dual 506 turntable-headshell adapter question? - AVS Forum | Home Theater Discussions And Reviews
Old 04-30-2019, 06:39 PM - Thread Starter
Quoted: 34 Post(s)
I inherited a dual 506 turntable from a friend who passed away. unfortunately the original dual headshell adapter literally fell apart on me. i found a replacement after market one on ebay (there were two companies in california offering them 269-611). Im not sure if i can post their names, but they are relatively cheap but by the time i add exchange, shipping, duties and taxes (im canadian) its starting to add up. Has anyone used one? did it work well? for sentimental reasons i would love to put the table back into use.
pgscubadiver is offline
Old 04-30-2019, 09:05 PM
m. zillch's Avatar
Quoted: 4672 Post(s)
Liked: 3470
I don't have a direct answer but often when it comes to turntables, TT, the easiest way to get some specific part is to buy an entire TT used on ebay, etc., that has some major defect like a scratched or cracked dust cover. Nobody wants a TT with a cracked dust cover, yuck, so the people who unload them for parts on ebay, etc, are forced to sell them for really cheap prices. They are often listed as "As-is". There is also often some degree of crossover of interchangeable parts. So even if you can't find the exact model, you may find a model 505, 504, 507, etc., that's just as good for what you want, but of coarse I make no promises.
m. zillch is offline
Old 05-01-2019, 12:40 PM
Alex F.'s Avatar
Quoted: 870 Post(s)
Liked: 468
I owned three different Dual turntables in the 1970s and 1980s. The metal contacts in the headshells were fragile and would bend or snap off easily despite being handled gently. A slight bend would result in hum. Dual's headshells could drive one nuts.
There are several sellers of Dual parts on eBay. Possibly one of the California eBay dealers you referred to is Pat's Audio Parts (links below). He seems to be a good resource for Dual parts and repairs, offering what he says is a more robust 269-611 headshell for $30 (U.S.). He even has a mounted and aligned Audio-Technica AT95E phono cartridge on that headshell for $80 (U.S.) should you be interested. I do not know the final cost for delivery to Canada.
https://www.patsaudioparts.com/singl...th-ULM-tonearm
https://www.ebay.com/itm/292479866396
Music room: Cary SLI-80 tube integrated amplifier, McIntosh MA6500 integrated amplifier, Quad 99 preamp, Quad 909 power amp, Acoustic Research AR9 loudspeakers, Yamaha CD-N500 CD player, Teac UD-503 DSD DAC, Phase Linear 8000II linear-tracking turntable.
Theater room: Panasonic 65S60 plasma television; Yamaha RX-A2020 (preamp section); Adcom GFA-5503 and GFA-5400 amplifiers; Polk LSi25, LSiC, and LSiF/X loudspeaker system; Velodyne FSR-18 servo-subwoofer.
Alex F. is offline
Old 05-01-2019, 04:52 PM - Thread Starter
Quoted: 34 Post(s)
Thankyou, you nailed it. thats exactly the one i was looking at. Im hoping someone has tried this and can comment on it.
Old 05-01-2019, 06:01 PM
Alex F.'s Avatar
Quoted: 870 Post(s)
Liked: 468
Consider searching and/or posting on these forums:
https://www.audioasylum.com/audio/vinyl/bbs.html
https://audiokarma.org/forums/index....turntables.28/
https://www.vinylengine.com/turntabl...a02741aa55826e
https://forums.stevehoffman.tv/forums/audio-hardware.5/
Alex F. is offline
