No signal with Denon x3000 and Monoprice active hdmi combination - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-25-2019, 02:34 PM - Thread Starter
Liked: 0
Question No signal with Denon x3000 and Monoprice active hdmi combination
Hello all,
I've been struggling with this for some time and decided to ask the question here in case I'm overlooking something obvious:
I have a setup with AVR-X3000 connected to (old) Samsung TV and successfully playing 1080p content. Recently I renovated the basement, had to move my equipment room little further and ended up replacing the old hdmi cable. The original length was 25 or 30ft, and now I have two cables 35ft and 40ft, both the same "Monoprice HOSS Active High Speed HDMI Cable - 4K @ 60Hz, HDR, 18Gbps, 24AWG, YUV 4:4:4" type.
So now I cannot get the signal through. If I connect new roku ultra, second gen apple tv, super old Sony home theater receiver, all work just fine and don't seem to have any reliability issues, as long as I'm in front of the tv I don't remember seeing any interruptions. But I cannot make Denon work, it doesn't display the status screen or anything coming from any source. I only have 1080 sources, no 4k or better...
Is there a hope that I'm missing some setting or trick to make Denon work or there is a problem with the signal strength of this specific model and I'll have to try another receiver?
vavalomi is offline
post #2 of 2 Old 06-25-2019, 03:42 PM
Joe Fernand's Avatar
Quoted: 607 Post(s)
Liked: 335
You could try adding a 5v power injector between the AVR and the active cable - failing that you could try one of our RuiPro4K Hybrid Fibre HDMI cables.
Joe
Octava Inc. Multi-cast HD over LAN solutions.
RuiPro UK and EU Sales and Support
The Media Factory. Residential and Commercial systems.
Joe Fernand is offline
Reply HDMI Q&A - The One Connector World
