Looking for first Turntable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-19-2019, 12:17 PM - Thread Starter
Quoted: 28 Post(s)
Liked: 1
Hello,
I'm looking for a gift for my wife for her 30th birthday. Our hobby is watching movies in our home theater setup and listening to music in our small apartment. She said in the past that collect old vinyl could be a nice hobby. So the idea was to buy a Turntable. I'm completely new in this topic. Budget 200-400 $ (target would be 300$). My home theater system AVR-X2300W + Dali Zensor 7 white (5.1) (I will change the sub for VTF-2 MK5). The only critical point is that we are living temporarily in the USA and the goal would be to use in Poland so it must work on 220-230V in Poland.
Right now my best candidate is Pro-Ject - Debut Carbon (Red) (But this one is very close to upper budget.
jaromarcin is offline
post #2 of 7 Old 06-19-2019, 10:01 PM
RayGuy's Avatar
Quoted: 2606 Post(s)
Liked: 2356
Check out the Orbit U-Turn turntable. Build your own with an acrylic platter, Ortofon om5e cartridge (allows upgrade to the om10 or om20 stylus when you are ready for better), manual arm lift, and built in phono pre-amp or get one separately. Choose the color she would like best.
The Ortofon Red cartridge is known for being bright. With your speakers of choice, the added brightness would probably be a bit much.
https://uturnaudio.com/products/orbit-custom
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #3 of 7 Old 06-20-2019, 05:34 AM
Class A's Avatar
Quoted: 702 Post(s)
Liked: 4297
Thumbs up
Wouldn't worry about the voltage you can get an inexpensive step up voltage regulator like the Minwa Mw2P045 on line when you move back to Europe. So you can be open to any TT you want.
Class A is offline
post #4 of 7 Old 06-20-2019, 08:13 AM - Thread Starter
Quoted: 28 Post(s)
Liked: 1
Thanks for all the recommendation. U-turn was one of my first choices but the problem is that I don't think that Minwa Mw2P045 would work but I'm not a specialist. I think I will have to have full big converter (I asked U-turn company, they recommended Frequency Converter https://www.kccscientific.com/produc...ncy-converter/ additional 150$ ;/ ).
One of the colleagues recommended Fluance RT81 it should work in the USA and in Poland (based on specification (100V - 240V AC (50/60Hz)). It has also built in pre amp so if I understand well I could use it very easy with my Denon (am I right?).
Thanks for all the clarifications.
post #5 of 7 Old 06-20-2019, 06:57 PM
Quoted: 1007 Post(s)
Liked: 802
Fluance RT81 is great entry level turntable; I have one & very happy with it. I also have a $600 e-project TT and don’t think it’s much better... honest opinion
Primary set-up 5.1.4; Yamaha A2050, Paired w/Parasound P5 & ATI 500NC 2 channel amp
Revel F206 fronts & Revel M16 rears; Outlaw X12 Sub & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is offline
post #6 of 7 Old 06-20-2019, 08:32 PM
RayGuy's Avatar
Liked: 2356
Not as pretty, but will do 220V natively:
https://www.amazon.com/Audio-Technic...NTJ033VPPNM6PY
post #7 of 7 Old 06-20-2019, 09:08 PM - Thread Starter
Quoted: 28 Post(s)
Liked: 1
Thanks for all your answers I prefer the design of Fluance RT81 especially this for a gift. Moreover it has very nice reviews, however, I'm still open for recommendations.
Additionally, can someone confirm that it should not be an issue using it in Europe without buying this huge converter? It will be a huge unfortunate if for some reasons which I'm not aware, it will not work or it might have some issues.
The other question which cross my mind, if the turntable is a gift it would be good to buy some speakers because we don't have any right now in the USA and we will come back to Poland in few months so any recommendations for some cheap powered bookshelf speaker?
Reply 2-Channel Audio
