What receiver to buy next? - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 1 Post By Jawaburger
  • 2 Post By Ratman
  • 1 Post By Alex F.
  • 1 Post By Keller
  • 1 Post By KenM10759
  • 1 Post By pjp
  • 1 Post By Keller
post #1 of 18 Old 10-23-2019, 09:26 AM - Thread Starter
Liked: 0
I have been thinking about buying a new receiver for two reasons:
1) I'm currently using an Optimus STAV-3690 from 1998 and my assumption is that if I buy a high end brand, newer receiver, I'll get better sound.
2) I assume something that can stream music directly without Bluetooth reliance will sound better. I play a lot of vinyl, but I also will stream Amazon Music via my phone through a $25 Bluetooth receiver connected to my receiver with A/V jacks.
I've been eyeing receivers like a Denon DRA-800h or Onkyo TX-8270. Both meet my 2 criteria above, but I wonder if I would be better off buying a separate streaming music player and/or buying a more expensive receiver? And will either really produce a noticeable sound difference just because they are 20 years newer and a "better brand?"
I'm a big "the proof is in the pudding" guy and don't really understand what it is about a more expensive receiver that would produce better sound and hate that I can't easily try different receivers in my with my current setup to see if I can tell meaningful differences. I'd be happy to pay an additional 500 or 1000 bucks if it could lead to a "wow! I can really hear the improvement!" moment, but feel like a lot of audio talk online is driven by hype and the satisfaction of knowing you own a really expensive setup - regardless of an objective quality increase.
Any thoughts or advice?
Andrew Jensen is offline
post #2 of 18 Old 10-23-2019, 09:32 AM
Jawaburger's Avatar
Quoted: 210 Post(s)
Liked: 207
If you are unhappy with the sound you are getting, a much better investment would be new speakers and/or acoustic treatments in your listening room. There has not been any significant new technology in amplifiers for a long time.
Perhaps if you are looking for a receiver/integrated amp that has built in digital streaming apps and networking capabilities it would make sense to update your receiver.
Keller likes this.
Sharp LC-80LE844U | Marantz BD8002 | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | Phase Tech PC 9.1 (FL/FR) | Phase Tech PC 3.1 (C/SL/SR) | Dual PSA S1811 Subs
Jawaburger is offline
post #3 of 18 Old 10-23-2019, 09:41 AM
Ratman's Avatar
Quoted: 2402 Post(s)
Liked: 2241
IMHO... as long as everything works, keep what you have and just add a "streaming device".
Newer does not necessarily mean "better sound".
pjp and SmittyJS like this.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #4 of 18 Old 10-23-2019, 11:41 AM
pjp
pjp's Avatar
Quoted: 648 Post(s)
Liked: 440
I would not get a receiver with built-in streaming. Receivers and integrated amps never go out of date, but any streaming built into receivers and amps will become outdated within a few years. Even if the receiver/amp's could be updated to keep them current, most manufacturers stop producing firmware updates for older models not long after newer models come out. Standalone streaming devices are likely to have updates for much longer update periods (usually forever) and can later be replaced inexpensively later if they ever do go out of date.
Newer is not always better, sometimes it's worse. I would just add streaming to the front-end of your Optimus. If you have the "upgrade itch", given that streaming can be external to the receiver, I would add a vintage receiver to the realm of possibilities. Some inexpensive vintage receivers like the Harman Kardon 330a and 330b with capacitor-coupled outputs are very highly regarded for sound quality. I haven't seen anybody test a 330a against a modern receiver, so I can't say how they compare. Even better is the HK 430, with "dual mono" internal amps and power supplies. The more powerful and more expensive HK 730 (also dual mono), by some accounts, does not sound as quite as good as the 330 and 430, so "more" is not always more.
pjp is offline
post #5 of 18 Old 10-23-2019, 11:42 AM
qirex's Avatar
Quoted: 170 Post(s)
Liked: 140
I've owned the Integra version of the 8270 for almost 2 years and it works and sounds great. Direct streaming is handled through the Onkyo app which is ok but not amazing, but you can also chromecast or airplay to it from a device. One other caveat is if you want to use it for audio only you'll probably want to connect it to a TV to get it set up, the on-unit menu system would be a real pain to navigate.
