AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   2-Channel Audio (https://www.avsforum.com/forum/173-2-channel-audio/)
-   -   Good Quality Analog Cables from DAC to Amp? (https://www.avsforum.com/forum/173-2-channel-audio/3064044-good-quality-analog-cables-dac-amp.html)
scott_francis 04-24-2019 04:03 PM
Starting to get back into the Hi-Fi stereo world. So, I am out of touch a bit. Just recently purchased a Schiit DAC and looking for a good quality brand/model 1mm RCA Analog type to run from the DAC to my integrated amp. Looking in the $50 or under range.
Thanks in advance
Scott
alan0354 04-24-2019 04:25 PM
I don't think RCA cable is that important, I just look at how big the cable, I won't use those come with the DVD players or some other stuffs that is very small in diameter. Just get those that are thicker and it should be good enough.
I myself just buy from Amazon. The complain is the connectors tend to be loose and won't fit tight enough. I have no complain on the sound quality of the cables.
m0j0 04-24-2019 04:30 PM
I like the SVS SoundPath RCA cables.
torii 04-24-2019 04:34 PM
I use these from my laptop to dac to amp. https://www.amazon.com/0-5-Foot-Dire...EW2HDZYPA841CR
I also have wireworld/audioquest/xlo/ethereal/ youname it many rca's....
Russdawg1 04-24-2019 04:51 PM
Mediabridge or Monoprice. Buy nothing that’s more expensive unless you like wasting money.
MTVhike 04-25-2019 05:21 AM
I like bluejeans cable. The only problem with their RCA cables is that the connectors are fairly long (3") and the cables are stiff, so they don't easily bend down from the back of your device(s). Very robust.
DonoMan 04-25-2019 05:47 AM
I see a recommendation above for Monoprice but I disagree majorly. Their actual cable itself works fine, but the connectors are generally very loose to the point where I got a bunch of cables from them and threw them out because they would pop off on their own. The cable itself works but is also very stiff. I think it's worth paying a bit more for something like Blue Jeans Cable or the cheaper Audioquest cables (they have some relatively cheap cables and they also have some pretty expensive ones - don't bother with the pretty expensive ones). Also just about anything using Belden, Canare or Gepco cable should be good. You can check Markertek for some of that stuff.
PioBeer 04-25-2019 07:31 AM
Always wanted to try Tweaker Man's DIY silver ultra high-end interconnects to see if I can hear a difference. Can probably make for under $100
Might be a fun project if you have some time
Graustark 04-25-2019 07:55 PM
Thanks in advance
Scott
And competently made RCA cables are going to sound like any other competently made RCA cables.
Save your money.
alan0354 04-25-2019 08:13 PM
It's really not that critical, just don't use those that comes with the devices which are very thin. Just get any thicker coax type and it's good enough. Just make sure the connectors fit tight and won't fell off.
The more important thing is DO NOT get cable longer than is needed. This is very important if you worry about cable capacitance, loss and all that.(not that I think it's that important) I use a lot of the 18" cables if they can reach.
For example, the best cable is say 15pF/ft. The worst cable is 40pF/ft. If you use 18" of the worst cable, it will be 60pF of capacitance total. By comparing to 6ft of the best of the best cable, it's 6 X 15pF = 75pF total. so an 18" bad cable has lower capacitance than the best and most expensive 6ft cable. This is the same as resistance, inductance and everything else. Keep it reasonably short and don't worry about it.
Don't listen to people that claim what metal the cable is made of and all, it doesn't matter. Input impedance of preamp and power amps are very high, you don't worry about needing a lot of drive. Most modern devices ( DAC, preamps etc.) have very low output impedance, a little capacitance, inductance etc. will not affect the sound. These preamp low level signal is nothing like speaker cables that has to drive down to 2ohm load where inductance becomes importance. It's NOT that critical.
Tom Fischer 05-23-2019 09:53 AM
Check out Signal Cables Silver Resolution.
Muphasta 05-23-2019 10:06 AM
I've had fantastic luck with Monoprice cables. I've never had any pop off on their own. In fact, I've found the connector to be quite tight.
If you want to get fancy, get two of these: (sold individually so you may want to get some colored tape to differentiate each end)
https://www.monoprice.com/product?p_id=18534
Those ship free. Remember, you'll need two.
But I've used these and they are great:
https://www.monoprice.com/product?p_id=5346
I made a pair of these and they are somewhere in-between the above two options, again, you'll need two:
https://www.monoprice.com/product?p_id=21679
Russdawg1 05-23-2019 10:21 AM
Starting at $289 for a pair of 6ft speaker cables?
No thanks.
_tk 05-23-2019 10:34 AM
Amazon Basics will do everything you need them to do. Great cables for the money.
