Looking for mid to high end turntable - $500 to $1500 to match with Philharmonic BMRs - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 2 Post By jcalifornia
  • 1 Post By Locoliberty
  • 2 Post By Class A
  • 2 Post By jsc79
post #1 of 17 Old 07-07-2019, 09:04 AM - Thread Starter
jcalifornia's Avatar
Quoted: 30 Post(s)
Looking to dive into vinyl and turn my 12'x14' office into a listening room. This will be in a 2.0 setup using a pair of Philharmonic BMRs and Denon AVR-X1000. Started off the search looking at Fluance and now looking at a few Rega turntables. Really looking for something that is on par with the BMR speakers. Also open to other options besides the 3 listed and probably leaning towards the Rega Planar 3 right now.
Options:
Fluance RT85 - $499
Rega Planar 2 w/ Carbon MM cartridge - $675
Rega Planar 3 w/ Elys cartridge - $1145
Will also need a pre-amp and so far have seen the Schiit Mani and Pro-Ject Phono Box DC but haven't done too much research. Again, I don't want this to be the weak link in the system and can spend more if it will make a difference.
jcalifornia is offline
post #2 of 17 Old 07-07-2019, 10:26 AM
Class A's Avatar
Quoted: 702 Post(s)
Liked: 4307
Thumbs up
Options:
Fluance RT85 - $499
The Rega 3 would be an excellent choice. It is the best of your choices. Buy the best and you won't have any regrets. For a phono I'd look at the Cambridge Audio Duo. Does both MM/MC if that's important to you. An added feature on the Cambridge is it's also a headphone amp. If your strictly a MM cart person also consider the Rega MM MK3. Excellent phono.
Class A is offline
post #3 of 17 Old 07-07-2019, 03:50 PM
bluewizard's Avatar
Quoted: 2285 Post(s)
Liked: 1508
Sorry to burst your bubble, but $500 to $1500 is Low to Mid, not Mid to High. High end turntables run in the 5 to 6 digits.
Of those listed, and assuming you can afford it, it is hard to consider anything other than the REGA 3. If you have to buy unseen and unheard, that is about the surest best imaginable.
One in the upper range that I might consider would be the
Music Hall MMF-5.3 - Black with 2M Blue Cartridge - $1000
https://musichallaudio.com/product/mmf-5-3-turntable/
Though my preferred, because I like wood -
Music Hall MMF-5.3se - Rosewood with 2M Bronze Cartridge - $1400
Keep in mind the cartridge upgrade is a considerable portion of the price increase -
https://musichallaudio.com/product/mmf-5-3se-turntable/
PROJECT also makes some similarly priced turntables -
https://www.musicdirect.com/top-rate...sic-eucalyptus
https://www.musicdirect.com/turntabl...iRes-Turntable
https://www.musicdirect.com/turntabl...t-X1-Turntable
While the Music Hall appeal to me personally, the safest surest bet is the REGA 3. If you are trying to save a bit more money, the there is nothing wrong with the REGA 2.
Though Music Hall does have a pretty wide range of turntable -
https://musichallaudio.com/turntables/
On the lower end, this appeals to me, partly because it has Auto-Lift of the tonearm at the end of the record; from what I understand, that is just Auto-Lift, not Auto-Return, and I prefer the S-Shaped Tonearms -
Denon DP-400F - $500 -
https://www.musicdirect.com/turntabl...atic-turntable
https://usa.denon.com/us/product/hifi/turntables/dp400
https://usa.denon.com/us/product/hif...ables/dp450usb
Though I don't especially like the dust cover.
If you want to stay more in the $500 to $750 range, then PROJECT has some nice options -
https://www.crutchfield.com/p_252DCE....html?tp=75887
https://www.crutchfield.com/g_10500/...Brand|Pro-Ject
But back to the main point, if you have to mail-order and can not see them in person, the the REGA-3 and REGA-2 are pretty safe bets.
Just one man's opinion.
Steve/bluewizard
bluewizard is offline
post #4 of 17 Old 07-07-2019, 06:01 PM
Macabre's Avatar
Liked: 0
For a fairly different option, take a look at the recent Technics 1200 re-release as well.
Macabre is offline
post #5 of 17 Old 07-09-2019, 03:39 PM
bluewizard's Avatar
Liked: 1508
Technics SL-1200MK7 Direct Drive Turntable System - $999 -
https://www.bhphotovideo.com/c/produ...le_system.html
Technics SL-1210GR Direct Drive Turntable System - $1700
Audio-Technica Consumer AT-LP1240-USB XP Professional DJ Direct-Drive Turntable (USB & Analog) with AT-XP5 Cart - $500 -
https://www.bhphotovideo.com/c/produ...e_pro_usb.html
Reloop RP-7000 MK2 Upper Torque Turntable System (Silver) - $500 -
https://www.bhphotovideo.com/c/produ...gh_torque.html
Stanton ST.150 M2 Direct-Drive Turntable - S-Tonearm - $600 -
https://www.bhphotovideo.com/c/produ...turntable.html
There are all DJ-style turntables, and while they have DJ features the OP will probably not need, they are all still very good turntable, very rugged with Direct Drive Motors, though they don't always come with a Cartridge.
