Sound output question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-24-2019, 02:42 PM - Thread Starter
pizzano's Avatar
Quoted: 17 Post(s)
Liked: 6
I noticed during today's listening session that I had to turn my preamps volume control up about 4 notches further then I normally have it set for the normal volume I listen to, which isn't absurdly loud, but just right for my ears as far as the clarity and bass punch and so on.
Yesterday was fine, nothing has changed as far as any of the settings go on any of the equipment used.
The set up is:
Carver A-400x power amp 200 WPC (AC Infinity fan center on top which keeps amp temp at 85 degrees, so no overheating)
Adcom GFP 555 Preamp, (tone control defeat running through Audio Control)
Pioneer Elite DV-59AVi SACD player and Denon DVD-2200 SACD player
Audio Control C-101 Octave EQ
Klipsch KSW 200 powered Sub Power amp is running speaker outputs through the Hi level speaker connections on the Sub.
Polk RTi A7 speakers (Not Bi-wired)
The sound quality seems to be the same , but the increase in the volume control needed is puzzling me.
Any suggestions what to look for as far as any internal parts maybe in the amps output etc, or am I just being to anal LOL.
thanks for any suggestions
pizzano is offline
post #2 of 9 Old 06-24-2019, 02:58 PM
Ratman's Avatar
Quoted: 2161 Post(s)
Liked: 2010
Originally Posted by pizzano View Post
... or am I just being to anal LOL.
Has my vote.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 9 Old 06-24-2019, 05:00 PM
brireeves629's Avatar
Quoted: 201 Post(s)
Liked: 83
The set up is:
Perhaps your “normal level” has cause hearing loss...
brireeves629 is offline
post #4 of 9 Old 06-24-2019, 09:01 PM
Quoted: 41 Post(s)
Liked: 49
Or just a build-up of ear wax, a common cold, or just got off a shift at a warehouse working with and around loud equipment. It happens.
NewAger is offline
post #5 of 9 Old 06-25-2019, 12:17 AM
alan0354's Avatar
Quoted: 1617 Post(s)
Liked: 418
You have different sources, do you have to turn up for every different sources or just one of them. If you have to turn up on all of them, then the problem can be on either the preamp or the power amp.
Is the L and R side both sound lower or just one side? It is hard to imagine both channels go soft at the same time.
Do you have another power amp or preamp to replace either one and see what happen?
Own designed power amp, own designed preamp, JM LAB Spectral 913.1 speakers, Rythmik F12SE sub.
Not hooked up: Nakamichi Stasis PA-7 power amp, Velodyne VA1210 sub, Kef Reference Series center, Kef Bookshelf speaker, Monitor Audio bookshelf speaker, Infinity rear speakers. Acurus 3X200W amp.
alan0354 is offline
post #6 of 9 Old 06-25-2019, 08:03 AM
Quoted: 41 Post(s)
Liked: 49
I'm sure his hardware setup is fine and operating as normal. Our auditory system can sometimes be off-kilter for any number of reasons, even if not immediately apparent. I've experienced the OP's findings a few times across multiple setups.
NewAger is offline
post #7 of 9 Old 06-25-2019, 09:01 AM
alan0354's Avatar
Liked: 418
Ha, I never have issue of hearing louder or quieter. Always seems the same at the same setting.
But anyway, my suggestion is very basic, if all sources ( CD, streaming, radio etc.) have the same loudness, then the source is not the problem. Left and Right channels are separate circuit, it's hard to imagine both get quieter at the same time. If OP feel both sides got quieter, then it's more likely it's his ears. I just don't want to make assumption at this point.
alan0354 is offline
post #8 of 9 Old 06-25-2019, 10:53 PM
Quoted: 56 Post(s)
Liked: 106
The set up is:
Gee. How did it sound today?
Graustark is offline
post #9 of 9 Old 06-26-2019, 07:44 AM
kjfalls's Avatar
Location: Dennison IL, just across the state line from Terre
Quoted: 324 Post(s)
Liked: 114
The only variable not mentioned is the media. Not all recordings are at the same level. If the hardware hasn't changed and sources are all at the same input level the recording is all that's left. Of course, assuming his ears are clean.
kjfalls is offline
Reply 2-Channel Audio
