Can be sound of Chromecast Audio improved with external DAC - AVS Forum | Home Theater Discussions And Reviews
 71Likes
post #1 of 273 Old 05-30-2019, 03:22 PM - Thread Starter
RAART's Avatar
Quoted: 62 Post(s)
Liked: 37
Question Can be sound of Chromecast Audio improved with external DAC
Hello folks,
I am thinking to get external DAC for one of my Chromecast audio devices and wondering if sound of CCA can be dramatically improved with an external DAC?
Here are some points I like to get your insight:
  • what DAC you will use
  • how much improvement specific DAC will bring
  • don't want spend a fortune on a DAC for CCA
  • if higher priced DAC are more recommended than no more than 250$ used value
I did some research on the web and found a quite some contenders but like to hear also your opinion.
RAART is offline
post #2 of 273 Old 05-30-2019, 10:52 PM
GIEGAR's Avatar
Quoted: 984 Post(s)
Liked: 1675
No.
Well... maybe if you're peeking. See below.
https://www.tomshardware.com/reviews...o,3733-19.html
https://translate.google.com/transla...tm&prev=search
m. zillch and SmittyJS like this.
GIEGAR is online now
post #3 of 273 Old 05-31-2019, 03:34 AM
IIDexII's Avatar
Quoted: 159 Post(s)
Liked: 201
Hello folks,
I think there is possibilities what about trying Schiiit?
American made, has optical, recommended, cheap but good quality.
https://www.schiit.com/products/modi-1
If you want a more expensive Dac, I would also recommend a better streamer, blusound, or a Japaneese, etc
IIDexII is online now
post #4 of 273 Old 05-31-2019, 03:50 AM - Thread Starter
RAART's Avatar
Quoted: 62 Post(s)
Liked: 37
So far I was looking into following ones:
Topping D30
Schiit Modi 3
JDSLab EL DAC
JDSLab OL DAC with optical input
Topping D50
Cambridge Audio DAC Magic 100
Audio Engine D1
and many more... but didn't get any wiser!
Just remember it needs to have optical input.
Edit: forget to look but just remembered that I like to have DSD playback, if possible...
RAART is offline
post #5 of 273 Old 05-31-2019, 05:59 AM
IIDexII's Avatar
Quoted: 159 Post(s)
Liked: 201
Topping D30
Schiit Modi 3
JDSLab EL DAC
Topping D50
Audio Engine D1
DSD from Chromecast? How sent as pcm? I didn't know Chromecast did pcm
post #6 of 273 Old 05-31-2019, 06:14 AM - Thread Starter
RAART's Avatar
Quoted: 62 Post(s)
Liked: 37
As far as I know the Chromecast internal DAC is AKM AK4430 192kHz 24-Bit Stereo DAC.
RAART is offline
post #7 of 273 Old 05-31-2019, 06:33 AM
highmr's Avatar
Quoted: 94 Post(s)
Liked: 56
As you know, you need a mini Toslink cable to replace the 3.5 mm audio cable.
I am not sure about getting DSD out to an external DAC.
I have a CCA and what I tested was streaming a DSD file and a 96 kHz hi resolution file to the CCA. That was using Plex and casting. The CCA is connected to a Denon X4200W. The 96 kHz file shows up as 96 kHz on the Denon input screen. The DSD shows up as 48 kHz, because somewhere in the chain, the file had to be converted to PCM. I am not positive if this is a Plex or CCA limitation. Is DSD even possible over a digital (not HDMI) connection?
RAART likes this.
Living room: Samsung PN60F8500, Sony X800M2, Roku Premiere+, Revel W763, Revel M16, Hsu HB-1 MK2, RSL C34E, Rhythmik D15SE, Denon X4200W; Zone 2: Speaker selector, Yamaha RX-V495 (1999); Bedroom: Panasonic P50U54, Oppo BDP-80, Chromecast Audio, Advent Legacy III (1994), Denon 2310ci; Cabin: Roku 3, NHT Super Zero (1996), Hsu VTF-2 MK4, Denon 1712
highmr is offline
post #8 of 273 Old 05-31-2019, 08:35 AM - Thread Starter
RAART's Avatar
Quoted: 62 Post(s)
Liked: 37
I ordered already mini Toslink cable but didn't get the DAC while I am still debating...
