Firewire alternitive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-26-2018, 07:14 AM - Thread Starter
Liked: 0
Red face Firewire alternitive
Hello all.
I have an older JVC gr-d23ek video Cam.
Loads of mini video tapes I would like to put on my laptop to edit.
Problem: Laptop does not have Firewire input.
I notice on the Video Cam, besides the firewire output there is a s-video output.
could this be used to transfer the mini dvd tapes do you think?
If so, what would be the best way. My Laptop has USB and HDMI ports.
Many thanks in anticipation.
Banjoman007
Banjoman007 is offline
post #2 of 5 Old 03-30-2018, 12:44 PM
holl_ands's Avatar
Quoted: 959 Post(s)
Liked: 534
Your can TRY an inexpensive Firewire to USB Adapter...which may or may NOT work:
https://www.amazon.com/s/ref=nb_sb_n...+usb+converter
Or if you have a ExpressCard Slot on your Laptop:
https://www.amazon.com/ExpressCard-1.../dp/B003N3J354
And if that doesn't work, TRY a HUB with both Firewire and USB Ports...suggest you do your own research to see which ones work:
http://www.wisegeek.com/what-is-a-fi...sb-adapter.htm
holl_ands is offline
post #3 of 5 Old 04-02-2018, 10:49 AM
ilikeme's Avatar
What kind of laptop is it? Does it have a thunder bolt port? If so, thunderbolt is backwards compatible with FireWire and all you need is an adapter.
ilikeme is offline
post #4 of 5 Old 04-03-2018, 06:16 AM
ilikeme's Avatar
Those FireWire to USB adapters do not work at all. Completely different interface and those have been known to even damage equipment due to the voltage differences.
ilikeme is offline
post #5 of 5 Old 12-27-2018, 07:41 PM
latreche34's Avatar
Quoted: 151 Post(s)
Liked: 66
There is no such Firewire to USB adapter without a chip, The ones you see on ebay and amazon are fake and they damaged so many devices over the course of the last decade or so, Check the customers complaints.
Look for any Pinnacle capture device that has both the firewire and USB ports, Models like 500-USB, 510-USB, 700-USB, 710-USB. The smallest device USB powered is the 500-USB.
A driver is needed for newer operating systems, You can just install a trial-ware pinnacle software without having to use it and you get the driver for free.
With such devices you can transfer DV and HDV to your computer unaltered and you can control your camcorder from the capture application, The best known one for DV is WinDV, There few others that can do both DV and HDV.
latreche34 is offline
Reply Firewire 1394 Trade Association Q&A