Happy to answer any questions you have about it.
qirex is offline
post #6 of 18 Old 10-23-2019, 02:07 PM
_tk
Quoted: 567 Post(s)
Liked: 252
I've always thought that (most) A/V receivers were a bit compromised in the 2-channel department. And some older ones are especially "odd" when it comes to setting the sound how you want and avoiding any DSP coming into play. I'm in the camp that looking at something new and dedicated to 2-channel might not be a bad thing.
In reality, a $499 receiver, streaming or not, is not a hugely expensive purchase. I personally would choose to purchase an integrated without streaming on it, but that's me. I get the convenience of having everything in one unit, but who knows if the app to run said receiver will still be going 3-5 years from now.
If you are down to the Denon or the Onkyo, I'd go Denon personally. But I'd also take a hard look at amps that don't have streaming built in.
And if you value sound quality, stay away from bluetooth.
If it were my $500-$1K, I'd take a look at something like the Marantz integrated amps that are made in Japan (PM7005, PM8006). There are a lot decent choices in that range.
_tk is online now
post #7 of 18 Old 10-23-2019, 03:22 PM
Alex F.'s Avatar
Quoted: 915 Post(s)
Liked: 533
I have not heard one, but within your stated price range the Outlaw RR2160 stereo receiver ($849) is often recommended here. They sell directly to customers. Links:
http://www.outlawaudio.com/products/rr2160.html
http://www.outlawaudio.com/support/faq_ordering.html
leecreek likes this.
Music room: Cary SLI-80 tube integrated amplifier, McIntosh MA6500 integrated amplifier, Quad 99 preamp, Quad 909 power amp, Acoustic Research AR9 loudspeakers, Yamaha CD-N500 CD player, Teac UD-503 DSD DAC, Phase Linear 8000II linear-tracking turntable.
Theater room: Panasonic 65S60 plasma television; Yamaha RX-A2020 (preamp section); Adcom GFA-5503 and GFA-5400 amplifiers; Polk LSi25, LSiC, and LSiF/X loudspeaker system; Velodyne FSR-18 servo-subwoofer.
Alex F. is offline
post #8 of 18 Old 10-23-2019, 04:15 PM
Keller's Avatar
You don't mention your speakers, but speakers are far and away the most impactful on the sound. In your quest for improving your setup, this is what you should be focusing on and putting most of your money into. Then compliment with a competent 2 channel integrated amp.
Excellent deals on amps here:
https://www.accessories4less.com/mak...ed-amps/1.html
Yamaha and Marantz make excellent choices.
There are economies of scale in your favor for home theater amps used as 2 channel. Denon in particular is known for making excellent receivers. Something like the Denon AVR-X series are well regarded (ie. AVR-X1400H here for under $300) would likely be a noticeable step up from what you have for a reasonable cost.
https://www.accessories4less.com/mak...ceivers/1.html
However, speakers are what is going to make the difference you are looking for. If you want to go down that route, ask again and luckily there are many good choices starting under $500.
vzphoneman likes this.
Allo Digione > Topping DX3PRO > Cambridge Audio CXA60 > Ascend Acoustics Sierra 2 > Martin Logan 800x (x2)
Keller is offline
post #9 of 18 Old 10-26-2019, 05:55 AM
KenM10759's Avatar
Quoted: 3453 Post(s)
Liked: 1932
I respectfully disagree.
Something like the NAD C368 integrated amp with the MDC BluOS 2i module for streaming would not go obsolete because it's continually receiving free firmware and app updates. Should the day come that a streaming technology becomes so advanced that the hardware of that module wouldn't work, NAD would make available a newer, updated module. They did this most recently with the module I mentioned because it didn't have the chip required by Apple for Airplay 2 to work..
That integrated amp can be had (in the US) from Safe & Sound for $649 as a factory refurbished, for $895 with the previous (non-Airplay 2) module, or buy without a module add the latest module for $449.
https://www.safeandsoundhq.com/colle...ry-refurbished
https://www.safeandsoundhq.com/produ...a0a82d12&_ss=r
Nothing wrong with going with a more modern unit, they sound fantastic IMO.
BTW, with the BluOS module it streams via wireless or Ethernet directly, and though it has Bluetooth that wouldn't be needed. Control is via any computer, phone or tablet and it streams myriad services (including Amazon Music HD) without need for any other DAC or device of any kind. Add a MDC PP375 and have full phono capability for both moving magnet and moving coil cartridges.
pjp likes this.