So far I can tell that CCA plays all my FLAC and PCM files but does not play DSD. All files are streamed straight from my PC (Solus OS Linux) with VLC player. I did not set any server yet while files are easily played from folders where I have them with VLC, also from external drives.
Did not get Audacious to work, though the PC settings see all players on my network:
Chromecast Audio
Chromecast (also round, not sure about generation)
Yamaha WXA-50
Funny thing is that Yamaha (from USB stick) does play DSD files but does not output them to AUX out. All other files it does output to AUX out (analog). Do not get it why...
RAART is offline
post #9 of 273 Old 05-31-2019, 09:36 AM
IIDexII's Avatar
Quoted: 159 Post(s)
Liked: 201
Chromecast Audio
Yamaha WXA-50
DSD is complicated, what do you send? Stereo? 5.1?
I know I can send DSD stereo and 5.1 via Hdmi, I can send "lossy" DTS via coax and Optical...
Im not sure but think I've played DSD via digital without hdmi only stereo but not Shure what I get out..
post #10 of 273 Old 05-31-2019, 09:41 AM
IIDexII's Avatar
Quoted: 159 Post(s)
Liked: 201
Chromecast Audio
Yamaha WXA-50
Chromecast is meant for streaming Spotify and maybe some flacs in stereo.
If you want something more advanced, I would look into an affordable good quality streamer.
RAART likes this.
post #11 of 273 Old 05-31-2019, 09:49 AM
plasma_fan's Avatar
Quoted: 82 Post(s)
Liked: 104
What is your issue with the CCA's sound quality?
FWIW, I run mine through a Cambridge Audio DAC, have also run it though a schiit modi multibit, and my receiver, with no apparent sound quality differences.
plasma_fan is offline
post #12 of 273 Old 05-31-2019, 10:49 AM
m. zillch's Avatar
Quoted: 4671 Post(s)
Liked: 3470
No.
RAART and Graustark like this.
m. zillch is offline
post #13 of 273 Old 05-31-2019, 10:58 AM
_tk
Quoted: 434 Post(s)
Liked: 174
Dramatically? No.
Somewhat? Yes.
The DAC in the chromecast audio isn't horrible. Unless you have a really resolving system and can stream very high quality files, I doubt you'll notice a lot of difference. But, there are certain times that it may be "handy" to have the CCA go into a DAC/external transport/Integrated Amp of some sort.
RAART likes this.
_tk is offline
post #14 of 273 Old 05-31-2019, 11:19 AM
IIDexII's Avatar
Quoted: 159 Post(s)
Liked: 201
I didnt say I have issues with it, just that it has certain limits, I'm happy that CCA exist because it makes streaming music Spotify and flacs cheap... Hell I use a 49$ MxQ plus whatever to play Tidal and YouTube music.. but I already have an old Dac in my Avr pre.
post #15 of 273 Old 05-31-2019, 11:41 AM
m. zillch's Avatar
Liked: 3470
It is possible using an outboard DAC will make the sound inferior and here's why.
The unit itself has a very capable DAC built in and it can directly convert every single digital format it is designed to encounter and convert it to analog, music. Done.
If using the Toslink digital out the incoming signal can again be anything under the sun which it is designed for however the Chromecast device will then have to CONVERT it to a digital signal which Toslink can then carry such as S/PDIF PCM. The signal now travels to the outboard DAC and gets converted to analog.
