AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   HDMI Q&A - The One Connector World (https://www.avsforum.com/forum/168-hdmi-q-one-connector-world/)
-   -   Where to find cable / transfers to DisplayPort 1.2 (https://www.avsforum.com/forum/168-hdmi-q-one-connector-world/1525475-where-find-cable-transfers-displayport-1-2-a.html)
WhyJoin 04-02-2014 06:02 AM
Where to find cable / transfers to DisplayPort 1.2   device transmits the 17.28 Gbit / s in High Bit Rate 2
Colm 04-02-2014 12:00 PM
Wanna say that in English?
WhyJoin 04-03-2014 04:05 AM
Where to find cable DisplayPort 1.2 ( 17.28 Gbit / s in High Bit Rate 2 )
Now you know where to Find  a cable with a  full standard for video card amd 290
Joe Fernand 04-03-2014 09:24 AM
Make it simpler for folk to try and help you out!
List the devices you are hoping to connect – Make, Model and Part number (no abbreviations).
Ideally provide a link to the Products online User Manual.
Joe
AV_Integrated 04-03-2014 12:01 PM
I'm completely at a loss on this. DisplayPort to HDMI adapters haven't changed to my knowledge, and there is only one type of connection. The AMD 290 video chipset cards which have DisplayPort use the same DisplayPort which everything else uses, which means that this adapter, or any similar adapter will work fine to my knowledge:
http://www.amazon.com/Startech-DP2HDMI-DisplayPort-Adapter-Converter/dp/B0017K6BDW
Is there some question that goes beyond this?
WhyJoin 04-03-2014 12:24 PM
Why  anyone  read?
"Supports PC resolutions up to 1920x1200 and HDTV resolutions up to 1080p "
i ask for :
So sellers do not want to sell? Or you do not know something?
If there is no difference between the cable
Why has a standard 1.0 or 1.1 or 1.2?
For beauty?
WhyJoin 04-03-2014 12:56 PM
For beauty?
Read the link you brought
  • "Supports PC resolutions up to 1920x1200 and HDTV resolutions up to 1080p"
  • Where a registered supports - DisplayPort 1.2 ( 17.28 Gbit / s in High Bit Rate 2 )  ???
WhyJoin 04-03-2014 01:02 PM
  • " Supports PC resolutions up to 1920x1200 and HDTV resolutions up to 1080p"
Read  from your link
Where a registered supports -DisplayPort 1.2 ( 17.28 Gbit / s in High Bit Rate 2 )  ?
Why issued three standards?  DisplayPort 1.0  /1.1 / 1.2
For beauty?
Or maybe the sellers do not want to sell?
Joe Fernand 04-03-2014 01:45 PM
Again simply list what you are trying to connect – folk will then have an idea what you are trying to achieve.
‘Or maybe the sellers do not want to sell?’
– probably very true, the reality is that DisplayPort is pretty much irrelevant in the Consumer World.
The DisplayPort.org website is a joke.
Joe
AV_Integrated 04-03-2014 10:50 PM
While it is clear English is not your native language, it would be helpful if you understood that DisplayPort++ is what is required for DisplayPort to connect to HDMI devices. The conversion from DisplayPort to HDMI is not a direct connection. It should also be noted that HDMI only supports up to the current limitations of the technology and DisplayPort is not directly cross compatible with all the features which HDMI offers. Most, yes, but not all.
DisplayPort is NOT HDMI, so asking a 'converter' to magically make it so, is not going to get you something. As well, since there are basically no HDMI 2.0 devices on the market, all discussion of DisplayPort would revolve, at most, around HDMI 1.4. From what I've read, most DisplayPort++ to HDMI adapters support the bit rate which HDMI 1.4 supports, but the exclusive HDMI 1.4 features can't be supported.
So, what it is that you are trying to achieve? What are you trying to connect? Why don't you just use the HDMI port on the computer to do what you want? Do you understand that DisplayPort is designed to deliver maximum quality to other DisplayPort products exclusively? If you are trying to force DisplayPort to be HDMI, or vice-versa, you need to accept that it is like shoving the keys for a Honda into the ignition of a Toyota... As much as you may WANT this to happen, it simply isn't designed to work that way.
AV_Integrated 04-03-2014 10:53 PM
Originally Posted by WhyJoin View Post
Why  anyone  read?
HDMI 1.4 does not support speeds of 17.28 Gbit - that's a DisplayPort speed.
i ask for :
Then buy DisplayPort devices that are DisplayPort 1.2 and don't look for HDMI adapters.
You still are being extremely unclear about what you are trying to achieve and what you are trying to connect.
WhyJoin 04-04-2014 12:31 AM
Who wrote HDMI 1.4? I have HDMI 2.0
You're making things ?
