active hdmi vs. extender - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Joe Fernand
post #1 of 6 Old 05-14-2020, 12:18 PM - Thread Starter
Quoted: 58 Post(s)
Liked: 0
I have yet to really find anywhere that compares which is better for a long run (~50') of hdmi cable from a receiver to a projector, using an active hdmi cable vs. using an HDMI Ethernet extender. They both seem like they are good, and there doesn't seem like there are many disadvantages to either. Is one better than the other, or is one more fail-safe/more reliable than the other? Running one HDMI cable seems simpler vs. using extenders
I plan to run the cable in raceways attached to the wall.
dmdbur is offline
post #2 of 6 Old 05-14-2020, 01:35 PM
skylarlove1999's Avatar
Quoted: 2033 Post(s)
Liked: 2096
Less traffic in your run the better. Buy a fiber optic HDMI cable and be done with it. Ruipro has a good rep on the forum.
Sent from my SM-G965U using Tapatalk
Tristan Jones
skylarlove1999 is online now
post #3 of 6 Old 05-14-2020, 08:43 PM
Otto Pylot's Avatar
Quoted: 3958 Post(s)
Liked: 2845
+1. Anytime you introduce a "break" in the HDMI chain (extender, wall plate, adapter, etc) you introduce the possibility of errors in the transmission of data. The most reliable connection for 4k HDR is a single cable, source to sink. However, 50' can be tough for any cable but the Ruirpo4k hybrid fiber cables are probably your best bet. That being said, there are some projectors that have difficulty with active cables at that length. Probably due to inconsistent current output at the sink end. You may need to use a voltage inserter to provide the consistent 5v/50mA (at least) that the cable requires.
I never trust an atom, they make up everything.
Otto Pylot is online now
post #4 of 6 Old 05-20-2020, 07:01 PM
Liked: 0
If you plan to run the cable in the wall, extender would be better.
He has a long enough distance to change places, maybe one year later.
EZCOO ProAV is offline
post #5 of 6 Old 05-20-2020, 07:57 PM
Otto Pylot's Avatar
Liked: 2845
Not for 4k HDR at 50'. Single cable, source to sink, with no extenders, adapters, wall plates, etc. Hybrid fiber is the best choice. For HD (1080) an active extender may work ok. I can understand why you would mention an extender because that's what you sell.
post #6 of 6 Old 05-21-2020, 12:03 PM
Joe Fernand's Avatar
Quoted: 655 Post(s)
Liked: 353
Both techs have advantages and disadvantages - ideally I would run the Conduit with at least one run of solid core, non-CCA/CCS, CAT6 plus a Hybrid Fibre HDMI cable (RuiPro4K being our preference), having surface mount conduit which allows you to 'open' up the conduit and lay in a new cable is ideal.
Any extender tech you install today will include some form of 'visually lossless' compression for 4K UHD signals.
Any 'active' HDMI cable you install today will ultimately become 'obsolete' if the active chip set does not support some future HDMI feature you wish to support - that may be a way down the line for you but it will eventually happen, we have customers with Active Copper HDMI cables which are 10+ years old and the customers are more than happy with how they perform at 1080p.
Joe
Otto Pylot likes this.
Octava Inc. Multi-cast HD over LAN solutions.
RuiPro UK and EU Sales and Support
The Media Factory. Residential and Commercial systems.
Joe Fernand is offline
Reply HDMI Q&A - The One Connector World