Here's an example . Using an incoming Hi-Res signal such as 24-bit/96 kHz you then have to downgrade the signal, because Toslink can't carry it, to say SD [standard resolution] 16-bit/44 or 48 kHz PCM. So rather than taking the best signal possible and converting it to analog directly with a AKM AK4430 DAC, instead there is a [potential] loss of quality because of:
A. - the conversion process from one digital format to another
B. - the forced use of a lower resolution format to transfer the signal via optical.
C. - an outboard DAC with inferior performance to an AKM AK4430 DAC, true of many even very expensive outboard DACs because they are long in the tooth [more than a few years old]
It's a shame the internet worries so much about digital stuff when it hardly matters. What matters is the speakers used, their position and aiming, and the room.
post #16 of 273 Old 05-31-2019, 01:35 PM
_tk
Quoted: 434 Post(s)
Liked: 174
Here OP, this thread is pretty factual (rather than the speculation going on in here):
https://www.audiosciencereview.com/f...l-output.4544/
pjp, DanPackMan, natchie and 1 others like this.
_tk is offline
post #17 of 273 Old 05-31-2019, 01:57 PM
m. zillch's Avatar
Liked: 3470
Jitter in modern day DACs is inaudible but boy does it make for a great way to scaremonger: "Look everyone! This number is much bigger than this other number! Be afraid!"
post #18 of 273 Old 05-31-2019, 02:09 PM
Ratman's Avatar
Quoted: 2145 Post(s)
Liked: 1998
Prices for nonsensical DAC's and overpriced cables to provide audio perfection gives me the jitters.
It's beyond me how one has a DAC in device A, a DAC in device B, but uses neither because the internet/forums/marketeers profess that the of DAC C device will "lift the veil".
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #19 of 273 Old 05-31-2019, 02:37 PM
IIDexII's Avatar
Quoted: 159 Post(s)
Liked: 201
Playing DSD now, 5.1 Trondheimsolistene Mozart Sacd.
RAART likes this.
post #20 of 273 Old 05-31-2019, 03:11 PM - Thread Starter
RAART's Avatar
Quoted: 62 Post(s)
Liked: 37
I just wanted to stream hi-rez files from my PC to my audio system and therefore while I have CCA thought it would be nice to use it as bridge, but... this brought another issue as CCA does not want to play DSD files I have on my PC, mainly superaudio cd stuff that I have collected. I thought that external DAC with DSD ability will help but not sure now. Also I thought that external DAC will improve sonic abilities of CCA at some point and this has been proven to be correct in other thread (linked above in the discussion). Not much but some improvement.
Also it looks like that DSD SACD are playing on CCA now, thanks to IIDexII...
I just hesitating to pull the trigger on NAD DAC 2 Wireless just for the PC and leave CCA for Spotify only. BTW I never said or complain about sound quality of CCA. I always praised the sound of it on its own but there is something in me that wants me to experiment and see if I can get a bit better sound of it. Always open-minded and ready to experiment!
BTW Currently the NAD DAC is 99$ here in Canada and it is sold by NAD through Amazon. I guess there is advantage as NAD being Canadian company.
RAART is offline
post #21 of 273 Old 05-31-2019, 03:35 PM - Thread Starter
RAART's Avatar
Quoted: 62 Post(s)
Liked: 37
I just bought NAD DAC 2 Wireless... next weekend should be here, even is just on the other side of Toronto but I opted for free shipping.
RAART is offline
post #22 of 273 Old 05-31-2019, 03:41 PM
IIDexII's Avatar
Quoted: 159 Post(s)
Liked: 201
I love NAD, has a NAD BEE cd player as we speak. The last one before the great Norwegian bjørn died....
Has enjoyed it max today......
Nad makes great good quality hifi gear, PSB speakers is in theyr Canadian gear also. Wish I had money to buy their Nad Viso bt headphones but as many times before I missed the sale.
The Bluesound series node Streamer is in fact also owned/made by Nad.
post #23 of 273 Old 05-31-2019, 03:50 PM - Thread Starter
RAART's Avatar
Quoted: 62 Post(s)
Liked: 37
In a fact I am listening to PSB speakers (GB1, same drivers as their reference series at that point) on Rotel gear but still like NAD as I had them before... NAD gear with KEF speakers was for long time my favorite listening gear.