KEF R500, R200C, R100, R50, SVS SB2000 sub, NAD T758v3 AVR, LG UP875 4K BlueRay, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer. Office: NAD M10, KEF LS50, KEF Kube 10b, Pro-Ject RPM1 TT w/ Ortofon 2M Red. Guest room: Hafler 300 L-R, KEF Reference Model 100 center, KEF iQ10 surrounds, modded M&K V-90 sub, Bluesound Vault 2.
KenM10759 is online now
post #10 of 18 Old 10-26-2019, 06:41 AM
pjp
pjp's Avatar
Quoted: 648 Post(s)
Liked: 440
I mostly agree with you in this very specific case because Bluesound is providing the streaming within the NAD amp. Because Bluesound is a streaming platform, I agree it is much more likely to be updatable for much longer periods of time just like their standalone streaming devices. For most manufacturers and models, the built-in streaming is their own proprietary implementation and they go out of date quickly. There is no reason for them to go out of date hardware-wise, but firmware updates from most manufacturers stop very quickly for older models as soon as newer models come out. To me, absent a scenario like NAD/Bluesound, built-in streaming is a dead end if you like to keep equipment long term.
Regarding internal upgradable hardware futureproofing promised by manufacturers for amps/receivers, I've seen very few of those work out in practical terms. Usually, they can be upgraded later as promised, but the cost of those upgraded boards usually turn out to be very expensive in many manufacturers -- often it costs the same or close to the same to upgrade internal boards as it is to buy a new unit. It sounds like NAD may be an exception, but that has been my general experience.
If the OP really wants, or only has space for, a single unit with everything built-in, then you have to go with built-in and the NAD seems like an almost uniquely solid recommendation (great value also).
For vintage versus modern, I won't push hard either way, my only point is that if streaming is external, it opens up a whole realm of possibilities of what to use for a receiver. I have a vintage receiver that I am literally thrilled with the sound of, but my observations are not scientific since I haven't tested side-by-side with a modern receiver. I'm curious enough that I would love to do that test myself, but it's logistically difficult to pull off and I don't have a new receiver on hand or the spare time to do it. I would love to see somebody do a test between a highly regarded vintage receiver and a modern stereo receiver -- haven't seen anyone do that comparison.
KenM10759 likes this.
pjp is offline
post #11 of 18 Old 10-26-2019, 09:43 AM
qirex's Avatar
Quoted: 170 Post(s)
Liked: 140
I've been shocked by the number of updates my DTM-7 has received but the platform is almost 3 years old at this point so I'm not sure how long that will continue. They haven't announced support for Amazon's new high resolution service (it does play normal Amazon Music) but they've added Airplay 2, Dolby Vision pass-through, sound quality improvements, Tidal Masters MQA, "works with Sonos," Deezer, Chromecast, Play-Fi, etc.
That all said I still usually use my Sonos Connect to play my local music because the app is much better than Integra ControlPro and I can do whole house, er, apartment. If you're not invested in high resolution music Sonos still has the edge in price, reliability and ease of use over Bluesound in my opinion. Bluesound obviously has the high resolution support, the individual powered speakers are a bit more capable plus it works with Roon.
qirex is offline
post #12 of 18 Old 10-27-2019, 07:45 PM
Keller's Avatar
https://www.audiosciencereview.com/f...amplifiers.47/
pjp likes this.
Keller is offline
post #13 of 18 Old 10-27-2019, 08:24 PM
pjp
pjp's Avatar
Quoted: 648 Post(s)
Liked: 440
Originally Posted by Keller View Post
Awesome!!!! Looks like a very cool website. I'd love to see listening tests, in addition to specs. That said, on specs, the 42-year-old unrestored Yamaha A1 kicks the crap out of modern amps in most respects -> https://www.audiosciencereview.com/f...r-review.9576/
I'm not surprised. I'd love to see them test my 1972 Rotex RX-400.
pjp is offline
post #14 of 18 Old 10-28-2019, 08:20 AM
Quoted: 569 Post(s)
Liked: 295
Interesting thread. I am not seeing HEOS mentioned here -although you are looking at the DRA 800H.
Question: if you are so concerned about fidelity, why are you insisting on using blue tooth? I am of the opinion that (audio) friends don't let friends use BT! At least in a "permanent" set up ( BT has its place, but in not a home audio set up where fidelity is important).
There are plenty of streamers that can be had inexpensively.
