Amplifier recommendations - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By Russdawg1
  • 1 Post By mjcmt
  • 1 Post By brireeves629
  • 2 Post By Alexander Jellison
post #1 of 12 Old 07-16-2019, 11:32 PM - Thread Starter
Odin_Thor's Avatar
Like some user feedback for recommended amplifiers to match my setup, speakers I currently use are the Paradigm Studio 60s. My existing pre-amp is a Cambridge 851E but the power amplifier I was using before, the Cambridge 851W.
The power amp has stopped working, stuck in protect mode. I had the amp fixed once over 2 years ago, won't be fixing it again.
As much as I liked the this setup, I looking at alternative options.
I don't know if I will bother with a power amp this time and may look for a decent integrated instead.
I know some integrated amps have a "main in" function so may look in that option.
Was thinking of a Yamaha A-s1100 but maybe look at other options
Odin_Thor is offline
post #2 of 12 Old 07-16-2019, 11:35 PM
Quoted: 1622 Post(s)
Liked: 1234
Check out Parasound. Loved mine.
Jonas2 likes this.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #3 of 12 Old 07-17-2019, 12:21 AM
If Class D is something you're open to, loads of power amp options including (but not limited to):
Nuprime STA-9
Nuprime STA-10
PS Audio Stellar S300
Nord (several options)
Cherry Amp (options)
D-Sonic
Jeff Rowland
Main system: Rotel RA-1572 (int amp - looking to change); Cocktail Audio X10 (main source); Sony UHP-H1 Blu-ray/SACD player (secondary source); Q Acoustics Concept 20 speakers.
Looking at: NAD C 658 (pre); Anthem STR (pre); Nord One MP NC252 (power - maybe SE); Mytek Brooklyn Amp (power); NAD C 658 (power). Also, Pioneer UDP-LX500 or Sony UBP-X1100ES
RockAddict is offline
post #4 of 12 Old 07-17-2019, 01:56 AM
glangford's Avatar
Quoted: 708 Post(s)
Liked: 627
Nuprime STA-9
Nuprime STA-10
D-Sonic
Jeff Rowland
Other Class D's. Peachtree, Lyngdorf, NAD
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #5 of 12 Old 07-17-2019, 04:41 AM
mjcmt's Avatar
Quoted: 16 Post(s)
The Yamaha is a very good amp and spoken very highly in other forums.
leecreek likes this.
mjcmt is offline
post #6 of 12 Old 07-17-2019, 02:57 PM
brireeves629's Avatar
Quoted: 201 Post(s)
Liked: 83
Look at Emotiva. Great value and outstanding build quality.
brireeves629 is offline
post #7 of 12 Old 07-17-2019, 06:22 PM - Thread Starter
Odin_Thor's Avatar
Only issue here in Australia, because prices are so expensive my options are limited.
Yes I have heard the Yamaha A-s1100 is a very good amplifier.
As for Class D, had one of these amps many years, it was okay for HT use, but I didn't think too much of it for musical side of things, especially since I started using a dedicated 2 ch setup for muisc.
Keeping my options open for the moment.
post #8 of 12 Old 07-17-2019, 07:43 PM
I was recently looking at come Class D amps from Apollon that really caught my eye and aren't too expensive for my other setup. Aside from that I second PS Audio amps. Still in love with mine.
Mytek Brooklyn Dac+ | PS Audio M700 monoblocks | Buchardt S400's
Alexander Jellison is offline
post #9 of 12 Old 07-18-2019, 05:15 PM
hedrick's Avatar
I suspect class D has improved since. I have a NAD D3020. It's wonderful. Stereophile did detailed tests, and it came out well. It's a good low-cost integrated if you don't want any controls other than volume. It and related products have varying types of inputs, analog and digital.
NAD uses class D for some of their high-end products.
hedrick is offline
post #10 of 12 Old 07-18-2019, 09:27 PM
Class D has come a long way in recent years. I recently replaced a 12 year old NAD Class A/B integrated with the new Class D version and it sounded nearly identical aside from the Class D having slightly quicker and tighter bass. I was sold on Class D at that point. There's basically only two companies making Class D boards, ICEpower and Hypex, and everyone uses those and tweaks the sound by messing with the input stage. If done properly, Class D can be almost indistinguishable from Class A/B, and it's not uncommon to have amps in the many hundreds of watts that barely get warm to the touch at full volume and still sound great.
Jonas2 and shivaji like this.
post #11 of 12 Old 07-21-2019, 09:07 AM
Jonas2's Avatar
Quoted: 2819 Post(s)
Liked: 1779
Although I don't own any Parasound gear, I have "played" with some of it, and I do really like the Halo Integrated. I would definitely consider one if I was looking for an integrated solution.
Today's class D amps are not those of yesteryear. I'd consider:
https://www.d-sonic.com/amplifiers/stereo/
Well, not everyone uses those.....
http://www.pascal-audio.com/products/
Used in the aforementioned D-Sonic amps....but yeah, the others get a lot of press!
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #12 of 12 Old 07-30-2019, 05:14 AM
Quoted: 69 Post(s)
Budget?
Bryston 4b-St and newer may be good options for you. the 4b SST is probly around ur budget given the old Cambridge or are you looking to upgrade?
System: Cambridge 851A, Revel M126be, SVS SB2000, Cambridge DACMAGIC 100, JVC XL-Z1050TN, Rega RP6, Vincent PHO-8. A bunch of monster power conditioning junk V: Samsung NU8000, Nvidia Shield TV
hipped
Locoliberty is offline
Reply 2-Channel Audio
