phono preamp upgrade? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Jeff Aguilar
post #1 of 8 Old 04-23-2019, 05:44 AM - Thread Starter
rocky1's Avatar
Quoted: 596 Post(s)
Liked: 196
I have a Pro Ject 1expression turntable w/ortofon 2mm blue connected via a Pro ject phono box mm to my Marantz.I'm looking to upgrade the phono preamp to something better. Just feel its time to upgrade the pre amp have had it for awhile and want to try something new within reason. Looking up 250-500. to spend for a new pre amp but don't know enough about them as to sound characteristics etc. Small foot print is best for me.Also like the "warm" sounding characteristics if possible.So looking for opinions as to what to look for a new preamp.thanks
Sony XBR65A1E,(Pioneer 500m relocated), AppleTv 4K,Marantz sr7012, System Audio Loudspeakers( sa1750 mains), ML Grotto.
Eastern Electric Minimax cd, Oppo UDP-203, Toshiba HD, Pro Ject 1expression Carbon TT.
rocky1 is online now
post #2 of 8 Old 04-23-2019, 06:27 AM
Class A's Avatar
Quoted: 817 Post(s)
Liked: 5691
Thumbs up
I think you need to change the cart if you want a more neutral or warmer sound. I had the 2M Blue and it can be rather hot on the top. For carts I'd look at the Nagaoka MP-200, Goldring G 2300 and the Grado Gold 2. Your current phono, which is quite good, can handle any of these MM carts.
Class A is offline
post #3 of 8 Old 04-23-2019, 07:04 AM - Thread Starter
rocky1's Avatar
Quoted: 596 Post(s)
Liked: 196
didn't think of changing the cart.I guess that would be a more advisable upgrade ?
post #4 of 8 Old 04-23-2019, 07:29 AM
Class A's Avatar
Quoted: 817 Post(s)
Liked: 5691
Thumbs up
Years ago when I went from a 2M Blue to a Dynavector 10x5 it was a big improvement. Less surface noise, better bottom end, more detail and soundstage. At the time I had the same Pro-Ject tube phono during the cart change.
Class A is offline
post #5 of 8 Old 04-23-2019, 09:50 AM - Thread Starter
rocky1's Avatar
Quoted: 596 Post(s)
Liked: 196
I suppose I should look into that one aswell . My pre amp is not the tube one more of the budget side of things. Makes me still wonder though between the cartridge upgrade or phono pre amp upgrade which should go first. Best scenario would be both if could be managed.
post #6 of 8 Old 04-23-2019, 10:26 AM
Class A's Avatar
Quoted: 817 Post(s)
Liked: 5691
Thumbs up
If you want to do both. I would say the Nagaoka MP200 w/the Lounge Audio MKIII LCR phono will really upgrade your sound. That would be above the $500 by about $100-$150 but you'll you won't want to upgrade for a long time.
Class A is offline
post #7 of 8 Old 04-23-2019, 01:45 PM
Jeff Aguilar's Avatar
Quoted: 50 Post(s)
Liked: 57
Send a message via Yahoo to Jeff Aguilar
I think going the route of getting a new cart is the way to go before changing out your pre-amp. I have read really good things about the Nagaoka MP200. When I did my last upgrade it was between that cart and the Denon DL-302MKII. I ended up going with the Denon. Changing the cart was a definite upgrade!
Jeff
Muphasta likes this.
Jeff Aguilar is offline
post #8 of 8 Old 04-24-2019, 09:43 AM
commsysman's Avatar
Quoted: 1120 Post(s)
Liked: 584
Look at the Cambridge Audio Duo, for $299.
commsysman is offline
Reply 2-Channel Audio
