LG BH200 Owner Review - Page 32 - AVS Forum | Home Theater Discussions And Reviews
post #931 of 2675 Old 03-18-2008, 06:55 PM
badwilly's Avatar
Originally Posted by elube View Post
I am totally stupid in this area. I have a DSL modem connected to a linksys router. If I look at the modem (all I can see under the 192..... normal address) I'm not sure what to do in there and if the router plays a part also. But I can't see that unless you know another way?
My DSL modem lives at 192.168.0.1
My DHCP is on
Firewall may be set to high. Sometimes Norton software will block network traffic.
Off to watch a movie will report back after.
Cheers
Willy
badwilly is offline
post #932 of 2675 Old 03-18-2008, 07:04 PM
elube's Avatar
My DHCP is on
I have a switch in the room that connects my rack also. I will check on the settings of Norton. Thanks
elube is offline
post #933 of 2675 Old 03-18-2008, 07:35 PM
bradavon's Avatar
Try disabling Norton IS.
bradavon is offline
post #934 of 2675 Old 03-18-2008, 07:58 PM
p-g-m's Avatar
WOW, I'm so happy for you guys. Bitstream and so early!!! I've heard of May and hoping for "ever" for this fw to come, and now there it is. I see a light at the end of the tunnel for the Samsung. I owe the 5k and I bought an A-35 to be able to enjoy the new codecs and was thinking of getting a Panny today for that same reason, but now I may just return the Toshiba and get a 200. So...you say there's a forsed 24fps too?
p-g-m is offline
post #935 of 2675 Old 03-18-2008, 08:29 PM
FremontRich's Avatar
Well, I'm thinking of getting the BH200 now that the new firmware has been released and it will output 1080p/24. I currently have a RCA HDV5000 HD DVD player which allows me to update my firmware via it's ethernet port from a cable modem and my Comcast ISP. It's painless as all I have to do is use the RCA's menu to activate the firmware upgrade. Does the BH200 work the same way?
FremontRich is offline
post #936 of 2675 Old 03-18-2008, 09:04 PM
badwilly's Avatar
Well Folks
I just watched the Bourne Ultimatum in full. Not one dropout of any kind. Yea!!! I did have to choose the dts encode on my HDMI hookup. I think it is because my Denon AVR4306 is only HDMI 1.1. It had one lockup at the disk first load because I think the website was down that the HD DVD was trying to get to. I rebooted and cancelled the web load at bootup and all was perfect.
Cheers
Willy
badwilly is offline
post #937 of 2675 Old 03-18-2008, 09:06 PM
badwilly's Avatar
Under the last menu item in setup was a network update selection. It went out and told me I had the most recent one.
Cheers
Willy
badwilly is offline
post #938 of 2675 Old 03-18-2008, 09:11 PM
JKR1963's Avatar
Quoted: 330 Post(s)
Liked: 151
I opened the file.........then extracted it, then saved it to my Jumper (not a sweater...my British cousins!). You first have to open the PDF file as it has precise instructions for doing this.
Now I have tried my ID4 5star..........no audio or video drop-outs!!!!!!!!!!! I can't check the bitstream.....but others say it works. I will open and try my Sunshine Blu boy later tonight to see if the unit has also been updated to BD profile 1.1 or not.
I am so happy!! at net $349 , I am even more happy.
JKR1963 is online now
post #939 of 2675 Old 03-18-2008, 09:29 PM
badwilly's Avatar
I just played a short dvd and no audio dropouts. I think that LG may have a winner here. If I had only waited another 12 hours before returning my first unit. Oh well.
Cheers
Willy
badwilly is offline
post #940 of 2675 Old 03-18-2008, 09:56 PM
bradavon's Avatar
Has someone been able to test TrueHD over SPDIF and see if it's still 2 Channel or Multi-channel? Please
Correct HDMI 1.1 doesn't support TrueHD (or DTS-HD). You need HDMI 1.3, 1.3a or 1.3b for those two:
http://en.wikipedia.org/wiki/Hdmi#Versions
That said osofast35801 said TrueHD would be available as onboard decoding and sent out as PCM.
What audio options have you got to choose from? Are you sure you're getting the Full Lossless TrueHD? I ask as I think DTS Recode down converts it. Bourne Ultimatum (USA) HD-DVD has both TrueHD or DD Plus. You chose TrueHD right?
Great thanks. I've been wondering about that one, fixed Profile 1.1 support hasn't been confirmed yet.
Oddly LG have always said the BH200 was Profile 1.1 but then when you actually try one it fell over . I guess it could've been all along but it doesn't mean much when you cannot actually play them.