PSB purchased NAD some years back.
Did not know that Bluesound is also owned by NAD.
EDIT: I really like NAD C 658...
RAART is offline
post #24 of 273 Old 06-01-2019, 04:33 AM
IIDexII's Avatar
Quoted: 159 Post(s)
Liked: 201
All is owned by Ledbrook. It's easy to see in theyr products.. for example Nad headphones and PSB headphones is very similar built... The Bluesound node comes with update modules a typical NAD functionality....
post #25 of 273 Old 06-01-2019, 06:02 AM
Class A's Avatar
Quoted: 699 Post(s)
Liked: 4257
Thumbs up
I purchased the RME ADI2 DAC about a year ago. Very pleased w/the unit. Also is a headphone amp which allows for either IEM's or standard headphones. Lots of features that fine tune your sound.
Class A is offline
post #26 of 273 Old 06-01-2019, 06:04 AM - Thread Starter
RAART's Avatar
Quoted: 62 Post(s)
Liked: 37
I did not paid attention in recent hifi world acquisitions but it is correct what you said. PSB speakers partnered with Lenbrook in 1985 and since then they are one company....
RAART is offline
post #27 of 273 Old 06-01-2019, 06:12 AM - Thread Starter
RAART's Avatar
Quoted: 62 Post(s)
Liked: 37
Thumbs up
Originally Posted by Class A View Post
I purchased the RME ADI2 DAC about a year ago. Very pleased w/the unit. Also is a headphone amp which allows for either IEM's or standard headphones. Lots of features th fine tune your sound.
I did not have pleasure of listening to that brand, but since I will go back to Europe for a vacation I may look into... it looks like very nice unit and since I own back home T+A Elektroakustik pre-amp with power amp and speakers I will need to add to my trusty Marantz CD 16 an external DAC and that might be a solution if I do not go again with T+A...
Thanks for turning my attention to that brand.
EDIT: I just have read some amazing reviews about that unit (mostly in German language) and I am very intrigued now!
Class A likes this.
RAART is offline
post #28 of 273 Old 06-02-2019, 12:25 AM
openwheelracing's Avatar
Liked: 37
Schiit Modi 3 is what I ended up with. Way better than the onboard DAC in Chromecast Audio.
Sent from my Pixel 3 using Tapatalk
IIDexII likes this.
openwheelracing is offline
post #29 of 273 Old 06-02-2019, 04:53 AM
highmr's Avatar
Quoted: 94 Post(s)
Liked: 56
The comment in that post was that a DSD file was playing, but not necessarily getting to the external DAC as DSD? My test file was playing but was converted to PCM.
My previous comment about a 96 kHz file was for a 24 bit / 96 kHz file. However, the incoming signal to the receiver was displayed as simply 96 kHz and doesn't prove it was not downgraded. I did a Google search and it appears that 96/24 is normally achievable but higher is not. Depends also on the optical transmitter and optical receiver, not just the cable.
RAART likes this.
highmr is offline
post #30 of 273 Old 06-02-2019, 08:24 AM
ChromeJob's Avatar
Quoted: 1988 Post(s)
Liked: 1054
If you use the CCA’s analog audio out, you can enable higher quality audio (an option in the Google Home app), but if you plug a Mini-TOSlink cable in, the CCA defaults to this option. I don’t know about the quality of the DAC in the $25 CCA, but perhaps your AVR’s DAC is “better.” Of course, if you stream a service for free that limits the audio resolution it will make little difference. Some only offer high bandwidth audio if you subscribe.
pjp likes this.
"Sell crazy some place else -- we're all stocked up here."
Are you new to the forum? Please read forum FAQs and stickies. Like posts that help you. RTFM, always.
A: Yamaha RX-V775; Chromecast Audio; iPod Classic, Touch. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen, Samsung UN40ES6150.
ChromeJob is online now
Reply 2-Channel Audio
