20276 - Printed on the cable - What does it indicate ? ? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Otto Pylot
post #1 of 12 Old 12-06-2014, 06:16 PM - Thread Starter
See The Light's Avatar
Quoted: 124 Post(s)
Liked: 196
Question 20276 - Printed on the cable - What does it indicate ? ?
So, I have several HDMI cables attached to my Home Theater set-up, for ROKU, BD Player, and a Laptop.
All of the cables have printed on them "20276".
I just wanted to have someone officially state what the "20276" indicates on an HDMI cable.
Cable Channel Choice is the only choice I want to make !!
See The Light is offline
post #2 of 12 Old 12-06-2014, 07:28 PM
olyteddy's Avatar
Quoted: 537 Post(s)
Liked: 945
Got Google? 'ul20276' http://wireandcablemalaysia.blogspot...ification.html
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 12 Old 12-06-2014, 10:38 PM
Otto Pylot's Avatar
Quoted: 3976 Post(s)
Liked: 2859
Just a mfr label.
Otto Pylot is offline
post #4 of 12 Old 12-10-2014, 12:09 AM - Thread Starter
Quoted: 124 Post(s)
Liked: 196
Originally Posted by olyteddy View Post
Yes, thanks.... I see now that 20276 is the UL listed "style" of cable.
I must have had a "google block" that day.
http://data.ul.com/link/stylepage.aspx?style=20276
post #5 of 12 Old 07-18-2015, 03:33 PM
PaulG's Avatar
Quoted: 102 Post(s)
Gonna bump this thread up because I have the same markings on an HDMI cable I put in a few years back with my Oppo Blue Ray player. Wondering what it is and weather this cable is high speed or not...
Other markings on the jacket include E224782 AWM STYLE 20276 80c 30V VW-1 Digital Video & Audio Cable
I can't find any record of the purchase (I think it was through Ram Electronics) and I wonder if the cable is high speed or not... will be putting in a new PJ in a couple of months...not 4k but 1080p for sure.
Its roughly a 35-40 foot run.
I'm happy enough to buy a new cable, even long runs aren't that expensive. Plus, there are some old legacy cables running to my PJ that will need to go when I install the new one, so I'll be in the ceiling and walls anyway...just hoping to find out if its NECESSARY to switch to a new HDMI cable as well or not.
PaulG is offline
post #6 of 12 Old 07-18-2015, 06:57 PM
Otto Pylot's Avatar
Liked: 2859
Canned answer is this: any certified high speed hdmi cable will work. The caveat is this: if your runs are over 25' (which is the currently the certified length for passive hdmi cables) then you may want to consider a passive cable with a thicker gauge of cable or go with an active cable with Redmere technology.
If you are going to be creating new cable runs (in-wall) then I strongly recommend using a conduit. Cable specs will be changing over time so installing cable in a conduit will make it so much easier to install new cables when required. If you do that, I would recommend installing a solid core CAT-6(x) cable for future connections.
See The Light likes this.
post #7 of 12 Old 07-22-2015, 07:28 PM
Otto Pylot's Avatar
Liked: 2859
You were answered in post 6. The markings are probably some mfr marking that have no bearing on the actual cable spec. Replace your cables with ones that you know what their capacity is. It's better to know for sure than to guess, especially if problems occur.
See post 6 for other considerations.
post #8 of 12 Old 07-23-2015, 06:19 AM
PaulG's Avatar
Quoted: 102 Post(s)
Fair enough - I was answered. You're exactly right...at the reasonable prices of 40 ft. Redmere cables, its worth it to just replace what's there now. When I replace my projector in a couple of months, I'm ging to pull out some legacy cables (component video) that are still connected to my current PJ, so I'll be back in the wall/ceiling anyway. Knowing is always better than guessing. :-)
PaulG is offline
post #9 of 12 Old 07-23-2015, 08:14 AM
Otto Pylot's Avatar
Liked: 2859
As a suggestion, if you're pulling cable in-wall it would be best, if possible, to run conduit. That makes it so much easier to replace/add/repair cabling. If you do install conduit, I would strongly suggest running some solid core CAT-6 cable for future use. That way you have, in place, the option to extend an ethernet connection should you need it and more importantly, you can install some sort of active termination (HDBT) at both ends and push audio/video. People always ask about "future proofing" their cable installations and the best way to achieve that is to install solid core CAT-6 actively terminated. HDBT can be a bit more expensive but for an in-wall installation it's really the only way to go. Redmere is great but they do have a chipset in the sink end (tv side) that draws a bit of power so, like any electronic device, then can fail over time.
post #10 of 12 Old 08-01-2015, 06:08 AM
Joe Fernand's Avatar
Quoted: 656 Post(s)
Liked: 354
Cable Markings - are relevant to the cable stock used in the cable assembly.
HDMI Certification - is applicable to the Cable Assembly (2x Connectors + relevant length of cable stock).
HDMI Certification is rarely marked on the cable jacket.
Active HDMI - is potentially a problem as UHD and HDR hit the market, the 'active' component (Chip) buried in the send or receive connector is unlikely to support UHD BD/HDR.
A couple of solid core, CAT6 (non-CCA) is, as Otto says, a good backup option!
Joe
Octava Inc. Multi-cast HD over LAN solutions.
RuiPro UK and EU Sales and Support
The Media Factory. Residential and Commercial systems.
Joe Fernand is online now
post #11 of 12 Old 05-07-2020, 03:42 PM
Liked: 0
Here ya go
Joe
Name:	Screenshot_20200507-161603_Amazon Kindle_1588891332245.jpg
xVx_K1r1t0_xVX_KillMe is offline
post #12 of 12 Old 05-07-2020, 03:50 PM
Otto Pylot's Avatar
Liked: 2859
Originally Posted by xVx_K1r1t0_xVX_KillMe View Post
Here ya go
You just replied to an almost 5 year old thread Things have changed a bit since then.
I never trust an atom, they make up everything.
Reply HDMI Q&A - The One Connector World
20276 , hdmi
