2 Channel powered Speakers - AVS Forum | Home Theater Discussions And Reviews
 15Likes
  • 6 Post By _tk
  • 1 Post By Captain Crunch
  • 1 Post By dunejunkee
  • 1 Post By qirex
  • 2 Post By jer181
  • 2 Post By jer181
  • 1 Post By pjp
  • 1 Post By wassup
post #1 of 22 Old 03-28-2019, 03:36 PM - Thread Starter
jer181's Avatar
Quoted: 125 Post(s)
Liked: 25
Looking for suggestions on powered book shelve speakers for 2 channel. Don't want to spend over $500 CAD, and have to be reasonable small as they are going above a fire place in a family room on either end of the TV.
Other option would be running wireless speakers from an SC67 located in the basement (although I would assume that would be more than $500!)
thanks!!!
jer181 is offline
post #2 of 22 Old 03-28-2019, 05:17 PM
bing!'s Avatar
Quoted: 322 Post(s)
Liked: 234
bing! is offline
post #3 of 22 Old 03-28-2019, 07:02 PM
_tk
Quoted: 439 Post(s)
Liked: 175
The focus is all messed up with that picture of the audioengines.
_tk is online now
post #4 of 22 Old 03-29-2019, 06:44 AM
TheDudeAbides's Avatar
Quoted: 13 Post(s)
Liked: 31
thanks!!!
Disclaimer - I have not tried them myself, but Emotiva Airmotivs can be had for <$500 on the used market and I have heard tell they are pretty decent in terms of sound reproduction. Best bet to find them at a decent price would be on the Emotiva Emporium or AVSForum Classifieds site. I do not believe they manufacture them any longer (powered versions, anyway), so they'd likely have to be picked up used or old-stock.
Best of luck!
TDA
"The Dude abides. I don't know about you but I take comfort in that. It's good knowin' he's out there. The Dude. Takin' 'er easy for all us sinners. Shoosh. I sure hope he makes the finals."
TheDudeAbides is offline
post #5 of 22 Old 03-29-2019, 08:07 AM
Captain Crunch's Avatar
Quoted: 144 Post(s)
Liked: 80
I read the edifier s2000pro was pretty good for $400usd
You may want to look up some reviews on that one.
Adam audio has some out there also.
wassup likes this.
SVS system 3X SCS-01s L-R & C, / 2X sbs-01s surrounds / 20-39pci sub.. AVR Pioneer - VSX-831
Captain Crunch is offline
post #6 of 22 Old 03-30-2019, 03:53 AM
glangford's Avatar
Quoted: 702 Post(s)
Liked: 618
Normally I'd recommend the audioengine a5 speakers but given you want them on the mantle they will be very close to the wall which isn't ideal for a rear ported speaker. The A2 and HD3s are front ported, but may not fill up the room with 2.75 in woofers. The Edifier S2000 pro is also rear ported but offers bass and treble controls to tame bass bloat from near the wall.
There are a few edifier front ported models that are cheaper. Here's one with a 4 in woofer and a front port.
https://www.amazon.com/dp/B016PATXSI...a-6fb64f5c7c10
One note about the edifier models is that they have cabinets like the Swan monitors, a deep base for the cabinet and may not fit on the mantle without hanging over. Be careful of dimensions.
I'd almost be tempted to try the Audioengine A2+ or HD3 and see if that can fill in the sound you want.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #7 of 22 Old 03-30-2019, 05:20 AM
dunejunkee's Avatar
Quoted: 22 Post(s)
Liked: 33
I have the transparent zero in my office and they sound great. These are a little higher than what you want to spend. https://www.amazon.com/Vanatoo-Trans...s%2C154&sr=8-3
wassup likes this.
Basement system: Yamaha 2060, Cambridge Azur 851W, Sony HAP-A1ES, Rega RP-1, B&W CM10S2, B&W CM Centre S2, Cambridge Minx XL,2 JL Audio e112
Upstairs: Yamaha R-N803, B&W 606 Continuum, 1 JL Audio D108
dunejunkee is offline
post #8 of 22 Old 03-30-2019, 09:05 AM
qirex's Avatar
Quoted: 111 Post(s)
Liked: 79
Since you're up North keep an eye out for Kanto speakers on sale, they're a Canadian company and frequently have good deals.
kantoliving likes this.
qirex is offline
post #9 of 22 Old 03-31-2019, 08:52 PM
DJ_JonnyV's Avatar
Quoted: 53 Post(s)
Liked: 45
I will continue to endorse the KEF Eggs. Have them in a 2.1 setup in my office and use them daily. Still happy with them over past 2 years. Just another option to research for you.
DJ_JonnyV
DJ_JonnyV is offline
post #10 of 22 Old 05-06-2019, 03:33 PM - Thread Starter
jer181's Avatar
Quoted: 125 Post(s)
Liked: 25
I ended up going this route but the S3000pro instead due to room size. I'll let you know my impressions once setup. Coming from KEF is believe this is going to be a totally different sound.
wassup and pjp like this.
jer181 is offline
post #11 of 22 Old 05-07-2019, 04:51 AM
MTVhike's Avatar
Location: North Shore of central Long Island, NY (Stony Brook)
Quoted: 194 Post(s)
Liked: 42
Remember "Wireless speakers" aren't really wireless, because they have to be plugged in somewhere. If you're putting them on your mantle, do you have receptacles there?
