Help Me Bundle An Entry Audiophile Turntable Stereo System - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By D.Bailey
post #1 of 17 Old 05-14-2019, 06:51 PM - Thread Starter
Liked: 1
Hello everyone,
I was asked by my father to help him select a turntable and pair of stereo speakers so that he can listen to his classical music from the Franklin Mint collection. I don't have a clue what separates a great sounding entry level audiophile turntable from an average sounding (and featured) record player, other than price. I have never owned a turntable but my parents used to own a Dual I think many years ago. That turntable was automatic I believe.
I asked my father about the budget range and he's OK if the turntable costs around $1,500 or less. In the past my parents have spent lots on audio gear, but they are at an age now where sound quality from very high end gear wouldn't swing their decisions. I think the sounds to their ears would be pretty much the same.
This is what I am thinking regarding turntable, not in any ranked order of importance:
1. Nice to have a USB port to record the music in digital format (more on that below)
2. Turntable cover with hinges that bring the cover down slowly
3. A light that helps guide the placement of phono needle on the record medium if manual
4. Manual vs auto vs semi-auto turntable. My father was thinking about a full automatic, but I told him that most (all?) high end turntables within his budget are full manual. He's OK with that.
5. Pre-amp: built-in would be best I think. If not built-in, what external pre-amp would you recommend?
Regarding USB on turntables. Is it worth having this feature? How do you digitally record your prized record collections? Or do you? What software works with Mac and or Windows computers? I personally prefer Mac.
So far, I plan to recommend perhaps the Audioengine HD6 powered speakers for my parents. It has wireless bluetooth, includes a remote, and some nice input options. I might reconsider for a smaller footprint. They have limited space to place a turntable, possibly an external pre-amp, and stereo speakers. I think my father will play his records somewhat loudly.
Where I am there's no place I know of locally to demo a nice turntable or listen to audiophile powered bookshelf speakers. We would have to drive out of state for that.
Thanks in advance for your inputs,
David Bailey
D.Bailey is offline
post #2 of 17 Old 05-15-2019, 09:58 AM
bing!'s Avatar
Quoted: 292 Post(s)
Liked: 218
The Rega Planar 3 with cartridge is an awesome turntable and can be had for under $ 1200. I would not call it entry level. I would call it middle range, slightly on the better side of things.
https://www.musicdirect.com/top-rate...p3-aregattp3be
This is awesome and may actually equal the Planar 3 - https://www.musicdirect.com/turntabl...-588-Turntable
"brilliance is not knowing all the answers. it's about asking the right questions."
bing! is offline
post #3 of 17 Old 05-15-2019, 10:51 AM - Thread Starter
Liked: 1
Thanks Bing! I will need to do some research on this Rega P3. Does it require an external phono pre-amp?
David
D.Bailey is offline
post #4 of 17 Old 05-15-2019, 11:05 AM
bing!'s Avatar
Quoted: 292 Post(s)
Liked: 218
David
If youre using an amp or preamp with phono input, and you pick a magnetic cartridge with the TT, no. If you pick a moving coil cart, normally, you will need one that does moving coil. Unfortunately, none of the above has a USB. You won't find USB on the mid to higher end TTs. If you go lower, there are a bunch like Project and stuff.
bing! is offline
post #5 of 17 Old 05-15-2019, 11:08 AM
bing!'s Avatar
Quoted: 292 Post(s)
Liked: 218
high end, I would look not much further than the VPI Scout, but its out of budget.
something to think about, moving coil cartridges are awesome, but low output MCs need ancillary equipment which raises the cost immensely. you'll want a high end TT with it, then an MC phono pre, and then the TT project goes from 1K to 3-4K
bing! is offline
post #6 of 17 Old 05-16-2019, 05:06 AM
Quoted: 456 Post(s)
Liked: 321
If a receiver or pre amplifier doesn’t have a built in phono stage you still need one with a MM cartridge.
MSchott is offline
post #7 of 17 Old 05-16-2019, 10:18 AM
pjp
pjp's Avatar
Quoted: 362 Post(s)
Liked: 255
Is the $1500 just for the turntable or for the whole system? If it's for the turntable only, it would be better to provide a budget for the whole system to allow recommendations on turntable, cartridge, phono preamp (if required), and amp/speakers (or to include the cost of Audioengine HD6 if that is already written in stone) within the total budget.
pjp is offline
post #8 of 17 Old 05-16-2019, 10:42 AM
pjp
pjp's Avatar
Quoted: 362 Post(s)
Liked: 255
Might be worth looking at Edifiers alongside the Audioengine based upon this thread:
https://www.avsforum.com/forum/173-2...l#post58054138
Different models -- but interesting comparison in the youtube below -- no clear overall winner in my mind because which one sounded best was very dependent on the material (overall, Edifiers go deeper, but Audioengine sounded cleaner and more transparent on some tracks) ->
pjp is offline
post #9 of 17 Old 05-16-2019, 03:29 PM - Thread Starter
Liked: 1
It's for the turntable. Thanks.