Steve/bluewizard
post #6 of 17 Old 07-10-2019, 10:00 AM
HarleyRider's Avatar
Quoted: 136 Post(s)
Liked: 83
Possibly out of your upper price range when you add in a pre-amp, but take a look at the Marantz TT15. I think it's one of the biggest values in TT's. It's made by German hi-fi company Clearaudio for Marantz. Very similar to their Emotion turntable. It uses Clearaudio's Satisfy tonearm which sells by itself for around $1700 and includes the Clearaudio Virtuoso Wood cartridge, valued around $700. It's a heck of a lot of TT for ~$1500. I recently upgraded from a Project Debut Carbon Esprit to the Marantz and could not be happier.
https://www.us.marantz.com/us/produc...oductId=TT15S1
Pre/Pro: Anthem AVR 60 | 5.2.4 Config: MartinLogan ElectroMotion ESL X FL/FR, ESL C Center, Motion LX16 Surrounds, Motion 4i Atmos | Subs: Velodyne DD-15, Martin Logan Dynamo 1100x | Amplification: Emotiva XPA-3 Gen 1 FL/C/FR, Emotiva A-700 Surrounds and Atmos
Dedicated ARC Genesis Thread
HarleyRider is offline
post #7 of 17 Old 07-12-2019, 07:58 AM - Thread Starter
Quoted: 30 Post(s)
Ended up going with and all Rega solution. Will report back once it's setup next week with my thoughts.
Rega Planar 3
Elys 2 MM Cartridge
Rega Fono MM Phono Preamplifier
Class A and jsc79 like this.
post #8 of 17 Old 07-12-2019, 08:47 AM
Class A's Avatar
Quoted: 702 Post(s)
Liked: 4307
Thumbs up
Rega Planar 3
Elys 2 MM Cartridge
Give it about 50 hours for the cart to totally break in. Excellent no fuss set up. Buy lots of records. Don't forget record cleaning supplies.
Class A is offline
post #9 of 17 Old 07-12-2019, 10:06 AM
jsc79's Avatar
Quoted: 373 Post(s)
Liked: 431
After reading this thread the other day, I went to needledoctor(only about 15 minutes from my work) and checked out some new turntables. I ordered the Planar 2, but now have decided I want to go with the Planar 3 to eliminate the what if's and spending more money later on upgrading. Im gonna exchange the 2 when I get it.
I see the OP went with the Elys 2 cart. Has anyone heard a Audio Technica cartridge on a Planar 3? Was looking at the one below. Im torn between going with the all Rega set up, or trying a different cart.
https://www.needledoctor.com/Audio-T...hono-Cartridge
Subwoofers: Dual Rythmik FV18
Speakers: L/R Ascend Acoustics Sierra 2 - Center - Horizon w/RAAL Surrounds: Sonance VP62R SST/SUR. Vinyl:Rega Planar 3
Video: Sony XBR65X900e 65" 4K - Sony UBP-X800 Blu Ray
Power and Processing: Yamaha RXA1030 - Monolith 7X Amp - Minidsp 2X4 HD/WI-DG
jsc79 is online now
post #10 of 17 Old 07-12-2019, 12:44 PM
Quoted: 289 Post(s)
Liked: 178
I cant claim comparative experience, but the Rega 2 I picked up used a while back had a Dynavector MC cart on it. The original owner thought is was a huge improvement over the Ortofon Red it came pre loaded with, FWIW.
I think the combination sounds fantastic. I'm pretty sure the Planar 3 would do just as well or better with a MC cart.
5.1: Power - Denon 4308ci, Fronts - Def Tech BP9040's, Center - Def Tech CLR 2000, Surrounds - Def Tech PM1000's, Sub's - Rythmik E15HP x2, Display - Panasonic TC-55AS530U, TT - Rega Planar 2 w/ Dynavector 10x5
derekmoore is online now
post #11 of 17 Old 07-12-2019, 12:46 PM
Quoted: 46 Post(s)
Liked: 8
A used Rega RP6 is also an excellent choice. Got mine for just shy of 1k
derekmoore likes this.
System: Cambridge 851A, Revel M126be, SVS SB2000, Cambridge DACMAGIC 100, JVC XL-Z1050TN, Rega RP6, Vincent PHO-8. A bunch of monster power conditioning junk
V: Samsung NU8000, Nvidia Shield TV
Locoliberty is offline
post #12 of 17 Old 07-12-2019, 12:47 PM
Quoted: 289 Post(s)
Liked: 178
https://www.needledoctor.com/Dynavec...hono-Cartridge
This is the one the guy I bought my Rega from put on it.
post #13 of 17 Old 07-12-2019, 02:56 PM
jsc79's Avatar
Quoted: 373 Post(s)
Liked: 431
I’m sure that’s an awesome cart, but way over my budget unfortunately.
jsc79 is online now
post #14 of 17 Old 07-12-2019, 04:05 PM
Class A's Avatar
Quoted: 702 Post(s)
Liked: 4307
Thumbs up
Depends on your speakers. The AT can be quite revealing at the top end. I'd look at the Nagaoka Mp-110 a much more rounded musical cart. In the same price range.
jsc79 and yanks1 like this.
Class A is offline
post #15 of 17 Old 07-12-2019, 04:07 PM
jsc79's Avatar
Quoted: 373 Post(s)
Liked: 431
It will be running through the gear in my signature. I’ve read a lot of good stuff about that mp 110 cart.
jsc79 is online now
post #16 of 17 Old 07-13-2019, 10:32 AM
jsc79's Avatar
Quoted: 373 Post(s)
Liked: 431
The more I think about it I might as well go with the Rega setup with the Elys 2 cartridge. As was mentioned, great no fuss setup out of the box.
Gonna go with the gloss white.
derekmoore and Class A like this.
jsc79 is online now
post #17 of 17 Old 07-13-2019, 11:55 AM
Quoted: 289 Post(s)
Liked: 178
I really liked the gloss white look as well. High on WAF too.
I wound up with a black one though just cuz is was too good of a deal to pass up.
Reply 2-Channel Audio
