Recommend me an option to buy - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By Leeliemix
  • 1 Post By Trunksleo
post #1 of 13 Old 11-12-2019, 08:40 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 8
Hi im looking for a stereo receiver or integrated amplifier mqa capable and ht bypass. I will connect to my marantz with pre outs for front speaker.
There is an other option to go to a integrated amplifier with ht bypass and add some mqa capable dac like pro ject pre box s2 digital or the bluesound node 2i.
There is something like im looking for??
Trunksleo is offline
post #2 of 13 Old 11-13-2019, 03:28 AM
glangford's Avatar
Quoted: 743 Post(s)
Liked: 657
Using google I found this list of integrateds that support MQA. They are: Bel canto blue sound, cary audio, Hegel, Krell, mark Levinson, NAD, Technics.
List was here:
https://www.mqa.co.uk/how-to-get-mqa
Most of these are pretty expensive, NAD, is probably most affordable. I didn't take the next step and go look up which of these supports HT bypass. Google is your friend.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is online now
post #3 of 13 Old 11-13-2019, 03:38 AM
Menarini's Avatar
Quoted: 894 Post(s)
Liked: 402
Does MQA make a real difference to music or it's just a certification label?
Menarini is offline
post #4 of 13 Old 11-13-2019, 05:46 AM
Quoted: 376 Post(s)
Liked: 206
Its lossy...
Personal opinion: when they do a good job remastering or using a good master it is good but that would be good on normal cd also, not to mention actual lossless high rez files.
It might be well meaning but its still a money grab in all links of the chain for a copy protection no consumer wants without actually giving us true high rez. We dont really need high rez above cd/dvd, what we need is quality work from recording/mastering/production. Really well made CDs sound incredible, better than mqa and high rez from most masters where they didnt do a really good job, which is most of them unfortunatly.
Leeliemix is offline
post #5 of 13 Old 11-13-2019, 10:33 AM
Quoted: 289 Post(s)
Liked: 80
Probably it will have some "exclusive" releases to lure people into it, so yes, it might if you want those releases.
aats is offline
post #6 of 13 Old 11-13-2019, 11:28 AM
Matthew Pool's Avatar
Quoted: 157 Post(s)
Liked: 46
The new Arcam SA30 has MQA, HT bypass, and Dirac Live room correction.
KEF R3 L/R | Dual Rythmik F12SE | 2.2 | Yamaha RX-A2080
Matthew Pool is offline
post #7 of 13 Old 11-13-2019, 06:42 PM
citizen arcane's Avatar
Quoted: 529 Post(s)
Liked: 20638
Hear, hear!
¿lɐɯɹou ǝq ʎɥʍ
citizen arcane is offline
post #8 of 13 Old 11-13-2019, 06:47 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 8
Thanks, but i dont tell my budget, its up to 1000u$s dolars
Matthew Pool likes this.
post #9 of 13 Old 11-14-2019, 12:46 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 8
Its lossy...
So you think that i will have a better improvement on the sound if i make an upgrade of my bookshelfs instead of add mqa hardware?
My room its 10ftx12ft
I also was looking for this floorstandings
Monitor Audio Silver 6
Psb imagine xt1
Kef q700
Only for 2.0 music.
Connected to yamaha rs700
post #10 of 13 Old 11-14-2019, 01:42 PM
Quoted: 376 Post(s)
Liked: 206
Psb imagine xt1
Kef q700
Only for 2.0 music.
A nice integrated with HT bypass might be a good upgrade mqa or not. Im not sure what speakers you have currently so its hard to say, i really like good electronics but speakers do make the biggest difference so i suppose it depends on how you like your speakers because an actual upgrade might be the more expensive option and a sidegrade is usually wasted money.
post #11 of 13 Old 11-14-2019, 01:52 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 8
Actually i have a marantz 5012 connected to the main in of the yamaha rs700. My front speakers are jamo c93.
post #12 of 13 Old 11-24-2019, 03:57 PM
Craig Morris's Avatar
I’m considering the Anthem STR Integrated to do similar to what you’re proposing. It has HT BYPASS, the most sophisticated 2 channel implementation of ARC room correction, and tons of power. I’m considering swapping my Sonos Connect for the Node 2i.
Craig Morris is offline
post #13 of 13 Old 11-25-2019, 03:42 AM
glangford's Avatar
Quoted: 743 Post(s)
Liked: 657
If the OP's budget it up to 1000 dollars, then the Anthem STR is out. It's a bit over 4 grand.
Reply 2-Channel Audio
