Sony Z8h - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-16-2020, 05:54 PM - Thread Starter
Mary Braun's Avatar
Liked: 0
Sony Z8h
I recently pre ordered the Sony Z8h from my local Gramophone, they think it should be in by July. Since it is 8k are there any suggestions for 8k hdmi cables from this group, would like to reap the best picture possible. Also ordered the Panasonic DP-UB9000P-K, so would probably need same type of cable for it. Thank you in advance for suggestions.
Mary Braun is offline
post #2 of 5 Old 06-17-2020, 09:19 AM
Otto Pylot's Avatar
Quoted: 4042 Post(s)
Liked: 2898
There aren't any certified 8k cables on the market. There are lots of cables claiming 8k capability (48Gbps, HDMI 2.1) but there is no way to verify that because there isn't any source material that is 8k that requires 48Gbps data rates, and there aren't any panels that are true 12-bit. It appears that Sony's 8k panels can do 8k and VRR, ALLM (via future upgrades) and eARC so those are the only "HDMI 2.1" features currently available.
All of your HDMI connected devices will need to have the same HDMI 2.1 option sets available for complete compatibility.
Depending on the length of your cable run, a Premium High Speed HDMI cable, up to 25', with the QR label for authenticity, will work until there are certified Ultra High Speed HDMI cables available. However, those cables will be passive only so if you need an active cable because your cable run is over 25', active cables cannot be certified.
Keep in mind that the cable is just the data pipe. It cannot alter the pq in any way. What you can get is determined by HDMI chipsets at the source and sink end.
I never trust an atom, they make up everything.
Otto Pylot is offline
post #3 of 5 Old 06-18-2020, 12:10 PM
Liked: 0
Thanks, very helpful and informative.
laserplus is offline
post #4 of 5 Old 06-25-2020, 01:34 PM
Joe Fernand's Avatar
Quoted: 659 Post(s)
Liked: 356
Can we assume you have an AVR in the system too?
Only HDMI 4 on the TV is '8K' capable and that will have limited use unless you have a suitable camera - there are no other '8K' source devices at this time.
Joe
Octava Inc. Multi-cast HD over LAN solutions.
RuiPro UK and EU Sales and Support
The Media Factory. Residential and Commercial systems.
Joe Fernand is offline
post #5 of 5 Old 06-30-2020, 06:13 PM
Liked: 0
Yes I upgraded from a pioneer elite avr to a new Sony str- za 810 es 7.2 system, very nice also bought the
Panasonic DP-UB9000 HDR 4K UHD Blu-ray Player to complement my setup. Hope thehe tv shows up soon.😉
Reply HDMI Q&A - The One Connector World
