Choosing an HDMI cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 02-19-2020, 06:11 AM - Thread Starter
rpearlberg's Avatar
Quoted: 74 Post(s)
This might be a dumb question, but what's the best HDMI to use to connect a Samsung Q80R TV to a Samsung Q80 Soundbar?
rpearlberg is offline
post #2 of 17 Old 02-22-2020, 01:10 AM
Joe Fernand's Avatar
Quoted: 649 Post(s)
Liked: 352
If the cables you require are short (2m) pretty much anything you have to hand will do - if you want belts and braces then look for the official certification Logos (High Speed, Premium High Speed and the New/rare Ultra High Speed).
As you increase the cable length out to 8m look for the Premium High speed certification.
If your cable runs are over 8m I would recommend RuiPro4K Hybrid Fibre cables.
https://www.hdmi.org/resource/cables
Joe
Octava Inc. Multi-cast HD over LAN solutions.
RuiPro UK and EU Sales and Support
The Media Factory. Residential and Commercial systems.
Joe Fernand is offline
post #3 of 17 Old 02-22-2020, 11:22 AM
Otto Pylot's Avatar
Quoted: 3877 Post(s)
Liked: 2770
Joe
A big +1.
My general rule of thumb is this:
For 4k HDR runs up to 25', a Premium High Speed HDMI cable (with the QR label for authenticity). Lots to choose from and they aren't expensive.
For 4k HDR runs over 25', a hybrid fiber cable (Ruipro4k). However, they are expensive but work extremely well.
I never trust an atom, they make up everything.
Otto Pylot is offline
post #4 of 17 Old 02-22-2020, 11:24 AM - Thread Starter
rpearlberg's Avatar
Quoted: 74 Post(s)
Thanks. I only need about 3-4 feet max.
Originally Posted by Otto Pylot View Post
A big +1.
post #5 of 17 Old 02-22-2020, 12:53 PM
Otto Pylot's Avatar
Liked: 2770
Easy to do. Just give yourself a little slack at the connector ends to eliminate any strain on the inputs.
post #6 of 17 Old 02-22-2020, 02:16 PM - Thread Starter
rpearlberg's Avatar
Quoted: 74 Post(s)
Yep, just didn’t know which one to get.
post #7 of 17 Old 02-22-2020, 02:22 PM
Otto Pylot's Avatar
Liked: 2770
The nice thing about Premium High Speed HDMI cables, if that's what you're considering, is that they should all be the same regardless of mfr because they've been tested and certified by an ATC (Authorized Testing Center) following standardized testing procedures and instrumentation. I've always used BJC Premium High Speed cables. They just work.
post #8 of 17 Old 02-22-2020, 03:43 PM - Thread Starter
rpearlberg's Avatar
Quoted: 74 Post(s)
Thanks! Looks like there are different ones to choose from that are BJC, what do I need?
post #9 of 17 Old 02-22-2020, 03:46 PM
Otto Pylot's Avatar
Liked: 2770
I used the Series-FE Belden Premium cables. White, because they look nice
post #10 of 17 Old 02-22-2020, 03:53 PM - Thread Starter
rpearlberg's Avatar
Quoted: 74 Post(s)
So this would be good? (Will be behind wall so color won’t matter)
https://www.amazon.com/Bonded-Pair-High-Speed-Cable-Ethernet-Black/dp/B0026NX3Z8
post #11 of 17 Old 02-22-2020, 03:59 PM
Otto Pylot's Avatar
Liked: 2770
https://www.amazon.com/Bonded-Pair-H.../dp/B0026NX3Z8
As long as it comes with the QR label and is described as a Premium High Speed HDMI cable you should be good to go. I purchased mine directly from BJC. You mentioned behind the wall. How long is your run and will you be installing your cabling in a conduit (highly recommended)?
post #12 of 17 Old 02-22-2020, 04:02 PM - Thread Starter
rpearlberg's Avatar
Quoted: 74 Post(s)
It’s just going from the soundbar under the tv to the back of the tv, so not very far.
post #13 of 17 Old 02-22-2020, 04:06 PM
Otto Pylot's Avatar
Liked: 2770
So it's not an in-wall installation?
post #14 of 17 Old 02-22-2020, 04:10 PM - Thread Starter
rpearlberg's Avatar
Quoted: 74 Post(s)
It is, just not very long
post #15 of 17 Old 02-22-2020, 04:17 PM
Otto Pylot's Avatar
Liked: 2770
So no conduit I take it. I would protect the connector ends then if you're going to blindly fish it thru the wall. Be careful of the connector ends and try to avoid sharp, 90 degree bends.
post #16 of 17 Old 02-22-2020, 04:18 PM - Thread Starter
rpearlberg's Avatar
Quoted: 74 Post(s)
post #17 of 17 Old 02-24-2020, 01:21 AM
Quoted: 649 Post(s)
Liked: 352
'It’s just going from the soundbar under the tv to the back of the tv, so not very far.' - simply ensure you can replace it easily and that you leave enough of a tail to allow you to move the TV out from the wall/remove it from its bracket without over stressing the cable.
Joe
Reply HDMI Q&A - The One Connector World
