AudioQuest HDMI's - Worth It? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 41Likes
post #91 of 95 Old 11-18-2019, 02:23 PM
audioheaven's Avatar
Quoted: 23 Post(s)
Cables matter.
There are plenty of articles that demonstrate that the quality of digital cables matter. Be it - jitter, current, voltage, .... its not just 1s and 0s. Just as ground plane has a tremendous effect on cable signal. Saying cables don't matter is like saying that the quality of your tires on your car don't matter. Everything matters. Yes the power source matters, but minimizing effects of AC on equipment involved matters. AC is full of noise that can and does have a causal effect on audio and video reproduction.
Again - saying cables don't matter is very short sighted - mainly from those that either can't afford the cables OR are not astute enough to notice the difference because they don't have quality audio gear, or are deaf, hard of hearing, or just flat out refuse to accept that cables - just like everything else - matters.
Higher quality ingredients and higher quality product development and manufacturing - regardless of product space -- will yield higher quality results.
To suggest otherwise is naïve at best.
" Listen and you will see. "
audioheaven is offline
post #92 of 95 Old 11-18-2019, 03:07 PM
Ratman's Avatar
Quoted: 2438 Post(s)
Liked: 2279
This is the rhetoric that reinforces why most say "beware".
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #93 of 95 Old 11-18-2019, 03:13 PM
Quoted: 23 Post(s)
My comment is just one facet of how cables do have an impact on SQ and PQ. There are measureable differences between 'value' cables and those that some would consider excessive or unnecessary. Such measureable areas include ground plane effects, jitter, trace, and voltage fluctuations. To say its all 1s and 0s - and only 1s and 0s with nothing else involved has no concept of EE.
post #94 of 95 Old 11-18-2019, 03:24 PM
Otto Pylot's Avatar
Quoted: 3570 Post(s)
Liked: 2570
There are in fact measureable differences but quite often those differences are outside of the normal human range of auditory and visual acuity so while they "sound" good, they are really meaningless when it comes down to what you see and possibly hear.
Oh, and cables do matter, but only up to a point. A cheap Chinese knock-off is not going to perform the same or better as a cable that is made from a reputable mfr, but cost isn't always an indicator of better performance.
audioheaven likes this.
I never trust an atom, they make up everything.
Otto Pylot is offline
post #95 of 95 Old 11-23-2019, 12:54 PM
Joe Fernand's Avatar
Quoted: 631 Post(s)
Liked: 345
'There are measureable differences between 'value' cables and those that some would consider excessive or unnecessary' - with HDMI both cables are carrying a highly encrypted digital signal which the cable is not capable of decrypting, altering and re-encrypting.
Joe
Octava Inc. Multi-cast HD over LAN solutions.
RuiPro UK and EU Sales and Support
The Media Factory. Residential and Commercial systems.
Joe Fernand is online now
Reply HDMI Q&A - The One Connector World
