Please recommend me a USB DAC (and related questions) - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Gyroscopics
post #1 of 9 Old 10-22-2019, 09:54 AM - Thread Starter
nonstopdoc1's Avatar
Quoted: 619 Post(s)
Liked: 160
I currently have a Teac UD301 USB DAC/Headphone which powers my headphones and also feeds a pair of powered bookshelf speakers. I have a Massdrop THX AAA 789 Amp on order and now looking for a separate DAC to pair it with or a combo DAC/AMP that can provide a similar performance for a similar combined price.
I need DAC with at least 2 pairs of outputs and one that can feed both at the same time. I also prefer black colored chassis.
I have shortlisted
- SMSL SU-8 - $200 - AFAIK, it comes only in silver
- Topping D70 -$425
- Monolith by Monoprice Liquid Platinum Balanced DAC by Alex Cavalli (AKM4499) - $500 - Not released yet so don't now how good it will be but I can wait if its expected to offer significant improvement.
1. Is Topping D70 worth twice the price of SMSL SU-8?
2. Can I control the volume of powered speakers from DAC or only from the speakers?
3. Is there a combo DAC/Amp that can offer similar performance for < $1K? I am open to reselling the Massdrop THX AAA 789 amp if I can find a good combo solution.
I returned the Monolith THX DAC/Amp because of usability issues. It required me to go to menu every time I wanted to switch outputs between speakers and headphones which my Teac does automatically depending upon whether headphones are plugged in or not.
Thanks in advance
My Build Thread
HT - Seymour Centerstage XD 2.39:1 133" W| JVC X790R | Denon AVR | QSC DPA 4.2 | ATI AT528NC | Procella P8/P5V | Revel C763L | Rythmik FV15HP x2
Living Room - LG OLED 65" | Yamaha 2060 | Monolith 3x200 | KEF Q900 L/R | Paradigm Millenia 20 CC | Polk Surrounds | Monolith 12" Subs x 2
nonstopdoc1 is offline
post #2 of 9 Old 10-22-2019, 11:52 AM
qirex's Avatar
Quoted: 169 Post(s)
Liked: 139
The two outputs thing reduces the field significantly. I usually recommend the JDS EL DAC for people who want a standalone but it only has one out. If you're open to a combo DAC/headphone amp/pre out unit with volume control they sell the Element. A pro option would be the Mackie Big Knob studio but it's not much to look at.
qirex is offline
post #3 of 9 Old 10-23-2019, 04:02 AM
glangford's Avatar
Quoted: 736 Post(s)
Liked: 648
I'd check out Schiit dacs.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #4 of 9 Old 10-23-2019, 09:47 AM
mlknez's Avatar
Quoted: 505 Post(s)
Liked: 162
check out the new ifi zen dac
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is online now
post #5 of 9 Old 10-23-2019, 07:14 PM - Thread Starter
Quoted: 619 Post(s)
Liked: 160
I like the looks of JDS Element but in its case you have to manually switch between headphones and RCA out with a button on the back which is going to be cumbersome in my usage. Thanks for the suggestion!
My Build Thread
post #6 of 9 Old 10-23-2019, 07:14 PM - Thread Starter
Quoted: 619 Post(s)
Liked: 160
Thanks!. Will checkout both.
My Build Thread
post #7 of 9 Old 10-24-2019, 02:09 AM
Roseval's Avatar
Quoted: 69 Post(s)
Liked: 47
Roseval is offline
post #8 of 9 Old 10-24-2019, 10:36 AM
Quoted: 274 Post(s)
Liked: 75
Why not connect your equipment in parallel to a single out?
aats is offline
post #9 of 9 Old 10-24-2019, 06:49 PM
Gyroscopics's Avatar
Quoted: 213 Post(s)
Liked: 278
I currently use SMSL SU-8 v2 DAC to feed my THX 789 (via XLR) and Loxjie P20 (via RCA). The XLR and RCA output from SU-8 are always on so you won't have the issue you mentioned about switching outputs via the menu. Permanently connect the XLR output to the THX789 and the RCA output to your powered speakers. I have plans to buy the Topping D70 in the future for my 2ch speaker system, but I'm quite satisfied with the SMSL SU-8 v2 and the Topping D50 currently used in my 2ch speakers.
nonstopdoc1 likes this.
Gyroscopics is offline
Reply 2-Channel Audio