David
D.Bailey is offline
post #10 of 17 Old 05-16-2019, 03:44 PM
_tk
Quoted: 381 Post(s)
Liked: 149
$1500 turntable is not what I'd call "entry level". When I clicked in the thread I was thinking $150 - $300 or so.
$1500 will get you a really nice unit.
_tk is offline
post #11 of 17 Old 05-16-2019, 05:05 PM - Thread Starter
Liked: 1
Thanks PJP for the suggestion regarding the Edifier speakers. I'm guessing either brand will do; I have a HD3 on my desk for my computers and they do sound great for the speaker size. I think the HD3 is a bit over-priced for what you get, however. I will need to read the thread about the audioengine and edifier system comparisons.
David
D.Bailey is offline
post #12 of 17 Old 05-16-2019, 05:08 PM - Thread Starter
Liked: 1
Ok. I figured a turntable in the $3K - $6K range would be high-end? I've found with google search some specialized TT costing much more that that range!
David
D.Bailey is offline
post #13 of 17 Old 05-16-2019, 05:25 PM
_tk
Quoted: 381 Post(s)
Liked: 149
David
Well yeah, there are the ridiculously priced units (as it is with this hobby), but a $1500 turntable is nothing to scoff at.
If you're just hooking it to a pair of powered speakers (like the mentioned Audioengine HD6), you probably would not be able to tell the difference between a $1500 unit and a $3000 unit.
Even with the nicer and more expensive powered KEF's or new Elac Navis...with some records maybe you'd notice a difference...maybe not.
_tk is offline
post #14 of 17 Old 05-16-2019, 07:47 PM
Quoted: 456 Post(s)
Liked: 321
David
For the huge majority of non wealthy audiophiles such turntables ARE high end. More expensive tables are better but given the same cartridge and phono stage the difference is slight. Better tracking due to better tone arms and quieter backgrounds are the main differences. You really need higher end components, especially speakers to reap full results.
Based on my system with a $2200.00 retail turntable, a better cartridge would be my first upgrade as opposed to the same cartridge and a better table.
MSchott is offline
post #15 of 17 Old 05-17-2019, 07:42 AM
pjp
pjp's Avatar
Quoted: 362 Post(s)
Liked: 255
I feel that "$1500 for a turntable" isn't anywhere close to being enough information for anyone to provide suggestions that are useful. You will need some or all of the following:
1. A turntable <- is $1500 inclusive of cartridge?
2. A cartridge <- which cartridge you can use (moving coil or moving magnet) will depend on which phono preamp, or which amp, you choose
3. A phono Preamp <- which phono preamps work is dependent on whether you choose MM or MC cartridge, whether you will need a phono preamp at all is dependent upon which amp you choose
4. An amp or powered speakers <- the amp determines whether or not you need a phono preamp (if the amp has one) and, if it does, it also determines which cartridges will work
If you want useful suggestions, specify what is decided (for example the audioengine speakers or a list of possibilities) and then provide an overall budget for all of the remaining components. Then experts can suggest the mix of components that actually works together and that is optimal within your overall budget.
Asking for $1500 turntable suggestions in a vacuum about everything else is an impossible question to answer and will not yield you useful information since you still need to fill out the rest. The far more important thing than "spending $1500 on a turntable" is to get the overall budget and then you can get suggestions about the best allocation of specific components across turntable, cartridge, and preamp investments to get you the best solution for what you want to spend overall.
pjp is offline
post #16 of 17 Old 05-17-2019, 09:02 AM - Thread Starter
Liked: 1
Point taken PJP. I need suggestions for turntable, pre-amp, and cartridge all within the total budget of $1,500 or less. The speakers are additional. Some TT have the pre-amp built in; but my guess is that the nice ones do not. I do want the cartridge included with the TT, with the option to upgrade in the future. Magnet or coil I have no idea and therefore no preference. I am not into TT, hence the reason I have posted here.
My parents will need to make a final decision on speakers because of space limitation. I am recommending the HD6 from
Hope this helps.
David
pjp likes this.
D.Bailey is offline
post #17 of 17 Old 05-17-2019, 09:48 AM
pjp
pjp's Avatar
Quoted: 362 Post(s)
Liked: 255
Hope this helps.
David
That helps a lot. The HD6's do not have a phono input, so your $1500 needs to cover turntable, cartridge, and phono preamp (somewhere -- whether external or internal).
pjp is offline
Reply 2-Channel Audio
