Preamp recommendation needed - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By GIEGAR
  • 1 Post By simplyderp
  • 1 Post By fatbulkexpanse
post #1 of 16 Old 09-18-2018, 10:03 AM - Thread Starter
fatbulkexpanse's Avatar
Quoted: 117 Post(s)
Liked: 89
Currently I have two systems:
1. Monitor Audio Silver 10s, PS Audio M700 power amps (on the way), and a Simaudio Moon 240i integrated amp
2. Philharmonic Audio BMR Philharmonitors, Yamaha A-S801 integrated amp
I'm returning the Yamaha and will move the Moon 240i to system 2. So, I'll need a preamp for system 1. Right now I have my eye on the Parasound Halo P5 or P6. I want to know if there are other preamps I should be looking into. Here are the features I want:
  • At least one each of USB and optical inputs (obviously this means built-in DAC)
  • Phono stage
  • Some sort of subwoofer management because I do plan on getting 1-2 subs in the future
  • Remote control
  • Obviously a few regular analog line inputs
If there is a preamp that also has some sort of room correction, all the better. I'd like to spend around $1,000, and I'm not opposed to buying used.
Philharmonic BMR Philharmonitor | Rythmik F12G | Parasound Halo P6 | PS Audio Stellar M700 | Oppo BDP-103
fatbulkexpanse is offline
post #2 of 16 Old 09-18-2018, 10:12 AM
Cla55clown's Avatar
Quoted: 406 Post(s)
Liked: 128
With those requirements I'd be looking at the parasound p6.
What didn't you like about the Yamaha?
Sent from my Nexus 5X using Tapatalk
Cla55clown is offline
post #3 of 16 Old 09-18-2018, 10:31 AM - Thread Starter
Quoted: 117 Post(s)
Liked: 89
Would you exclude the P5? If so, why?
I didn't have any big issues with the Yamaha, but it doesn't fit well into how I want to set everything up. My biggest complaint, though, is that the loudness can't be controlled by the remote (but the volume can).
post #4 of 16 Old 09-18-2018, 12:18 PM
Quoted: 37 Post(s)
Liked: 30
Agreed, also no reason to discount the P5 other than it's been replaced in the line.
SOTA Nova (III)/Jelco TS-550S/Grado Sonata V2/Parasound JC 3 Jr and Zpre3/Parasound A23+/TEAC A-2520/Philharmonic BMR
6TCycleHum is offline
post #5 of 16 Old 09-18-2018, 12:51 PM
Alex F.'s Avatar
Quoted: 981 Post(s)
Liked: 587
Unlike the Yamaha's A-S801's variable loudness control (versus a typical fixed setting), the Parasound P5 and P6 preamps do not have any loudness control.
Note that it is possible to use the Yamaha's remote to engage and disengage a pre-selected loudness setting by utilizing the Pure Direct button.
Music room: Cary SLI-80 tube integrated amplifier, McIntosh MA6500 integrated amplifier, Quad 99 preamp, Quad 909 power amp, Acoustic Research AR9 loudspeakers, Yamaha CD-N500 CD player, Teac UD-503 DSD DAC, Phase Linear 8000 II linear-tracking turntable.
Theater room: Panasonic 65S60 plasma television; Yamaha RX-A2020 (preamp section); Adcom GFA-5503 and GFA-5400 amplifiers; Polk LSi25, LSiC, and LSiF/X loudspeaker system; Velodyne FSR-18 servo-subwoofer.
Alex F. is online now
post #6 of 16 Old 09-18-2018, 12:55 PM
GIEGAR's Avatar
Quoted: 1008 Post(s)
Liked: 1703
... Here are the features I want:
  • Phono stage
  • Remote control
Slightly over $1K but packs top class Dirac Live® digital room correction and all the features on your list except for the phono stage:
https://www.minidsp.com/products/str...-hd-series/shd.
fatbulkexpanse likes this.
GIEGAR is offline
post #7 of 16 Old 09-18-2018, 12:56 PM - Thread Starter
Quoted: 117 Post(s)
Liked: 89
Yes, unfortunately it seems I'll have to lose out on the loudness control by switching things around as I have planned.
post #8 of 16 Old 09-18-2018, 01:03 PM - Thread Starter
Quoted: 117 Post(s)
Liked: 89
That is a really good idea, and I'd forgotten about that one (probably because it doesn't have phono). I only listen to records very rarely, though, and not seriously so I could probably add a (relatively) cheap external phono stage.
post #9 of 16 Old 09-18-2018, 03:48 PM
simplyderp's Avatar
Quoted: 46 Post(s)
It's a great stereo processor with independent measurements by audiosciencereview.com to prove it, but be aware that miniDSP doesn't accept any returns. I bought one and kind of regret it, now that I'm getting into surround sound.
simplyderp is offline
post #10 of 16 Old 09-18-2018, 03:56 PM - Thread Starter
Quoted: 117 Post(s)
Liked: 89
They don't accept returns for any reason?!? If so, that's a really big consideration and I'm glad you mentioned it.
yanks1 likes this.
post #11 of 16 Old 09-18-2018, 03:58 PM
simplyderp's Avatar
Quoted: 46 Post(s)
http://support.minidsp.com/customer/...return-policy-
LG C9, Genelec 8341A, miniDSP SHD, GIK Acoustics
post #12 of 16 Old 09-18-2018, 04:08 PM - Thread Starter
Quoted: 117 Post(s)
Liked: 89
Wow. That's a deal breaker for me.
yanks1 likes this.
post #13 of 16 Old 09-19-2018, 12:00 PM
Quoted: 1066 Post(s)
Liked: 863
Holy cow; didn’t realize P6 was available, just checked and it’s $1,495.. ouch; I bought gently used P5 preamp 9 months ago for $650
Primary set-up 5.2.4; Yamaha A2050, Paired w/Parasound P5 & ATI 522NC 2 channel amp
Revel F206 fronts & Revel M16 rears; 2 Outlaw X12 Subs & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is offline
post #14 of 16 Old 09-19-2018, 12:04 PM - Thread Starter
Quoted: 117 Post(s)
Liked: 89
Have you had any issues with it?
post #15 of 16 Old 09-19-2018, 12:54 PM
Liked: 863
None; my P5 is rock solid
yanks1 is offline
post #16 of 16 Old 09-28-2018, 11:19 AM - Thread Starter
Quoted: 117 Post(s)
Liked: 89
I'm leaning towards the P6. Anything else I should look at before pulling the trigger on the P6? (SHD is out of the running because of the return policy, and P5 is still a consideration if I find a good one used.)
Reply 2-Channel Audio
