Speaker Cables & Interconnects - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 214Likes
post #331 of 349 Old 12-02-2019, 10:50 PM
alan0354's Avatar
Quoted: 1831 Post(s)
Liked: 447
BTW, I never mention, I have THOUSANDS of exotic cars like Lamborghini, Ferrari, Aston Martins, Porsche, Bugatti and many many more, I can tell you they are no better than Ford Mustang GT after driving them. Most of them are not as reliable as the Mustang and most don't even seat 4. But I just keep buying them, I can't help it.
Own designed power amp, own designed preamp, JM LAB Spectral 913.1 speakers, Rythmik F12SE sub.
Not hooked up: Nakamichi Stasis PA-7 power amp, Velodyne VA1210 sub, Kef Reference Series center, Kef Bookshelf speaker, Monitor Audio bookshelf speaker, Infinity rear speakers. Acurus 3X200W amp.
alan0354 is offline
post #332 of 349 Old 12-02-2019, 11:47 PM
alan0354's Avatar
Liked: 447
Originally Posted by bear123 View Post
For amp designers, I wouldn't trust a guy who doesn't believe in blind testing of products enough to spend $1 with him. But I would trust the guy who built a reasonably priced amp that produces 185 watts with .0001% distortion. It's the Benchmark AHB2, and its only $2995. But that would probably rule it out as a true audiophile amp for alan0354 since its not $10,000. What a joke. I'd also buy an amp from the guy who designed the HypexNC400 and NC500 modules since they also measure better than just about any amp made, and cost half what the benchmark does for 3 channels vs 2, and with a lot more power to boot.
Anyone interested in the facts about these amps, check out their detailed independent reviews on audiosciencereview. If you want some audiophile tomfoolery about how they improve soundstage and imaging or any other such baloney, definitely DO NOT check them out. Only facts here.
And anyone who talks about how an amp improves soundstage, imaging, etc, is absolutely deluded. The only things that have any affect on that, at all, are the speakers, the recording, and the room and placement.
An amp affects soundstage and imaging????...ok folks, time to move on.
Where did you get the idea I said $3000 is cheap? My amps are $1000 each as I designed and built it. As for AHB2, I don't know how they get 0.0001% THD, but it's only at 1KHz. I only achieved 0.0005% with 4ohm load ( should be like 0.0003% with 8ohm). But the damping factor at 20KHz of the AHB2 is way less than good, it's only [email protected]. This means the output impedance is 8/34=0.235ohm. That's very high. THD needs to measure at the speaker input, any amp measures a lot better if using a 8ohm resistor load. Notice other than damping factor, there is no spec at higher frequencies?
https://benchmarkmedia.com/products/...ower-amplifier
They did not spec THD at 5KHz, 10KHz, 15KHz and 20KHz.With damping factor of [email protected], THD is going to be sky high with real speaker measuring at the speaker input terminals.
See, you really have to know what you are talking to quote the technical spec.
My new amp is low power, it measured 0.0014% THD @20KHz, less than 0.001%@10KHz at 60W output into 4ohm. Damping factor is over 600 @ 20KHz.
BTW, what is your system so we can put it in perspective.
alan0354 is offline
post #333 of 349 Old 12-03-2019, 02:33 AM
C'mon fellas... I'm running out of popcorn...
Jonas2 and Frostyboy115 like this.
Main system: NAD C 658; Emotiva Stealth PA-1 x2 monoblocks; Monitor Audio Gold 100 5G spkrs. Sources: Cocktail Audio X10; Sony UHP-H1. Cables: Mark Grant Cables (analogue ICs); Atlas Cables (coax); QED (optical); Fisual S-Flex 2.5mm OFC (speakers).
RockAddict is offline
post #334 of 349 Old 12-03-2019, 03:16 AM
bear123's Avatar
Quoted: 2834 Post(s)
Liked: 4320
I have Dayton Audio B652 for LCR, Micca Covo-s for surrounds, and a Dayton Sub-800 to handle the low stuff. AVR is Yamaha RXV-375. Its a pretty sick setup! I have crazy good speaker cables too! I forget which brand cable lifts I'm using.
m. zillch likes this.
bear123 is offline
post #335 of 349 Old 12-03-2019, 07:13 AM
3db
3db's Avatar
Quoted: 686 Post(s)
Liked: 457
So you admit you don't have the high end gear, and you believe that you test the best of the best speakers with one speaker and ABX by recording the best of the best amps at the output and play it back on another system?
I don't care you even read this, I want other people to read this and decide whether they trust this or not.
I for one trust Charles. Unfortunately I cannot say the same thing about you. You absolutely refuse to see that somehow in your breadboard experiments, you and your friends got biased towards one component over another. You also refute that there is a limit in human hearing with 0.5 db being the limit of detectable change. Hearing memory accuracy is also only accurate for up to a minute at best which has been proven many times over and independently of Doc Toole but you also don't accept that premise. Audio is about science and measurements and not alchemy.
AVR Yamaha RX-V 1800/1900/1500
TT/Cassette ProJect Xpression III/Yamaha KX1200/KX800
BR Yam. BD-S681/Sony X800/Pan. BD30 DPL Sam. 65"/ 55"/50"
Speakers PSB T-45,8C,1B/ PSB 500,200C,RBH A600/Alphas
Subs Rythmic LV12-R/PSB Subsonic 6/5
3db is offline
post #336 of 349 Old 12-03-2019, 09:18 AM
Out-Of-Phase's Avatar
Quoted: 341 Post(s)
Liked: 308
"And the reason I spent so much money on electronics because I used to think I could hear differences."
