Marchand XM-66 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By A9X-308
post #1 of 5 Old 10-03-2016, 07:00 PM - Thread Starter
Thunder240's Avatar
Marchand XM-66
I thought I'd post this mini-review only because I recently spent several weeks trying to get information about this crossover without any luck and ultimately took the plunge with very little information to go on. Fortunately, I'm pretty happy with my purchase, but in case there is anyone else looking for some user experience regarding Marchand's variable frequency active crossover, the XM-66, hopefully you'll find this useful.
For the last several years I've used a 2 channel dbx 223s crossover in my 2.1 home stereo rig to relieve my power amp of the low frequencies. It was pretty cheap, about $150 at the time of purchase, and I felt it didn't noticably color the tone, but when I would compare the sound through my speakers to a system without the crossover in the signal path, I could tell it was adding some low level but nonetheless audible noise. I talked to tech support at Harmon Kardon at one point, and they advised me that the noise was a result of the dbx 223s being designed for a +4dbu (i.e. pro audio) nominal signal instead of a lower nominal signal typically found in home stereos. Although who knows, it may have still been audible at higher line levels as well.
A few months ago I began looking for crossover to replace my dbx. First, I wanted it to be analog (there are some folks on this forum who swear by the miniDSP -- if it works for you, that's great, but the heart wants what the heart wants). Second, I wanted it to be dead silent, totally transparent, with 4th order low and high pass. Third, I wanted it to have damping control to help me dial it in, and I preferred a variable frequency, which ruled out Marchand XM9. I didn't want to spend more than about 600, although I ultimately raised my price cap a couple hundred to 850. Finally, I wanted it to either support balanced and unbalanced, or else be upgradable to balanced (my rig is currently balanced from DAC to preamp, and then unbalanced from preamp down to the power amp, although I antitipate eventually getting a balanced amp and running balanced all the way through).
If you've been looking into [analog] active crossovers at all, you've probably noticed that there are a bunch of pro crossovers priced between 100 and 300, and then most crossovers designed for home stereo. The problem with these crossovers is that all of them have the same design issue that the Harmon Kardon techs mentioned to me -- they are designed for hot pro-audio signal levels. They might claim particular SNR and particular distorion specs, but those specs are for +4dbu. Typical home audio nominal signals are -10dbV, which is about 12dB softer, and at that level the distortion and SNR are a lot worse.
Home audio crossovers, on the other hand, are significantly more expensive. The cheapest I could find was the Hsu crossover, priced around 500, and they go up from there. Most are well over 1000. Eventually I settled on the Marchand XM66 because of its variable frequency adjustments. I couldn't find any user or pro reviews, although there were some very positive reviews of the XM44, and Phil Marchard wrote to me that he couldn't hear any autible difference between the XM44 and the XM66 (althoug he acknowledged that in theory one might expect fixed frequency modules to outperform a variable circuit).
Now that I've had the XM66 in my rig for about a month, I feel comfortable sharing some thoughts. First, it's built like a tank! Second, it is, indeed totally transparent to my ears. I have the unit set to 50Hz (after some experimentation to integrate my sub). When I compare music that does not have any bass with the crossover in the signal path to the same music without the crossover, I cannot detect any difference. With bass, integration between speakers and sub is pretty darn good. I'm quite content with the damping, phase 0/180, and frequency adjustments. Undoubtedly if I had seperate adjustments for low pass and high pass filter frequencies I could probably achieve slightly better integration, and this might be important for some, but I don't need this level of flexibility. Lastly, Phil Marchand is very helpful, and answered several of my questions.
The one negative I have to share is that Marchand has unfortunatley stopped selling crossovers as kits. But it's hard to blame him! I doubt he made any profit on them.
Thunder240 is offline
post #2 of 5 Old 10-04-2016, 07:35 PM
Glimmie's Avatar
Quoted: 1079 Post(s)
Liked: 1000
I have built a couple of Marchand kits. Very high quality designs, parts selection, and layout.
True audiophile products without the fancy and expensive extruded aluminum chassis that adds nothing to the sound quality.
Glimmie is offline
post #3 of 5 Old 02-09-2017, 05:57 AM
Masis's Avatar
Great write up Thunder thanks for the effort. I have read your other posts regarding analog crossovers to add to your system. I am in the same process at moment trying to find a crossover that I can use which retains my current DAC on my amplifier. I do think purchasing a digital DAC combined crossover which might have digital room correction or any other feature would be pointless when you already have dedicated DAC.
I am very close in purchasing the XM66, I have been waiting impatiently to add a sub to my 2 channel system. A very modest set up a NAD C-356DAC amp with PBS XB Bookshelf speaker. My sub is of below average quality a Jamo 200 sub but acoustic treatment although DIY equates to over $4000 worth so the addition to a sub and quality crossover would in my mind add the next step for an upgrade and open up the speakers.
My only issue is how the crossover will effect the quality of my NAD sound? Can you shed some more light on situation from your experience?
I know yo have mentioned your thoughts but its been a while and curious if you feel the same way?
Masis is offline
post #4 of 5 Old 02-09-2017, 10:12 AM
A9X-308's Avatar
Quoted: 1792 Post(s)
Liked: 1484
A MiniDSP or a DCX2496 will do far more for less cost.
Steve Hanna likes this.
A9X-308 is offline
post #5 of 5 Old 06-15-2017, 08:01 AM
Quoted: 14 Post(s)
Liked: 2
I too purchased an XM66 with little info, other that Marchand produces high quality products and had exactly what I needed.
Many folks out there that use subwoofers without both low and high pass filtering are not getting the best quality and integration with their mains/subs. I wont start preaching about how vital I believe it is to use a proper crossover when integrating subs, but do want to say that I am very pleased with the XM66 active crossover. Dead silent, and adds zero coloration to the signal/music. Highly recommended.
_______________
PS Audio BHK Signature Preamp | PS Audio BHK Signature 300 Monoblocks | Auralic Aries G2 | AURALiC Vega G2 | Auralic LEO GX | KEF R11 | Dual SVS SB13-Ultra | Roon Nucleus+
Orosie is offline
Reply 2-Channel Audio
crossover , marchand
