Is there any HDMI 2.0/a/b Switch with 18gbps each channel¿?
Hi !! I have a question .... I will raise it here with the hope that someone can help me ...
I have a Benq W2700, it brings 2 HDMI inputs and I need 3 ...... (PC + PS4 Pro + Chromecast). Changing every time I need the HDMI cable manually to put one thing or the other is almost hell .....
For this reason I have considered buying an HDMI Switch as cheap as possible to connect it to one of the projector's inputs and thus have some extra input. Most bring remote control to commute with what the thing would be quite simple and completely solve the problem ....
BUT here comes the doubt .... I need the switch inputs to allow the input of 4K + 60Hz + 12Bit + HDR signals in other words I need almost 18gbps on each input ....
All the switches that I see in Amazon and other stores .... although it says "2.0 /2.0b, 4K, HDR, 12 bits .............." then you see in the description things of the type .... for example in a switch of 3 inputs 1 output puts 18 gbps followed by "6 per channel", or if it is 2, 9 per channel etc ...
I guess the doubt is clear ..... that means that really every input is limited in that width and therefore you don't really have 18gbps? If so, these switches really are not worth any for my needs ....
Anyone know anything about it or have a switch that I can confirm that I can reach the maximum on each HDMI input? (For example 4K + HDR + 12 Bits + 60Hz RGB or 60 4: 2: 0 or 30 4: 4: 4) ....
I hope so ... because otherwise I don't really understand the purpose of these devices ....
Greetings !!