You can get a HEOS link ( preamp) used via ebay for typically less than 200 ( 349 new. same as Sonos connect) . Or a play -fi streamer can be had via amazon for ~30 ( Phorus pr5, Klipsch gate).
Both HEOS and Play-fi can stream from your NAS. HEOS supports higher bit rates than Sonos.
But to answer the broader question of "should you consider a unit with built in streaming"? I say, yes. However, this is based mostly on the convenience-of-control factor, as well as an outward sense of simplicity(everything is in the case).
As for sound quality, well, that's another thing...can you perceive an audio/audible difference between a modern unit and a vintage unit? Only your ears can tell.
hope it helps
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #15 of 18 Old 10-28-2019, 08:22 AM
Super Moderator
DrDon's Avatar
Quoted: 2321 Post(s)
Liked: 4405
title edited
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #16 of 18 Old 10-29-2019, 06:46 AM
djp2k7's Avatar
Quoted: 369 Post(s)
Liked: 305
It sounds like music sound quality is important to you. I've had a handful of receivers and integrated amps over the last 8 years or so, from $600 Denons and Yamahas to $2000+ Marantz models. If I were in your shoes now I'd get the Yamaha A-S501 or Cambridge Audio CXA-60 paired with the Bluesound Node 2i streamer. The Node 2i is a great device for $500. Streaming, DLNA, Aptx BT, and USB for thumb drives.
ADS L710 / PSB Alpha B / HIFIMAN HE400i / Martin Logan Dynamo 300 Sub
NAD 720Bee / Schiit Modi 3 / Yamaha CD-S300 / XBOX One X
djp2k7 is offline
post #17 of 18 Old 11-04-2019, 02:36 PM
bluewizard's Avatar
Quoted: 2328 Post(s)
Liked: 1542
It is hard to predict what will give you specifically the WOW factors, but I can suggest a few Network Receivers in your price range that are worth looking at.
Outlaw Audio is very well regarded and certainly worth a look. It does have Streaming but I'm not sure of the degree to which it is implemented, I will leave that aspect to others with more direct experience -
Then there are two Yamaha Network Receiver at least worth checking out -
https://www.crutchfield.com/p_022RN6...ha-R-N602.html
https://usa.yamaha.com/products/audi...602/index.html
https://www.crutchfield.com/p_022RN8...ha-R-N803.html
https://usa.yamaha.com/products/audi...803/index.html
The Yamaha RN803 Network Receiver is in essence a 2.1 Channel AV Receiver minus the HDMI inputs. It has Full Bass Management and Room-EQ capability with a solid 100w/ch to 8 ohm.
The Optimus STAV-3690 does not appear to have been anything unusual, pretty much just a standard consumer grade AVR.
http://www.manualsdir.com/manuals/20...0.html?page=30
From what I read, this is a re-badged Pioneer Receiver.
If you really want to climb to the top of the mountain, then consider this considerably more expensive Amp -
https://www.crutchfield.com/p_410SR2...cam-SR250.html
Also, can you tell us what speakers you are using or will be using with the new Amp/Receiver?
Steve/bluewizard
bluewizard is offline
post #18 of 18 Old 11-04-2019, 02:47 PM
bluewizard's Avatar
Liked: 1542
As someone else mentioned, you could combine the Yamaha Integrated Amps (AS501, AS701, and AS801) with a separate Network Streaming device -
Yamaha AS501 Integrated w/DAC, 85w/ch - $550 -
https://www.crutchfield.com/p_022AS5...01-Silver.html
Yamaha AS701 Integrated w/DAC, 100w/ch - $800 -
https://www.crutchfield.com/p_022AS7...01-Silver.html
Yamaha AS801 Integrated w/Better DAC w/USB-PC, 100w/ch - $900 -
https://www.crutchfield.com/p_022AS8...01-Silver.html
Here are all Yamaha Amps and Receivers with full specs -
https://usa.yamaha.com/products/audi...nts/index.html
Here is Yamaha's Network Streamer - WXC-50 - $350 -
https://www.crutchfield.com/p_022WXC...ha-WXC-50.html
https://usa.yamaha.com/products/audi...-50/index.html
Here is the Bluesound Note-2i Network Streamer - $550 -
https://www.crutchfield.com/p_813NOD...-2i-Black.html
Steve/bluewizard
Reply 2-Channel Audio
