First monitor PC purchase 2.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-11-2019, 03:31 AM - Thread Starter
hyg71886's Avatar
Quoted: 53 Post(s)
I listen to alot of music, movies, and games from my desktop. I am looking for a nice set of speakers and possible sub for my gaming desktop. I was looking at the Klipsch r-15pm but wasn't sure if there is something better out there for about the same price. Sub I'm not sure about. I am open to suggestions for the system. For reference I have all Klipsch r speakers in my theater room with a 15in powernsound sub. I'd like to stay well under 1k if possible but am willing to bend for a good deal.
hyg71886 is offline
post #2 of 12 Old 06-11-2019, 06:02 AM
Transmaniacon's Avatar
Quoted: 1788 Post(s)
Liked: 1629
I’d go for something like this:
Topping D30 DAC > SVS SB-2000 > JBL 305P Mk. II
The SVS sub has a 80Hz high pass filter so you can integrate your bookshelves easily without dedicated bass management. It’s compact and will work great in nearfield for your needs.
The JBLs are very accurate and the top performer in their price range, you’d have to step up a good bit in price to find something better.
The Topping DAC is a great value option, it measures well and will do everything you need.
5.1: Samsung PN60F5300 | Sony BDP-S1700 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
2.0: Oppo DV-980H | Apple Airport Express | Topping D30 | Parasound HCA-1500a | Chane A1.4
Transmaniacon is offline
post #3 of 12 Old 06-11-2019, 10:03 AM - Thread Starter
hyg71886's Avatar
Quoted: 53 Post(s)
I looked at those but I'd prefer if they were Bluetooth capable as well
hyg71886 is offline
post #4 of 12 Old 06-11-2019, 10:08 AM
Liked: 1629
I assume this is going to be hooked up to a computer? What do you foresee needing Bluetooth for? It’s a poor source of audio in terms of quality, I’d try and avoid that.
post #5 of 12 Old 06-11-2019, 10:29 AM - Thread Starter
hyg71886's Avatar
Quoted: 53 Post(s)
The Klipsch had multiple hook up option which I liked, but I'm also on a deployment so it's getting used where I'm at and then coming back home. Normally it'll be hooked up to probably my laptop or tv but I wanted to have options. Mainly it'll be music, movies, gaming.
hyg71886 is offline
post #6 of 12 Old 06-11-2019, 10:32 AM
Liked: 1629
You can always pick up a Chromecast Audio to add WiFi streaming to any stereo. They are discontinued now but still available.
post #7 of 12 Old 06-11-2019, 01:50 PM - Thread Starter
hyg71886's Avatar
Quoted: 53 Post(s)
How is the bass reproduction on the monitors you listed? My only experience with monitors was some by m audio
hyg71886 is offline
post #8 of 12 Old 06-11-2019, 03:10 PM
Liked: 1629
The bass is adequate for their size, but you’d have a very good SVS SB-2000 handling the low end.
post #9 of 12 Old 06-11-2019, 04:06 PM - Thread Starter
hyg71886's Avatar
Quoted: 53 Post(s)
Ya I'm just worried about the weight and size
hyg71886 is offline
post #10 of 12 Old 06-11-2019, 08:58 PM
Liked: 1629
If you want adequate bass, you will have to go with a sub. The SB-2000 is about as compact as it gets, it’s basically a 15” cube.
post #11 of 12 Old 06-12-2019, 02:54 AM
glangford's Avatar
Quoted: 788 Post(s)
Liked: 694
I would give audioengine a look. They have wireless/wired speakers. If the SB-2000 bugs you in size, there are smaller subs out there. Given it's a desk system a 12" sub seems a bit much. audioengine also makes an 8" sub. Velodyne has a few models at 8" as well. (The mini vee is 10"x10"x12" with an 8" driver)
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #12 of 12 Old 06-12-2019, 04:50 PM - Thread Starter
hyg71886's Avatar
Quoted: 53 Post(s)
What do you think about the RSL Speedwoofer? Also, how would I go about connecting the 2 monitors and the the sub together to my computer? I looked at the dac you listed but I don't understand how that would work.
hyg71886 is offline
Reply 2-Channel Audio
