Please recommend upgrades to my system - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #1 of 38 Old 09-12-2019, 11:00 AM - Thread Starter
ktm125's Avatar
My current setup...
Spotify thru PC connected to processor via HDMI
Emotiva UMC-200 Preamp/Processor
Emotiva RPA-2 amp
Leagcy Audio Focus speakers
PS Audio Power Plant Premier
What would you replace or add to get a noticeable increase in SQ?
Not interested in CDs or vinyl.
thanks...
ktm125 is offline
post #2 of 38 Old 09-12-2019, 12:00 PM
Ratman's Avatar
Quoted: 2358 Post(s)
Liked: 2211
Nothing IMO.
What do you think requires an "upgrade" for a noticeable improvement to SQ?
Out-Of-Phase likes this.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #3 of 38 Old 09-12-2019, 12:02 PM
qirex's Avatar
Quoted: 163 Post(s)
Liked: 137
What don't you like about the way it sounds now? Without knowing that I'd say maybe look at Tidal HiFi or Qobuz for CD (and-above) quality streaming. Since you have a complete system it also might be time to start looking at room treatment.
qirex is offline
post #4 of 38 Old 09-12-2019, 12:04 PM
Williams2's Avatar
Quoted: 465 Post(s)
Liked: 256
Maybe mini dsp, to have perfect bass.
Williams2 is offline
post #5 of 38 Old 09-12-2019, 01:40 PM
m. zillch's Avatar
Quoted: 5331 Post(s)
Liked: 3843
Subs
Room treatments
I sometimes use a center and surround speakers even for 2-channel audio content. Not usually though, but I certainly use them for TV and movie content and for me my 2-ch audio system is also my video system.
m. zillch is offline
post #6 of 38 Old 09-12-2019, 02:39 PM
Liked: 1
The only thing I'd recommend is using a USB cable instead of an HDMI. It's completely possible that you could get a better bit depth and sample rate that way. Both of which are capped by HDMI which may also have some lossy encoding that you're not aware of. I'm not aware of HDMI doing lossless broadcasting but I could be wrong there.
You'll, of course, have to do some settings editing on the computer. I presume your using Win10 which doesn't make it easy to find the place where bit depth and sample rate are controlled. If you know where they are great! If not do some exploring with both the right and left mouse buttons on things and you'll eventually find it.
I hope this helped you out.
Nathan Loiselle is offline
post #7 of 38 Old 09-12-2019, 02:43 PM
Quoted: 68 Post(s)
Liked: 30
Agreed with Room treatments- probably the best upgrade that a lot of people don’t do. You can get custom art panels that blend Into living areas for fairly reasonable cost from the likes of GIK Acoustics or ATS Acoustics
Also consider a streamer like Bluesound or Sonos Connect (Now Sonos Port) - especially if you switch to Tidal for ease of selecting and controlling your music from your phone. With Spotify (and Spotify Connect) you should be good already.
thebrieze01 is offline
post #8 of 38 Old 09-12-2019, 03:18 PM
m. zillch's Avatar
Liked: 3843
If he was "there" he probably never would've asked the question, as I see it.
post #9 of 38 Old 09-12-2019, 03:20 PM
Out-Of-Phase's Avatar
Quoted: 318 Post(s)
Liked: 264
He doesn't know he's there.
m. zillch likes this.
Save your money.
Out-Of-Phase is offline
post #10 of 38 Old 09-12-2019, 06:08 PM
Quoted: 178 Post(s)
Liked: 32
From my recent experiment how DAC/amp can improve the final result, I'm guessing you're currently not hearing your speakers full potentials.
Setup #1: GoldenEar Triton Reference --> Parasound Halo Integrated --> Allo DigiOne Signature, LG OLED C7P 65
Setup #2: Elac Debut B6.2 --> Akitika GT-102 --> ??
tt.tennis-warehouse.com/index.php, www.dpreview.com/forums, www.bimmerfest.com/forums
Shangri-La is offline
post #11 of 38 Old 09-13-2019, 05:20 AM
Class A's Avatar
Quoted: 739 Post(s)
Liked: 4773
Thumbs up
I would add Tidal or Qobuz for better quality streaming services. Also either a Topping D-70 DAC or the RME-ADI-2 DAC. Both have excellent in depth reviews in Audio Science Review.
