Marantz PM7000N - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By _tk
  • 1 Post By qirex
post #1 of 19 Old 09-27-2019, 11:22 AM - Thread Starter
qirex's Avatar
Quoted: 193 Post(s)
Liked: 156
Marantz PM7000N
Marantz has announced an "all in one" integrated amp with streaming, looks pretty interesting. $999, 60 WPC rated at 0.02% THD, DAC, USB phono, adjustable crossover. They have a feature that can "listen" on digital inputs and power the receiver on plus learn TV remote volume codes. It also features many buzzwords (HDAM SA3, SPKT-1+, etc.) for all the ways they built it but it sounds like they put some effort towards isolation and separation of components. What Hi-fi reviewed it and gave it 5 stars (on their scale of four to five stars).
Some things that seem odd:
  • No pre-outs (the much cheaper NR1200 2 channel AVR has them plus HDMI switching)
  • It seems like everything network runs through HEOS
  • No remote, I guess you're supposed to use an app or the learning feature with your TV remote but at this price they could have thrown one in. Shades of the NAD M10.
  • HDMI ARC would have been nice
  • "Pure" mode for bluetooth?
Seems like a decent value against stuff like the NAD 368 BluOS but if you wanted external amps the NR1200 is probably a better bet.
qirex is offline
post #2 of 19 Old 09-27-2019, 12:46 PM
mlknez's Avatar
Quoted: 538 Post(s)
Liked: 182
As an NR1200 owner, I agree
The main problem that I have with the NR1200 is that it does not play back native DSD. It first converts to PCM then goes through the DAC. I do not know if the PM7000 does this also or not.
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is offline
post #3 of 19 Old 09-27-2019, 01:22 PM - Thread Starter
qirex's Avatar
Quoted: 193 Post(s)
Liked: 156
Do you like it otherwise? It seems super flexible and the small size makes it easy to recommend to friends who aren't used to full size audio components.
The PM7000N is probably better compared against the upcoming Onkyo 8390, which has a bigger amp (200 BS marketing watts per channel, 135 actual 8 ohms full range 0.08% THD) AccuEQ and pre-outs for around the same price.
qirex is offline
post #4 of 19 Old 09-27-2019, 02:02 PM
mlknez's Avatar
Quoted: 538 Post(s)
Liked: 182
Yes, I do like it otherwise. I use it in a simple bedroom system. It replaced a Pioneer SX-N30. I liked it better than the Onkyo 8270. See in my signature below.
mlknez is offline
post #5 of 19 Old 09-27-2019, 03:21 PM - Thread Starter
qirex's Avatar
Quoted: 193 Post(s)
Liked: 156
I have an Integra DTM-7 (rebadged 8270) and I've been generally happy with it but it's been almost 2 years so upgrade-itis is creeping in. I think I'll do my speakers first, though.
qirex is offline
post #6 of 19 Old 09-29-2019, 08:36 PM
denslayer's Avatar
Quoted: 61 Post(s)
Liked: 37
Just started the 2 channel research phase . I also want to stream amazon hd music , so this product looks very tempting. Too bad no one has them yet
Sony 65inch 900F, Apple TV4k, Xbox one S, sonos 5.1
denslayer is offline
post #7 of 19 Old 09-30-2019, 07:55 AM
mlknez's Avatar
Quoted: 538 Post(s)
Liked: 182
What about it looks tempting compared to other systems out there?
mlknez is offline
post #8 of 19 Old 09-30-2019, 07:19 PM
denslayer's Avatar
Quoted: 61 Post(s)
Liked: 37
well, I've never focused on only a 2 channel setup. To me this is plug it in , hook up some speakers and go. I can stream Flac from amazon or hook up a turntable in the future.
post #9 of 19 Old 09-30-2019, 07:30 PM
_tk
Quoted: 643 Post(s)
Liked: 274
Seems like a pretty good unit for that. Out of all the "mid-fi" integrated amps in the $399-$999 range, I prefer the Marantz sound over all of them.
Personally, I don't like all the digital stuff built in...but I understand why it's attractive to some. This unit basically does everything and should do it pretty well.
_tk is online now
post #10 of 19 Old 09-30-2019, 09:35 PM
mlknez's Avatar
Quoted: 538 Post(s)
Liked: 182
Three are others that are less expensive with more features.
Sent from my LG-H931 using Tapatalk
mlknez is offline
post #11 of 19 Old 09-30-2019, 10:54 PM
denslayer's Avatar
Quoted: 61 Post(s)
Liked: 37
please elaborate.. I'm not set at all on this unit. My speakers will be the Kef Ls50. I want to sit on the couch , open up the heos app and stream some Hd music from amazon. I don't want to leave a pc running and i don't have a Nas . Sure all Denon and Marantz and now some onkyo receivers will do this, but they all have Hdmi, which I have no need for . I'm also leaning towards the Nr-1200 but again has hdmi.. Who woulda thought that good old stereo would have so many options
post #12 of 19 Old 10-01-2019, 10:02 AM
_tk
Quoted: 643 Post(s)
Liked: 274
They also might not sound as good, look as nice or could be different amp architecture (like class D).
Any examples that you are thinking of?
_tk is online now
post #13 of 19 Old 10-01-2019, 10:10 AM
mlknez's Avatar
Quoted: 538 Post(s)
Liked: 182
Pioneer SX-N30, Onkyo 8720, marantz NR1200
mlknez is offline
post #14 of 19 Old 10-01-2019, 10:28 AM
_tk
Quoted: 643 Post(s)
Liked: 274
Anything with HDMI is more on the "home theater" side of the house.
The PM7000N is basically a PM7005, only with digital streaming built into it. You're still getting the better grade components like you do in the PM line.
Compared to the NR1200 that basically a 2-channel version of their AVR's (NR line).
_tk is online now
post #15 of 19 Old 10-01-2019, 12:28 PM
denslayer's Avatar
Quoted: 61 Post(s)
Liked: 37
Just found on Instagram that the sale date is Nov 15
post #16 of 19 Old 10-01-2019, 01:14 PM
mlknez's Avatar
Quoted: 538 Post(s)
Liked: 182
I agree, but with a $1000 unit, you should be hooking up speakers that are $2000 or above.
mlknez is offline
post #17 of 19 Old 10-01-2019, 01:24 PM
_tk
Quoted: 643 Post(s)
Liked: 274
Please don't spread this around anymore than what it is already. Due to the quality of "inexpensive" speakers in this day and age, this is no longer all that close to being valid.
Plus, someone mentioned they'd use LS50's with said amp, which would be a nice combination.
mlknez likes this.
_tk is online now
post #18 of 19 Old 10-01-2019, 01:49 PM - Thread Starter
qirex's Avatar
Quoted: 193 Post(s)
Liked: 156
Just think of it as a $600 amp with a $400 DAC/streamer built in, then $1200 speakers are perfectly on budget
mlknez likes this.
qirex is offline
post #19 of 19 Old 12-15-2019, 07:07 AM
Liked: 0
Hi, can someone tell me if there is a SUB out VOLUME CONTROL on this or does one need to use the powered sub volume?
What is the sound signature of the built in DAC?
[email protected] is offline
Reply 2-Channel Audio
