points. Imagine that the bracket in some cases is just a little bit too far away from the tab. Now, putting a screw through the bracket and into the tab ends up producing precisely the sort of upward cantilever force on the pins where the connect to the PCB, that this was supposed to avoid. Way to go! If you study various different PCB mount connectors designed for other purposes (VGA, RS232, etc), you'll see a fundamental difference with respect to the typical HDMI connector. That is, the metal bracketry surrounding a VGA or RS232 D-sub type connector, is much more substantial and the plastic innards of the connector extend far outside of the bracketry completing enveloping it. Grab the plastic part and see if you can wiggle it. It's very strongly attached to the metal bracketry and there is very little net force imparted to the pins where they contact the PCB. In sharp contrast, grab an HDMI cable inserted into it's PCB mounted mating connector and wiggle it. You'll see very quickly that the bracketry does very little to keep stresses away from the pin to board solder connections. Usually the plastic part and the pins can be wiggled around quite a lot with little motion from the metal bracket. Connectors with thru-hole style pin connections to the PCB tend fare a good deal better, than the trendy surface mount designs that end up not saving any space anyway.
I don't know if this sort of design is the result of just trying to be cheap, or the crackpot EMI zealots insisting that the connector be fully enveloped by a "shield". Whatever the reason, the bottom line is that until we start seeing connector designs where the metal bracket part is completely embedded within the plastic part of the connector, we'll continue to suffer from poor connector durability.
I might add that most USB connectors suffer from the same design flaws as HDMI connectors, though it tends to be less of a problem in practice, due to the much smaller, lighter cables used with USB, not to mention the much larger pins.
P.J.
Valence01 is offline
post #4 of 9 Old 09-19-2009, 11:16 AM
ChrisWiggles's Avatar
Liked: 26
HDMI connectors are fragile. Very fragile.
ChrisWiggles is offline
post #5 of 9 Old 09-19-2009, 04:00 PM - Thread Starter
Megalith's Avatar
Quoted: 86 Post(s)
That whole PCB bit is very interesting.
My initial worry with putting force on the cable, especially up/downwards force, was that the channel card (I don't remember the proper terminology) inside the socket could actually crack or break off completely. The piece I'm talking about is what's in the middle:
I think the new HDMI 1.4 connector should be better (in terms of possibly providing a tighter connection), but I'll assume that it really will be reserved only for portable devices because the gauge of the wire will have a clear limit.
Megalith is offline
post #6 of 9 Old 10-15-2009, 05:57 PM
lawman85's Avatar
I have a Pioneer Elite with a bad output HDMI and out of warranty ? any ideas ???
lawman85 is offline
post #7 of 9 Old 10-16-2009, 07:18 AM
scorrpio's Avatar
If a connection problem can be corrected by 'wiggling', it means your connection is already loosened up and inadequate. - that is, most likely, the socket shroud is deformed. Further wiggling will only make the problem worse. Ideally, the HDMI connection should be engaged once and left alone. If it looks like the connection will be stressed, it might be a good idea it find a way to fixate the cable so that stress is minimized. If a cable needs to make a sharp turn (i.e. equipment almost up to the wall), consider getting some 90 or 270-degree adapters.
scorrpio is offline
post #8 of 9 Old 10-17-2009, 11:00 AM
Rebound's Avatar
I think that super-fat HDMI cables were never intended by the origional designers. Their connector becomes a lever which can pry the hdmi connector off of the pcb.
Rebound is offline
post #9 of 9 Old 10-21-2009, 08:04 AM
vogon13's Avatar
I have seen a couple of nonworking HDMI receptacles with a 'pin' bent upwards and mashed into the back of the connector. I suspect customers insert the cable at an angle, and the 'pin' does not slide onto the mating surface and instead snags the end and then gets mashed when the connector is fully inserted.
Probably a coincidence, but both the ones I have seen were on Dish HDDVRs.
I have a Sony HD camcorder and I admit to being extremely cautious when using the HDMI output. I can imagine that would be a very expensive repair.
vogon13 is offline
Reply HDMI Q&A - The One Connector World