Class A is online now
post #12 of 38 Old 09-13-2019, 09:05 AM
hhawk's Avatar
Quoted: 28 Post(s)
Liked: 24
Upgrade interconnects and/or speaker wire? System should be good enough to hear differences if you are still using basic cables and speaker wire. Could experiment with lower cost cables from popular brands like Wire World, Audio Quest and Nordost.
hhawk is offline
post #13 of 38 Old 09-13-2019, 09:38 AM - Thread Starter
ktm125's Avatar
Originally Posted by Ratman View Post
Nothing IMO.
don't know...that's my question
ktm125 is offline
post #14 of 38 Old 09-13-2019, 09:39 AM - Thread Starter
ktm125's Avatar
some songs are harsh at high volumes...thanks will look into Tidal and Qobuz
ktm125 is offline
post #15 of 38 Old 09-13-2019, 09:40 AM - Thread Starter
ktm125's Avatar
thanks!
ktm125 is offline
post #16 of 38 Old 09-13-2019, 09:41 AM - Thread Starter
ktm125's Avatar
Audio Science Review....thank you so much...tons of info there
ktm125 is offline
post #17 of 38 Old 09-13-2019, 09:52 AM
m. zillch's Avatar
Liked: 3843
That sounds like a text book description of exceeding either the limits of your speakers or your amplifiers (you are "clipping" them on the louder parts). Investing in amps with power output meters or at the very least clip lights might be in order.
Hearing itself also gets into trouble (sounds distorted) at very high levels [dangerously loud, that is, such that extended listening at this level can cause tinnitus or even permanent NIHL, noise induced hearing loss] . Just ask rockers like Phil Collins or Pete Townsend who ruined their hearing by not following OSHA safety guidelines..
John Enwhistle, also of the Who, once came into my audio store decades ago and his "hearing aid" was his wife/g-friend who would repeat every question we asked him into his ear quite loudly as she draped herself on his arm so her mouth was just inches away from his ear.
post #18 of 38 Old 09-13-2019, 10:52 AM
Ratman's Avatar
Liked: 2211
Or... just poor source material and/or internet speed and/or router settings users and/or poor Wifi… etc.
Try a Steely Dan CD. If it sounds good at desired volumes compared to a "streaming service", your equipment may not be to blame.
drh3b likes this.
post #19 of 38 Old 09-14-2019, 06:56 PM
crn3371's Avatar
Quoted: 307 Post(s)
Liked: 266
You have some fairly high end components in your system, but you’re feeding them pretty low end source material. Cheapest upgrade you can do is to get rid of Spotify and use something like Tidal or Quboz. After that I’d stop using your pc and get a dedicated streamer, something like the Bluesound Node 2i at the very least.
drh3b, KenM10759 and pappaduke like this.
crn3371 is offline
post #20 of 38 Old 09-15-2019, 12:40 PM
Liked: 2
kalle83 is offline
post #21 of 38 Old 09-15-2019, 03:32 PM
Quoted: 68 Post(s)
Liked: 30
Originally Posted by kalle83 View Post
What pre-pro would you recommend?
post #22 of 38 Old 09-15-2019, 06:51 PM - Thread Starter
ktm125's Avatar
from "TAPAS" the RMAF thread...
"It boggled my mind thinking of the level of performance any music lover could enjoy today with a pair of Tekton MOAB speakers and a Parasound 200 Integrated amp for a modest investment of $5,695.
All that you need is a monthly premium subscription to Tidal ($19.99) or Qobuz ($24.99), connect your laptop to the Parasound 200 Pre via USB and stream all the high resolution 192kHz/24-Bit audio files to your heart’s content.
The Parasound comes with Burr-Brown DACs supporting USB, Coaxial and Optical Inputs.
This is the simplest and cleanest idiot proof setup you could ever assemble.
This is unreal. This is audio magic. This system shattered my frame of reference."
I'm looking into this setup.
ktm125 is offline
post #23 of 38 Old 09-16-2019, 05:25 AM
KenM10759's Avatar
Quoted: 3435 Post(s)
Liked: 1916
To my mind, there's nothing particularly 'modest' about a $5,695 investment.
One can get a good TI Burr-Brown PCM5122 DAC, and streaming of 24/192 Tidal (with full MQA unfold, if that matters) or Qobuz with a very slick interface with any Bluesound streamer and spend under $500.
pappaduke likes this.
KEF R500, R200C, R100, R50, SVS SB2000 sub, NAD T758v3 AVR, LG UP875 4K BlueRay, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer. Office: NAD M10, KEF LS50, KEF Kube 10b, Pro-Ject RPM1 TT w/ Ortofon 2M Red. Guest room: Hafler 300 L-R, KEF Reference Model 100 center, KEF iQ10 surrounds, modded M&K V-90 sub, Bluesound Vault 2.