Then buy DisplayPort devices that are DisplayPort 1.2 and don't look forThen buy DisplayPort devices that are DisplayPort 1.2 and don't look for HDMI adapters..
Even adapters HDMI 2.0/ DisplayPort 1.2
Should meet the standards
And you do not get it
Joe Fernand 04-04-2014 02:28 AM
‘And you do not get it’ – yup, definitely the best tactic when seeking help is to be rude to folk who are trying to help you!
There are numerous Threads above and below this one discussing the mess that is HDMI 2.0 and its release and how bandying HDMI Version numbers around means nothing.
WhyJoin indeed!
Joe
WhyJoin 04-04-2014 06:55 AM
Write nonsense and again write nonsense, tired
Does not help anything and you're just yelling and not helping anything
  • Joe Fernand You have many names and you disturbing, try to help others
AV_Integrated 04-04-2014 01:53 PM
For the tenth F#KING TIME...
WHAT ARE YOU TRYING TO CONNECT?
Do you have the ability to answer that basic question or are you going to continue to not provide any information whatsoever about what you are attempting to achieve?
HDMI 2.0 is brand new to the market and DisplayPort++ connections are not necessarily designed to support the higher bandwidth of HDMI 2.0. This is, flat out, a mismatch between the DP format and the HDMI format and with the lack of HDMI 2.0 chipsets currently on the market, I would not expect a higher speed rated product for six to twelve months.
I hear that you can buy DisplayPort products right now - you should check them out.
Colm 04-04-2014 04:28 PM
This might answer some of your questions.
AVS153 04-10-2014 01:41 PM
DisplayPort 1.2   Supports up to 4K Ultra HD and 2560x1600 @60Hz  but on 300MHZ
Adapter to hdmi 2.0 Still working on  300mhz
hdmi 2.0 Requires  600mhz
So how to bring 4K 60 HZ  to hdmi 2.0 4K 60 HZ  from DisplayPort 1.2  ?
They all hdmi 1.4
http://www.ebay.com/itm/Standard-DisplayPort-DP-1-2-to-HDMI-1-4-Adapter-with-Audio-support-3D-Black-/261413508467?pt=US_Video_Cables_Adapters&hash=item3cdd759573
Support HDMI 10Gbps not 17.28 Gbit
http://www.ebay.com/sch/i.html?_trksid=p2047675.m570.l1313.TR0.TRC0.H0&_nkw=DisplayPort+1.2+&_sacat=0&_from=R40
Look at all that transmit up to 10.8Gbps at best
Otto Pylot 04-10-2014 02:39 PM
I doubt seriously that you have HDMI 2.0 because I don't think the chipsets capable of 18Gbps (HDMI 2.0's maximum bandwidth) are available yet in most, if any, consumer devices presently.
AVS153 04-11-2014 06:20 AM
This is a bad answer
What is the link to my question?
If you do not know the answer don't answer
AV_Integrated 04-11-2014 09:23 AM
Are you WHYJOIN or are you AVS153?
Why is it you can't answer questions, or won't answer questions?
What equipment are you using?
You've been asked by multiple people, many times, to list what equipment you are using so you can get the best possible answer. So, why not tell everyone: WHAT EQUIPMENT ARE YOU USING?
It may not be possible under DP 1.2 to go to HDMI 2.0. because HDMI 2.0 actually has higher bandwidth capability than DP 1.2 supports.
Or, do you want to go from HDMI 2.0 to DP 1.2? This may not be possible because DP 1.2 doesn't support a conversion from HDMI in that manner easily, and certainly not in the HDMI 2.0 format.
HDMI 2.0 has just started on the market. I think that you will need to wait until there are actually chip sets out there before there will be adapters in place.
But, it sure would be nice if you could let us know what equipment you are using.
AVS153 04-11-2014 10:58 AM
What does it matter to you ?  Owe you nothing
Finally you really understand that you have no idea
I wrote explicitly :
AV_Integrated   Do not know do not answer
my equipment None of your business, clear enough .
Joe Fernand 04-11-2014 11:27 AM
my equipment None of your business, your aggression unhelpful and very unlikely to elicit any help from Forum members, clear enough .
Joe
Otto Pylot 04-11-2014 11:54 AM
They/he are trolls without a clear understanding of what they want to accomplish or are attempting something that is not quite "kosher". Either way, we should just ignore him/them and possibly have the mods take care of it. We've wasted too much time and space as it is.
Colm 04-11-2014 03:02 PM
This thread reminds me of the old science fiction move Plan Nine from Outer Space. "You see? You see? Your stupid minds! Stupid! Stupid!"
Otto Pylot 04-11-2014 05:44 PM
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
