List of actual mods from Musical Concepts website:
"LX Series Modifications
Modification Strategy: Our venerable LX mod for your Adcom amplifier has changes in feedback circuitry which improves bandwidth, dynamic range and bass solidity/power. The bias circuit uses a new and better bypass capacitor with an added high quality bypass capacitor. Input and output filters are improved with far better parts. Some critical resistors are upgraded. Each small-value (p high frequency stabilizing capacitor is optimized for audio quality. Each power supply capacitor has an added bypass capacitor. Elite and higher models have superb power rectifiers in the main power supply. We use the finest soft-recovery diodes superior in naturalness and dynamics.
The Sound: LX is much more natural, sweet and liquid. Soundstage is much more open. Imaging from top to bottom is more predictable, i.e. instruments come from stage locations that seem more accurately positioned. Gone is the brightness, etched quality and bass inaccuracies. Perceived dynamic range soars! The Elite version is even more refined/defined with solid bass extension and silky extended high-end detail, a definite improvement in resolution and definition. The mids have superior timbre, texture, clarity and musical naturalness. Highs are more natural and clear.
We no longer support all Adcom power amps. Some of the newer mosfet amps, GFA-5800/5802 plus several others and multi-channel amps are not serviced.
LX Mod
LX mods are for all the earlier classic stereo or mono Adcom amplifiers, including all “535”, “545”, "555", "585", “565", etc.
Features of the LX Mod*
Superior coupling caps - better sound top to bottom with great bass, tonal purity, 3D qualities of focus and transparency
Feed back(FB) loop tech mods - better phase response - tight, deep, clean bottom, even more 3D sense of sound space
Superb cap used in Zobel network(output load) - more open
High quality resistor replacements in several locations - smooth and silky yet great clarity and intonation
Better bypass caps in power supply, FB loop, Bias circuit - dynamics with control, big soundstage
$399 installed for early Adcom stereo and GFA-5500 amps
GFA-565 LX mod is $599/mono
pr
*Will vary with different Adcom models
LX Elite Mod
The Elite mod includes all the features of the LX Mod…
Plus More Features*
Premium grade Audio specific electrolytic capacitors - more transparency, quickness, clarity
Premium power HiperFred rectifier - smooth, transparent, rich majestic sound stage and dynamics
Select bypass capacitors - dynamic, silky, open stage
$599 installed for all early model Adcom stereo amps, other items listed below
GFA-5500 $529 - rectifier replacement not included for GFA-5500
GFA-565 $799/
pr
LX Mini-Platinum Upgrade
While you could apply this to the standard LX mod it clearly makes the most sense to add it to the ELITE version.
Takman CF resistors in strategic locations offers superior naturalness and clarity, plus a very elegant proper warmth.
Some added larger bypass caps are used in critical locations
Additional power supply tweaks
Add this upgrade to an ELITE mod for even more natural sound. Add $200 to stereo ELITE mods, $300 to ELITE mono pair pricing."