I look forward to hearing from you my American cousin .
bradavon is offline
post #941 of 2675 Old 03-18-2008, 10:03 PM
Sunnie's Avatar
When I went to update the player it initially wouldn't see either the image on the USB or a CD. It saw the devices just not the update. At this time I had used my Vista computer. I powered up my XP machine and did the process again. Worked perfectly. I noticed that the name of the file when Vista extracted it versus XP was different. I don't know why, but my suggestion is to use XP if you have it.
Never had any problem with Vista here.
Sunnie is offline
post #942 of 2675 Old 03-18-2008, 10:44 PM
badwilly's Avatar
Hi
I tried the PCM Multi-ch and got 2 channel. Actually, the manual says with TrueHD it is PCM 2ch. I'll have to test but I think I also tried the DD Plus and it was 2 channel (manual says should be 5.1 pcm). The DTS encode sounded great though. Also according to the manual, DTS encode drops the audio to 48kHZ. My receiver is capable of 192K sampling. I didn't test Primary Pass-thru.
Cheers
Willy
badwilly is offline
post #943 of 2675 Old 03-18-2008, 10:46 PM
badwilly's Avatar
I must have did something wrong on the vista machine.
Good night all. See you in the AM.
Cheers
Willy
badwilly is offline
post #944 of 2675 Old 03-18-2008, 10:52 PM
bradavon's Avatar
I can only presume because your Amp is HDMI 1.1 it is unable to pick up the TrueHD.
As of the 17th of March 2008 the manual is out of date
That should definitely be 5.1.
That maybe why. Give that a go
bradavon is offline
post #945 of 2675 Old 03-19-2008, 12:50 AM
JKR1963's Avatar
Quoted: 330 Post(s)
Liked: 151
I was just watching and playing around with the PIP on the Sunshine BLU RAY and it all seemed to be working fine..........I was getting the PIP and stuff that the menu on Sunshine was saying you need a PIP capable player to use the feature.
I had no issues loading this disc either..........I have to go to bed ...will check more tommorrow.
post #946 of 2675 Old 03-19-2008, 01:12 AM
AlfaGT's Avatar
Right. I can confirm that the Denon AVR-4306 has HDMI 1.1. So he does not support bitstream for the new HD audio-codecs. I had this machine before I upgraded to the AVR-4308.
I would advise, to let the LG make the decoding and send an PCM-signal to the Denon 4306. The Denon 4306 is capable of handling Multi-Channel signals. Think this is the better solution than down-convert the audio-tracks to an ordinary DTS signal.
Greetings
AlfaGT is offline
post #947 of 2675 Old 03-19-2008, 01:49 AM
bradavon's Avatar
Fantastic. Thanks.
So you can also watch the film in Full DTS-HD? Did the LG ever have a problem playing Sunshine back or was it just the Samsung that has this problem?
Lazerfan has reported he cannot play it with the November firmware:
https://www.avsforum.com/avs-vb/showthread.php?t=1002769
But I don't think anyone else has had a problem.
bradavon is offline
post #948 of 2675 Old 03-19-2008, 02:47 AM
bradavon's Avatar
I've been through this thread and updated the first post here:
https://www.avsforum.com/avs-vb/showthread.php?t=1009104
To include confirmation links for all the things the firmware fixes, check it out!
bradavon is offline
post #949 of 2675 Old 03-19-2008, 06:59 AM
LGdoubter's Avatar
It seems a lot of us are having problems getting the 200 to the internet via a router. I called LG and they are sending a firmware update disc to solve the problem. (we'll see - lack of the 0701 driver is the culprit?) - I was also transferred to a techie named Matt who wasn't at his bench and never called back. I thought it was something I had done (or not done) with the wireless system - but some of you guys are probably a lot more savvy about these things and are having the same issue. Anyone have this solved yet?
LGdoubter is offline
post #950 of 2675 Old 03-19-2008, 07:25 AM
volleybradt's Avatar
Another update is now showing on the LG site..... Please note: different file size, not sure what this fixes but lets see if it takes care of any other puny issues like driver updates....
Subject Program Update for BH200.
Product DVD&VIDEO&SET TOP
Operating System Windows 2000
Windows XP
File Name LG_BH_LV221BH.zip SB_BH200_0124R.pdf
This firmware file is apply for USA and Canada only.
#.It was improvement of performance;
While playing through Primary PassThru setup, disappearing sound issue has been fixed.
#. Firmware Version : BH02080124R
#. Countermeasure
: Updating by using the newest firmware.
The update method is refer to the attatchment
volleybradt is offline
post #951 of 2675 Old 03-19-2008, 07:50 AM
bradavon's Avatar
Well spotted, thanks. I'm downloading it now.