MTVhike is offline
post #12 of 22 Old 05-07-2019, 10:54 AM - Thread Starter
jer181's Avatar
Quoted: 125 Post(s)
Liked: 25
Yes, they are going into a built in around a fire place that has deep and large spaced shelving. Power outlets on the bottom shelf (approx. 36" off the floor)
jer181 is offline
post #13 of 22 Old 05-10-2019, 10:30 AM - Thread Starter
jer181's Avatar
Quoted: 125 Post(s)
Liked: 25
So these Edifiers are amazing sounding speakers for the money!!! I was really impressed. In my opinion they even beat the KEF LS50. With the DSP control sound they make every recording sound amazing and really big sound stage with lots of dynamics.
pjp and wassup like this.
jer181 is offline
post #14 of 22 Old 05-10-2019, 11:43 AM
pjp
pjp's Avatar
Quoted: 432 Post(s)
Liked: 301
The Edifiers look amazing, but it looks like (correct me if I'm wrong) they don't have a sub output if you want to add a sub later
wassup likes this.
pjp is offline
post #15 of 22 Old 05-10-2019, 01:17 PM - Thread Starter
jer181's Avatar
Quoted: 125 Post(s)
Liked: 25
They don't have a sub out. Unless you can use RCA out somehow or something like that...
I have them in an open living room that is approx. 18'x16' with the back being open to the kitchen and one of the sides open to a front entry way with 20'+ high ceilings and I don't think you need a sub at all, fills the room nicely.
jer181 is offline
post #16 of 22 Old 05-11-2019, 07:26 AM
Quoted: 96 Post(s)
Liked: 42
get a sub with a high pass and connect to the sub first in the speaker chain...
by the way, i just heard some Edifiers
Edifier R1850DB Active Bookshelf Speakers with Bluetooth and Optical Input - 2.0 Studio Monitor Speaker - Built-in Amplifier with Subwoofer Line Out
these were placed up high in laft space and most of the night I heard the reflected music seated opposite reflecting wall below... very nice
and it got better when seated in front of the speakers, still below the horizontal plane... the speakers were installed on a "plant ledge" in the loft space abot 3 metres high... no sub-woofer... i was impressed
pjp likes this.
wassup is online now
post #17 of 22 Old 05-11-2019, 08:02 AM
pjp
pjp's Avatar
Quoted: 432 Post(s)
Liked: 301
I actually prefer connecting the subs via speaker-level inputs for 2-channel systems, but I don't think it's possible to do that with powered monitors because the amps are internal to the speakers.
The Edifiers look great based upon everything I've seen, just surprised I don't see a way to support a sub (unless I'm still missing something, which is quite possible ).
pjp is offline
post #18 of 22 Old 05-12-2019, 12:03 PM
Quoted: 96 Post(s)
Liked: 42
i should have been a bit clearer. i use the AirPulse A200 monitors... I was referring to line level outputs/subwoofer/monitors
if you have to send the subwoofer juice that is another issue...
i'm no help there mate
post #19 of 22 Old 05-15-2019, 06:43 PM
xpavar's Avatar
Quoted: 38 Post(s)
Liked: 47
You might check out the Peachtree Audio M24 or M25. They include a sub out.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Audio-Parasound Halo Integrated/Cambridge Audio CXNv2/Yamaha BD-A1060/Monitor Audio Silver 300/SVS SB1000/Sennheiser HD600/Shure SRH1540
Video-Sony XBR900E/Sony PS4Pro/Microsoft XBOX One X/Oppo BDP-103/Roku+/Yamaha YAS-107/Emotiva BasX S10
xpavar is offline
post #20 of 22 Old 05-21-2019, 04:20 PM
bluewizard's Avatar
Quoted: 2271 Post(s)
Liked: 1504
Another vote for Edifier -
The R2000DB have 5.25", 2xAux, 1xOptical, 1xCoaxial, Bluetooth, and a Remote control - CA$299/pr -
https://www.edifier.com/ca/en/speake...th-optical-rca
The better 5.5" Edifier S2000 Pro are about CA$500/pr -
https://www.edifier.com/ca/en/speakers/s2000pro
The S2000 Pro have 1xAux, 1xOptical, 1xCoaxial, and Bluetooth, plus as mentioned a remote control.
These are available for the prices shown on AMAZON-CA.
Edifier does make smaller speaker and Satellite speaker with a Sub -
https://www.edifier.com/ca/en/shop?p...eatures_group=[[%22bookshelf%20speakers%22]]
The Forum does not like the square brackets in the web address, so just cut and paste or go directly to Edifier -
If you are very very pressed for space, perhaps something like this would get the job done for you -
Edifier S350DB 2.1 - CA$389/set -
https://www.edifier.com/ca/en/speakers/s350db
Worth at least looking into.
Steve/bluewizard
bluewizard is online now
post #21 of 22 Old 05-21-2019, 04:28 PM
bluewizard's Avatar
Liked: 1504
As to adding a Subwoofer to Edifier, that will depend on the Input. If using the Analog Aux in a couple of "Y"-Cables from the source, send on leg to the SUB and the other to the Edifier Speakers.
Or consider something like the S350DB that already have a Subwoofer.
https://cdn.ventmere.com/edifier-dev..._HJNVHG0Hf.pdf
2xAux, 1xOptical, 1xCoaxial, Bluetooth, Remote Control
In all honestly though, good bookshelf on their own can sound very good in the bass department.
Consider that the S350DB with an 8" Subwoofer is rated down to 40hz, but the S2000-Pro (5.25") is rated down to 48hz. That's not that much difference. The considerably expensive S3000-Pro with a 6.5" bass driver are rated down to 38hz, which is pretty good.
Steve/bluewizard
post #22 of 22 Old 05-23-2019, 09:43 AM
Liked: 3
Check out Vanatoo T1E. I heard them at an audio show. Very impressive.
Tom Fischer is offline
Reply 2-Channel Audio