KenM10759 is offline
post #24 of 38 Old 09-16-2019, 08:11 AM - Thread Starter
ktm125's Avatar
Would you recommend any other streamers over the Bluesound?
ktm125 is offline
post #25 of 38 Old 09-16-2019, 08:39 AM
KenM10759's Avatar
Liked: 1916
There are better, but none other than other Lenbrook Group products NAD and Bluesound (plus speaker companies PSB and Dali) have the BluOS interface that affords running it via any Android, IOS, or Windows mobile or desktop device.
Depending upon budget, there are a LOT of other choices but you may have to figure out the best app to run each. Elac, Naim, etc.
post #26 of 38 Old 09-16-2019, 09:49 AM
crn3371's Avatar
Quoted: 307 Post(s)
Liked: 266
There are certainly better streamers than the Node, but at a price. Look at brands like Aurender, Auralic, Cocktail Audio.
crn3371 is offline
post #27 of 38 Old 09-16-2019, 10:12 AM - Thread Starter
ktm125's Avatar
Whats your best pick for SQ and PC interface not taking cost into consideration?
The streamer will connect to my DAC.
ktm125 is offline
post #28 of 38 Old 09-16-2019, 10:42 AM
bluewizard's Avatar
Quoted: 2321 Post(s)
Liked: 1532
Very Sweet system, though I'm not exactly sure of the components related to Streaming. For example, if the Computer you are using dedicated to your Stereo System?
I would suggest you get a dedicated Streaming Device like Bluesound, Cambridge, or one of many others depending on your budget. That would integrate into your system very nicely, and could be controlled with a Smart Phone or Pad/Tablet.
That would also give you access to Hi-Res Streaming Services like - Dezeer, Qobuz, and the most popular TIDAL. Though it would also work well with Spotify.
Now based on your list of equipment, very nice equipment. However, that doesn't mean you necessarily like what you hear. If that is true, then we would need to explore specifically how the system was letting you down and focus on how to improve that specific aspect.
I agree with others that Room Treatments might help improve the sound. An open bare room can have a lot of echo that are not really noticeable because of the short delay times, but they will still cause the music to smear and blur.
While I'm sure HDMI will and does work, for music, as others have suggested, if this is audio only, I would consider USB. However, if it is Audio and Video then HDMI might be the better choice. Though be aware, you can probably have both.
I think you would benefit from the convenience of a dedicated Streaming Device. For example, the Bluesound NODE-2i is only about $500, and is very fast and responsive, and has a decent interface.
I think it depends on whether the Computer in question is dedicated to the System, or whether it is a general purpose personal computer.
Just a few thoughts.
Steve/bluewizard
bluewizard is offline
post #29 of 38 Old 09-16-2019, 06:54 PM
crn3371's Avatar
Quoted: 307 Post(s)
Liked: 266
Are you referring to the built-in DAC on your Emotiva pre? If so, I’d wager that the built in DAC on the Node is as good, or better. If you’re looking at streamers that cost several thousand dollars you’d best be looking at a DAC upgrade, or look at a streamer with a good built-in DAC. With a brand such as Auralic, their dedicated streamers (sans DAC) are $2.5K and $4K, while their streamers with DACs run $3.7k and $6K. It really comes down to budget. I wouldn’t make a jump into territory like this unless you’re also planning to upgrade the rest of your front end components. If you’re planning on staying with the Emotiva gear I wouldn’t go any higher than the Node 2i for a streamer.
crn3371 is offline
post #30 of 38 Old 09-16-2019, 07:14 PM
pappaduke's Avatar
Quoted: 404 Post(s)
Liked: 406
Here's a list of Tidal supported devices: https://tidal.com/supported-devices
As you do your research, you will see the prices are all over the place. Budget will help to determine what is right for you. Personally, I'm a Bluesound guy. I've been happy with the available streaming services, SQ and build.
Man cave-Marantz 8012, Oppo 203, 4K ATV, Sony XBR-75X940E, Bluesound Vault 2, Harmony One, 2 Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's,
4 SVS Prime elevations. B&W P5. Living room- Yamaha 2010, Bluesound Node 2, Paradigm SE-1's, Zone 2-Paradigm-Stylus 370-SM
Bedroom- Samsung UN60ES7100F, Oppo 103D, Pulse Mini, JBL Bar Studio, ATV3 and Harmony 650
pappaduke is offline
Reply 2-Channel Audio