1. The ZIP file size has gone from 39Mb (39,378K) to 38Mb (38,054K - 2008-03-14) to now 33Mb (33,744K).
2. The 2008-03-17 Firmware's ROM file is 38,955,543 bytes compared with the new one which is 34,543,200 byte.
3. The Firmware file name is still the same: LG_BH_LV221BH.zip
4. But the PDF Instructions filename has changed from SB_BH200_1119P_080102.pdf to SB_BH200_0124R.pdf
Which if I'm reading it correctly means 01/24/08, so still wrong
5. Also the Change Log for both are identical:
#. Countermeasure
bradavon is offline
post #952 of 2675 Old 03-19-2008, 07:50 AM
suntanjam's Avatar
I just installed the new firmware and tried a disc I was having problems with, Legends of Jazz Blu-ray. Not only was there no audio drop-outs, but Dolby TrueHD lit up in its blazing glory on my Pre-amp!!! The sound is incredible!!! I have to go to work where I will update our store unit and play around with it some more. Also noticed 1080p film mode in "others" setup. So far I'm as happy as a clam!!! Where did that phrase come from anyhow? Either way, YEA BABY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I looked at the LG service site and all I saw were 2 updates listed. Both had the P designation in their listing. Am I missing something. It would be ironic the day after I return the player a new update is issued. Of course before I rebuy, I would want to know if the issues with dropout are fixed.
suntanjam is offline
post #953 of 2675 Old 03-19-2008, 07:51 AM
badwilly's Avatar
Windows XP
#. Countermeasure
First we have no updates and now 2 within 2 days. I'm going to try the network update method when I get home. The document doesn't mention it but I think its just the same one they have been using and not updated for the new firmware. It seems LG is really trying to get these working. It is an expensive unit from retail but if it does everything as promised, I will consider it a good deal. Besides, I don't have any more room in my AV rack.
Cheers
Willy
badwilly is offline
post #954 of 2675 Old 03-19-2008, 07:51 AM
bradavon's Avatar
Right I've opened both ROM files in Wordpad (yes Wordpad) and can tell you the header on yesterday's is:
BH02080314B
And the new one is:
BH02080124R
In short = It's older!
I'm guessing it's the European (or similar) firmware that AlfaGT posted above a few days ago.
p.s - As long as you DON'T save the file in Wordpad (if you do re-download it) you can also open the ROM file in Wordpad after you've unzipped it. It takes a few minutes to open and most of it you'll see is computer code. To be on the save side I'd recommend if you do open it in Wordpad re-download it or work on a second copy of the ZIP File.
bradavon is offline
post #955 of 2675 Old 03-19-2008, 07:55 AM
So are you going to update with it?
post #956 of 2675 Old 03-19-2008, 07:56 AM
LGdoubter's Avatar
Not only is it older - it ELIMINATED the new NETWORK CONNECTION option. What the....?
post #957 of 2675 Old 03-19-2008, 07:56 AM
bradavon's Avatar
Like I said, it's older. You want the second one, file size:
38,054K
That's the latest firmware, despite having the wrong file name.
I'd roll back if I were you to: BH0208314B (2008-03-14)
LG really need to get their filenames sorted out!
bradavon is offline
post #958 of 2675 Old 03-19-2008, 07:58 AM
hello252's Avatar
Why doesn't someone email LG and find out what the difference is between yesterday's and today's. I would, but I am swamped this a.m. Please post your response.
hello252 is offline
post #959 of 2675 Old 03-19-2008, 08:02 AM
bradavon's Avatar
Why?
I've said it's 2 months older (those dates are from the header in the actual ROM file that is read by the LG BH200) and LGdoubter has said it at least disables your Ethernet connection.
The firmware released today is date stamped 2008-01-24 (which I'm sure is the date AlfaGT gave on his Swiss BH200 when he told us about it a few days ago) so newer than the November 2007 firmware but older than yesterday's which has a date stamp of 2008-03-14 which was only last Friday.
My guess is LG shouldn't have uploaded it at all or if they should've they messed up the filenames/dates etc...
At least they got the filename for the PDF Instructions right this time
BH02080314B
And the new one is:
BH02080124R
Just for fun I opened the even older firmware in Wordpad and that has a date stamp of:
BH02071119P
No surprises there then.
bradavon is offline
post #960 of 2675 Old 03-19-2008, 08:16 AM
LGdoubter's Avatar
LGD - stupid
Reinstall of #3 has corrected.
Thought maybe the older one was a setup to #3 - just posted poorly - and executed even worse.
No harm - no foul.
Reply Dual Format Players
