Record & Stylus Cleaning - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By citizen arcane
  • 2 Post By Alex F.
post #1 of 4 Old 08-11-2019, 11:37 AM - Thread Starter
RickD1225's Avatar
Quoted: 292 Post(s)
Liked: 1019
How often are you cleaning your records & stylus?
Since I purchased the Onzow ZeroDust I clean my stylus every album side. I use a carbon fiber brush before I start each album side. My entire collection has recently been washed with a Big Fudge Record Friend. Is this too anal? Either way my vinyl sounds terrific!
Spoiler!
RickD1225 is offline
post #2 of 4 Old 08-11-2019, 12:14 PM
citizen arcane's Avatar
Quoted: 516 Post(s)
Liked: 19608
Then play on.....
Ratman likes this.
¿lɐɯɹou ǝq ʎɥʍ
citizen arcane is offline
post #3 of 4 Old 08-11-2019, 12:19 PM
Class A's Avatar
Quoted: 735 Post(s)
Liked: 4650
Thumbs up
For my cart I use the DS Audio ST-50 Stylus Cleaner. I have a VPI 16.5 RCM and always clean new and used records that I purchase. For some deep cleaning I use the Record Genie a local service that deep cleans my LP's for around $2 each. He uses the expensive $5000 machines. A good clean collection will make your music sound better and lengthen the life of you cart.
Class A is offline
post #4 of 4 Old 08-11-2019, 12:54 PM
Alex F.'s Avatar
Quoted: 892 Post(s)
Liked: 497
If your LPs are clean it is not necessary to clean the stylus that often. Typically I clean the stylus only at the beginning of a listening session, even if that session includes both sides of about three records.
Class A and Scotth3886 like this.
Music room: Cary SLI-80 tube integrated amplifier, McIntosh MA6500 integrated amplifier, Quad 99 preamp, Quad 909 power amp, Acoustic Research AR9 loudspeakers, Yamaha CD-N500 CD player, Teac UD-503 DSD DAC, Phase Linear 8000II linear-tracking turntable.
Theater room: Panasonic 65S60 plasma television; Yamaha RX-A2020 (preamp section); Adcom GFA-5503 and GFA-5400 amplifiers; Polk LSi25, LSiC, and LSiF/X loudspeaker system; Velodyne FSR-18 servo-subwoofer.
Alex F. is offline
Reply 2-Channel Audio