Tex_Thai 05-23-2019 10:46 AM
^^^^^^^^^^ Russdawg1, that was a completely trash comment and totally off base!!!!!
Tom Fischer recommended some VERY good interconnect cables to the OP, Signal Cables Silver Resolution are excellent interconnects, and they start at $79 a pair you were WAY OFF sir!!!!!!!
Frank over at Signal Cables is an excellent resource and can help whomever contacts him, is not selling snake oil, but good quality products.
When someone recommends his product to another, even if it is not your cup of tea, you should be kind enough to get your facts right.
And NOT trash some one's business erroneously.
Be FAIR.
Nobody mentioned looking for 6 ft interconnects anyway (which are $159 a pair).
I am very happy with my Signal Cables, Silver Resolution cables are highly recommended, I second what Mr. Fischer said!!!!!
God Bless,
Wayne
Muphasta 05-23-2019 11:57 AM
Be FAIR.
God Bless,
Wayne
If someone is asking for good cables under $50, it is ridiculous to suggest something 3x more expensive. The suggestion doesn't belong in this thread at all.
Where was the product trashed BTW? All I saw was someone say, "No Thanks".
CharlesJ 05-23-2019 12:08 PM
Be FAIR.
God Bless,
Wayne
Well, he gave price for a 6 ft pair of speaker cables at $289 and not interconnect RCA cables that starts at $79 for 2 ft, on sale it seems, and $20 per foot for longer cables.
OP was looking for cables less than $50, I believe.
I am glad you like your silver cables.
But there is no good reason to buy silver wired cables and other good cables were recommended, right.
eljaycanuck 05-23-2019 12:18 PM
Originally Posted by Muphasta
I've had fantastic luck with Monoprice cables. …
Same here. I have a bunch of them and I've had no issues with any of them. :)
Russdawg1 05-23-2019 12:43 PM
Be FAIR.
God Bless,
Wayne
Glad you are happy with your overpriced cable.
Not once did I say they are trash.
If you think they are worth it, then have at it.
I said I would not like to purchase a pair of 6ft speaker cable for $289. Note how I said speaker cable. I read the website. The RCA cables are also overprice too while we’re at it.
There’s no reason for cable to cost this much.
So why don’t you be FAIR and respect my choice of not wanting to grossly overspend on a product that doesn’t provide any audible difference in sound.
Alex F. 05-23-2019 01:11 PM
A 1 mm cable is a bit short, only 0.039 inches. How about 1 meter instead?
AudioQuest offers high-quality interconnects at reasonable prices. A 1-meter Tower is $29.95 with free shipping at Amazon.
scott_francis 05-23-2019 01:47 PM
Duly noted on the length :) and yes I agree the more research I have done the more I think AudioQuest provides entry into the higher quality interconnects without breaking the bank.
Scott
m. zillch 05-23-2019 06:37 PM
I'm a critical listener and performance is very important to me, so I use these because they are audibly indistinguishable from the best.
alan0354 05-23-2019 07:55 PM
That's even too cheap for El Cheapo like me. I say I'll go with Amazon express for those $7 a pair type. That's what I use, many of them. Only complain is the connector can get loose(cheap).
m. zillch 05-23-2019 08:21 PM
I also use a $1 HDMI cord I bought at The Dollar Tree Store, not that I needed one, but I wanted to be able to say I use $1 cords, both analog and digital.
Both are flawless.
2WheelsWillTravel 05-23-2019 09:02 PM
RCA cables that start at $79? There's a word for that, "Oniomania"
My most recent set of RCA cables purchased were I think RocketFish brand found on clearance at Best Buy for like $8. I don't see any logical reason to go any fancier than what you can get from KabelDirekt or similar.
alan0354 05-23-2019 09:52 PM
Both are flawless.
Hey, at least my Amazon express have some fake gold connectors and fatter cables. That's can fool people to think it's more expensive!!!
CharlesJ 05-23-2019 10:13 PM
Fake gold? You don't think it might be 10k and at a few microns thick? ;)
Yes, fooling people is good. :D
CharlesJ 05-23-2019 10:15 PM
Originally Posted by alan0354 (Post 58091446)
.... Only complain is the connector can get loose(cheap).
Then stop playing with it. Just leave it alone. ;) :D
emcdade 05-23-2019 10:31 PM
I use Straightwire Expressivo interconnects from DAC to Pre and also from Pre to amps. They are great, much better than the Canare and SVS ones I had on hand.
https://www.thecableco.com/cables/in...nect-pair.html
m. zillch 05-23-2019 11:07 PM
In my use they last for years and years without issue. They also have a lifetime warranty, by the way.
I like Amazon/Mediabridge too.
P.S. The Monoprice RCAs are nickel plated which is actually superior to thin layers of gold plating because it is a harder metal hence less prone to scraping off, plus it is nearly as good in terms of not oxidizing.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
