Originally Posted by
3db
Have you looked at a lot of curves? I have and these are not that bad at all. Most likely, on par with your speakers. If you want more accurate measurements,I suggest visiting soundstage.com or Stereophile. S&V measurements are not all that accurate.
Liking a speaker is a personal preference. It would appear from your critique and comments that your preference is towards a more colored or biased sound, something like boom and sizzle. Thats your choice but to me, I would get listener fatigue early on whereas the PSB and Salk speakers, I could listen for extended time and not get tired.
Nope you have me wrong. This is what the speakers a line below mine look like. Dynaudio believes in similar flat frequency response, low distortion, wide dispersion. Dynaudio is smooth and silky, touch of warmth, with strong, tight bass. You should hear them sometime.
Here you go the previous Focus line, I owned both the Excite and Focus. The Focus line I have is the newer one (now discontinued), they improved woofers by using the upper tier contour with some newer things they'd learned from the Confidence revision for quicker response and longer excursion, the tweeter was given the new precision coating and a neodiuyum magnet vs ferrite, changed the crossover to that matching more closely their Special 25 speaker and improved cabinet structure and dampening. Again a nice flat response.
Dynaudio Contour 20, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, Naim Uniti Star, Marantz SR5010, 60" 4K Samsung LED LCD, XBOX ONE S
