Help with Cartridge/stylus ID (Technics SL-D2) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-13-2016, 08:28 PM - Thread Starter
AJPeacock's Avatar
Quoted: 13 Post(s)
I bought a Technics SL-D2 at a garage sale 10 years ago for my daughter. She recently 'upgraded' to a new TT and I've inherited the Technics.
It sounds 'OK', but there is very little bass, even from brand new 'audiophile' vinyl.
I'm wondering if it needs a Stylus and/or Cartridge refresh. I've tried my best to adjust the cart.
I don't want to be chasing red herrings, so thought I should figure out the currently installed Cartridge/stylus.
The Cartridge has a "MA 20" on the face. The stylus is labeled with "Shure HE".
I know there has been 100's of hours of listening since I bought the TT used at the garage sale for $10.
AJ
ID:	1496153   Click image for larger version
Epson 5030UBe
118" Painted wall (Black Widow) (Dover Grey mixed 4:1 with AAA-F)
Marantz SR-6010 amp
Thiel CS .5 front speakers
SVS SB13-Ultra
Polk Audio Center Channel Speaker (CS 350)
AJPeacock is offline
post #2 of 5 Old 06-14-2016, 05:11 AM
Clarence's Avatar
Quoted: 534 Post(s)
Liked: 21986
My TT is also a SL-D2. Love it.
I currently use a JVC 4MD-20X, but unless you have a quadraphonic receiver, that's probably overkill and way above what you need to spend.
The other cartridges that I have used are Ortophone OMP 5E and AT125LC.
Clarence is online now
post #3 of 5 Old 06-14-2016, 05:59 AM
balky's Avatar
Quoted: 289 Post(s)
Liked: 207
Just curious on which Phono pre-amp you're connecting the TT to...
balky is offline
post #4 of 5 Old 06-18-2016, 06:46 AM - Thread Starter
AJPeacock's Avatar
Quoted: 13 Post(s)
I figured out the issue and will post an update after I answer your question.
I'm currently using the built-in phono pre-amp in the Marantz SR6010.
I built a VSPS with Mica caps and upgraded op amps a few years ago and it does a very fine job, but haven't done any a/b testing between it and the built-in since upgrading to the SR6010. (pure laziness on my part).
Thanks for the question,
AJ
Epson 5030UBe
Marantz SR-6010 amp
SVS SB13-Ultra
post #5 of 5 Old 06-18-2016, 06:55 AM - Thread Starter
AJPeacock's Avatar
Quoted: 13 Post(s)
Interestingly, after taking the pictures of the stylus for this forum, when I put it back together, it just felt like it 'seated' better ???
I found a discussion on the Guru protractor/positioning and decided to give that a shot.
Amazingly, it now sounds terrific (better than ever).
I'm not sure if it is the Guru positioning or the stylus being removed/replaced (probably hadn't been removed/reseated in 20+ years).
Listening to 'The Doors : The End" on 180g last night, I was shocked at the strength of the drum kit.
Very very pleased.
Thanks all,
AJ
Epson 5030UBe
Marantz SR-6010 amp
SVS SB13-Ultra
Reply 2-Channel Audio
