Discs the LG BH200 has problems with - Page 24 - AVS Forum | Home Theater Discussions And Reviews
post #691 of 1091 Old 08-13-2008, 12:07 PM - Thread Starter
bradavon's Avatar
Originally Posted by DCSholtis View Post
I have the Galapagos BD and it works with the latest firmware.
Thanks. I've removed it from the list, as it seems it's works for more people than not.
Originally Posted by allargon View Post
I see this Shooter HD DVD stuff coming back up. I thought we confirmed that it (the US HD DVD) worked fine with June.
Some say it's fine, others don't. It's one of those odd ones. The links in the first post should still work.
I will try to open it sometime this weekend or next week to re-verify Debbie Does Dallas Again and others with the June firmware.
Thanks. No rush.
Originally Posted by MikeFossati View Post
The newer version I got works with the BH200 whereas StardustOne has an older version which does not run.
It seems only Stardust's doesn't work. I'd guess if you buy it now, it will be fine.
bradavon is offline
post #692 of 1091 Old 08-13-2008, 12:08 PM - Thread Starter
bradavon's Avatar
Originally Posted by bradavon View Post
1. USA 21 BD - His post is missing so the link to it doesn't work. Krobar posted about this.
2. Shooter, USA HD-DVD - The link confirming the German HD-DVD works no longer exists. I'm guessing AlfaGT wrote about this.
3. Shooter, USA HD-DVD - The link confirming it works with the January firmware is also missing.
Krobar and whoever wrote the above about Shooter could re-post something please. I'll add it to the first post again.
bradavon is offline
post #693 of 1091 Old 08-13-2008, 02:30 PM
StardustOne's Avatar
My US Shooter HD DVD works with the January firmware but does not work with the June firmware. I remember another person that also mentioned it does not work with the June firmware.
StardustOne is offline
post #694 of 1091 Old 08-13-2008, 02:48 PM - Thread Starter
bradavon's Avatar
Cheers Stardust. I've updated the first post.
bradavon is offline
post #695 of 1091 Old 08-13-2008, 05:57 PM
CochiseGuy's Avatar
Here's two problem discs:
1- Crank: German HD DVD. Player gets stuck in the menu when you go in to select English audio & no subtitles. It lets you make the selection, but you can't get out of the menu. When you just hit "Play" at the main menu, it plays the movie but the Audio button on the remote won't let you change from the default German audio. The PAL DVD extras disc gets stuck in the menu as well.
2: Rambo (2008 release): It tried to load the disc and then just ejects it. I applied the region free DVD hack to the player, so I think the BD+ Fox uses detects the player has been altered and refuses to play the disc. I'll try Live Free or Dies from Fox tonight to see if affects other Fox titles.
EDIT: Stupid me. I tried Live Free or Die Hard & it played fine, so I tried Rambo again - and then I noticed I'd been trying to play the DVD digital copy.
Stupid me, but stupid packaging - the DVD digital copy is in the bottom slot of the case while the BD version is hidden behind inserts in the upper case. The Rambo BD plays fine.
CochiseGuy is offline
post #696 of 1091 Old 08-14-2008, 12:35 AM
Krobar's Avatar
Quoted: 97 Post(s)
Liked: 71
I did the same thing a few months ago after a few beers. Was ranting and raving that this new technology was just unstable and then put the bluray disc in.
Krobar is online now
post #697 of 1091 Old 08-14-2008, 12:54 AM - Thread Starter
bradavon's Avatar
Are you saying there's no way to choose English on the German Crank HD-DVD?
bradavon is offline
post #698 of 1091 Old 08-14-2008, 10:00 AM
CochiseGuy's Avatar
Correct. If you try to chose it in the disc menu you get stuck in the language menu with no way to get the movie to play. If you press Play when the main disc menu appears the movie will play with the default German language and there is no way to change it to English. On other HD DVDs and BDs, when you press the Audio button on the remote you can use the toggle directional buttons to cycle through the different audio options; you cannot do this with Crank.
post #699 of 1091 Old 08-14-2008, 02:41 PM - Thread Starter
bradavon's Avatar
Thanks CochiseGuy. You're running the June firmware and 0702 driver right? I've added it under the June list but want to confirm that's the firmware you have.
I can also confirm the Skynet Interactive HDi extras on the Terminator 2 German UE HD-DVD don't work. You click Yes to continue and it just sits there saying "Downloading". It never gets anywhere period. Oh well, I cannot say I'm too bothered.
I bought it for the movie and extras "on the disc".
bradavon is offline
post #700 of 1091 Old 08-14-2008, 03:27 PM
CochiseGuy's Avatar
Yes, June firmware & 702 driver.
post #701 of 1091 Old 08-14-2008, 03:34 PM - Thread Starter
bradavon's Avatar
Cheers. I thought you did.
bradavon is offline
post #702 of 1091 Old 08-14-2008, 03:36 PM
ls1115's Avatar
Just received Twenty Thousand Streets Under The Sky on HD DVD. This is another series from BBC 2. I am pleased to report that all menus work perfectly on this one!
ls1115 is offline
post #703 of 1091 Old 08-14-2008, 06:04 PM
DCSholtis's Avatar
Crank German HD DVD is working fine for me. Both the HD DVD and the PAL disc. No issues at all.
DCSholtis is offline
post #704 of 1091 Old 08-15-2008, 10:42 AM
allargon's Avatar
Quoted: 262 Post(s)
Liked: 217
Okay... Debbie Does Dallas Again HD DVD still has problems. However, I can select on the menu and get the movie to play and skip chapters to fast forward. The pop up menu stays on the screen during the movie.
"Picture This" HD DVD still has problems. It plays the movie, but don't attempt to fast forward, skip, etc. or the movie will stop. The only way to get the disc out is to power off the system and eject.
One more confirmation that playback of the US Shooter HD DVD is screwed. It loads up and goes to the menu. You can move the cursor all you want--no go. Play pretends to play the movie, but does nothing. I attempted to eject it. I got the LG blue screen garbled, flashing all over my screen over and over again--very strange.
Yeah, I guess my memory is faulty. I admit it.
La Môme HD DVD still has funky menus. You still can't select the chapter, etc. At least I can change it from DTS-HD HR to Dolby TrueHD!
"Art Mann: Crazyness in Austin" (HDNet out of print) has a very minor issue. At the beginning of the feature, the pop-up menu works fine. However, in later chapters, the pop-up menu will flash and disappear. The chapter skip buttons work, so I don't care.
The German La Haine HD DVD plays fine. (Good news!)
This is with the June firmware/702 driver.
allargon is offline
post #705 of 1091 Old 08-15-2008, 11:21 AM
allargon's Avatar
Quoted: 262 Post(s)
Liked: 217
The "Robbie Williams: Live at the Albert" HD DVD has flakey menus, too. It's a showstopper. It stays in the opening menu loop.
allargon is offline
post #706 of 1091 Old 08-15-2008, 04:11 PM
Don Borvio's Avatar
Quoted: 33 Post(s)
I'd like to report that with the 6/20 firmware, my copy of Shooter (USA HD-DVD) works completely fine. I can forward through chapters, watch the extras and play the movie normally.
Don Borvio is offline
post #707 of 1091 Old 08-17-2008, 04:49 AM - Thread Starter
bradavon's Avatar
Thanks I'll remove it.
Is there any way to turn the pop-up menu off? I guess the answer is not to press it.
AFAIK all the Studio Canal HD-DVDs work fine, except with the March firmware.
Thanks Allargon. I've updated the post.
bradavon is offline
post #708 of 1091 Old 08-17-2008, 04:51 AM - Thread Starter
bradavon's Avatar
Thanks. I've mentioned your post in the list.
Can you press Enter or something like that to get it to play and then advance forward using the Chapter button?
bradavon is offline
post #709 of 1091 Old 08-17-2008, 06:52 AM
allargon's Avatar
Quoted: 262 Post(s)
Liked: 217
No, I tried. The same for DDDA. The menu is there no matter what. I forgot to mention that the special features are inaccessible.
I will try the January firmware in the near future with my problem discs. I have a bunch of Digital Playground titles coming in next week. I will try those as well. I see me having a 2 hour phone call with LG support next week.
allargon is offline
post #710 of 1091 Old 08-17-2008, 07:13 AM - Thread Starter
bradavon's Avatar
So with DDDA the pop-up menu appears even if you don't press it? That's weird. Was it that way with the April firmware too?
I've added Robbie Williams.
bradavon is offline
post #711 of 1091 Old 08-17-2008, 07:50 AM
muzz's Avatar
Quoted: 930 Post(s)
Liked: 642
"Hello Ms. LG support, please put Debbie Does Dallas Again in the player, now try to play with the special features"
LMAO
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #712 of 1091 Old 08-18-2008, 08:52 AM
aagstn's Avatar
I just tested my copy of the US Shooter HD DVD and it does not work with the June Firmware on my player. Same issues as reported before.
Oddly enough Clerks II does work now. I get menus and can start the movie.
2014 Sony KDL70W850B and 2011 Sharp LC-60LE845U
2012 Sony BDP-S790 3D Blu-ray Player
Nvidia Shield TV
aagstn is offline
post #713 of 1091 Old 08-18-2008, 01:20 PM
DCSholtis's Avatar
With what firmware?!!
post #714 of 1091 Old 08-18-2008, 01:21 PM - Thread Starter
bradavon's Avatar
I don't think it's firmware connected but luck related . It works fine for some with any firmware.
bradavon is offline
post #715 of 1091 Old 08-18-2008, 02:12 PM
stpat's Avatar
I still think there must be different authorings of Clerks 2.
stpat is offline
post #716 of 1091 Old 08-18-2008, 11:21 PM
DCSholtis's Avatar
There must be. Question is how do we know for sure?!! I'm tempted to purchase another copy used in hopes it would work but I'm just not sure about it.
post #717 of 1091 Old 08-19-2008, 01:02 AM - Thread Starter
bradavon's Avatar
You could always find out where someone bought a working copy (for them) and if it doesn't work eBay it.
bradavon is offline
post #718 of 1091 Old 08-19-2008, 01:14 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
I got my Clerks II from inetvideo.
Spoiler
The donkey ****ing is a bit much, so I gave it to a friend whose into that kinda' thing...
Anyway, it played fine (on my BD-UP5000) and the menus also behaved. More data to add on top of the pile.
vinnie97 is offline
post #719 of 1091 Old 08-19-2008, 06:19 PM
MrMM1's Avatar
Was watching Harold and Kumar last night on my BH200 (June Firmware, latest driver) paired with my Onkyo 875 (Updated DSP's and 1.05 firmware?) and had a lot of random pops and sound glitches.
MrMM1 is offline
post #720 of 1091 Old 08-19-2008, 09:48 PM
DCSholtis's Avatar
Thats what I'll do. I'll order from inetvideo. Thanks.
Closed Thread Dual Format Players