Beautifully said.
There's an old phrase, "open your eyes".
But when it comes to comparisons between various audio components, "close your eyes" instead.
Cognitive bias in the brain is real and it influences our perceptions.
m. zillch and 3db like this.
Save your money.
Out-Of-Phase is offline
post #337 of 349 Old 12-03-2019, 09:19 AM
m. zillch's Avatar
Quoted: 5546 Post(s)
Liked: 3986
HA. Good one "cable lifts". Are they gold plated and cryogenicly treated? Sounds like a good start but maybe you should buy a magic brick to place on top of your system which "experts" like Paul McGowan, the head of PS Audio, tells us makes a real difference:
"Oh my goodness. It worked, and not just a little. The Brick opened up the soundfield, separated the instruments and singer from each other and, best of all, it was repeatable. On; magic happened. Off; we went back to what was."
Source.
Good thing he uses protocols to preclude cognitive bias and applies statistical analysis to his results. . . oh wait, never mind, he doesn't.
m. zillch is offline
post #338 of 349 Old 12-03-2019, 09:21 AM
Quoted: 341 Post(s)
Liked: 308
OMG. He should write for Stereophile.
m. zillch, RUR and 3db like this.
Save your money.
post #339 of 349 Old 12-03-2019, 09:25 AM
m. zillch's Avatar
Liked: 3986
He'd be in good company because both believe green magic marker ink placed on the circumference of a CD improves the sound.
It astounds me how many people cite him as an expert.
3db likes this.
post #340 of 349 Old 12-03-2019, 09:28 AM
Ratman's Avatar
Quoted: 2441 Post(s)
Liked: 2282
"You’d think after some of these eye openers I’d have changed my ways; become more accepting of change I don’t understand. But no, I am still resistant to that which makes no sense.
Even when it works."
[quoted from same source/link in the previous post]
So... sell 'em if ya got 'em!
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #341 of 349 Old 12-03-2019, 10:28 AM
alan0354's Avatar
Liked: 447
Now, this put into perspective. Nothing wrong with your system, just how do you judge the good system?
alan0354 is offline
post #342 of 349 Old 12-03-2019, 10:30 AM
alan0354's Avatar
Liked: 447
I am sure you trust him and the few others, you all trust
1) Testing the best of the best speakers with ONE speaker.
2) ABX the best of the best amps by recording it's output and play it back on a totally different system.
alan0354 is offline
post #343 of 349 Old 12-03-2019, 10:38 AM
alan0354's Avatar
Liked: 447
Who gives you the idea that I refute this? I said you can hear the difference in sound quality even if the volume is no perfectly matched.
Speak for yourself and the few people that don't have ears. I have friends that can pin point the exact device few months apart. You are not a musician, you don't have the ears. You cannot even imagine how good the ears some people can have.
Ah, him again. I just wonder if he work for a high end speaker company instead of some mid-fi company, what would he say then............."Ah, I see the light, now, I have scientific proof that you have to have two speakers to separate the good and not so good speakers"
Like I said, when Consumer Reports gave bad rating to speakers from harmon, harmon SENT HIM to Consumer Reports to "TEACH" them the "RIGHT" way to listen to speakers to get a better rating of harmon speakers.
alan0354 is offline
post #344 of 349 Old 12-03-2019, 11:07 AM
CharlesJ's Avatar
Quoted: 817 Post(s)
Liked: 586
Good thing there is a pause button so you won't miss out while you run down for more. Buy it by the box full.
RockAddict likes this.
CharlesJ is offline
post #345 of 349 Old 12-03-2019, 11:10 AM
CharlesJ's Avatar
Quoted: 817 Post(s)
Liked: 586
... Audio is about science and measurements and not alchemy.
I thought for a minute there may be a revival, new life, in alchemy.
CharlesJ is offline
post #346 of 349 Old 12-03-2019, 02:03 PM
3db
3db's Avatar
Quoted: 686 Post(s)
Liked: 457
FADs come and go
3db is offline
post #347 of 349 Old 12-03-2019, 02:10 PM
3db
3db's Avatar
Quoted: 686 Post(s)
Liked: 457
Show me the article.
You keep reading your CR They are the least qualified to evaluate speakers. "Hmmmm the vinyl wrap wasnt applied evenly so we'll score the speaker a 4 out of 10 " despite the speakers having the most linear response and best off axes response. After all vinyl is king, right?
Paul Barton the founder of PSB was a concert violinist so he knows all to well about tone, pitch and realism. Yet he subscribes to Dr Toole's work and agrees whole heartedly with Tool's testing philosophy and he believes in the measuring of mono speaker in an anoechic chamber.
CharlesJ likes this.
3db is offline
post #348 of 349 Old 12-03-2019, 02:27 PM
3db
3db's Avatar
Quoted: 686 Post(s)
Liked: 457
I vaguely remember this event but i remember it totally different than you. Dr Toole went to CR to teach them how to properly evaluate speakers and to look beyond the vinyl wrap.
Here's a discussion from another forum about CR speaker measurements.
http://forums.audioreview.com/speake...ngs-13445.html
It appears that CR is out of their league when it comes to understanding speakers.
Here's a score report from CR that gives the #2 spot to a pair of Bose301 Series IV speakers. Bose is HIFI alright and it just goes to show how far out of their league CR is when it comes to testing speakers.
https://www.hometheaterforum.com/com...-ratings.8047/
As to auditory memory accuracy... No Toole hear but hear you go anyway
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC2667065/
3db is offline
post #349 of 349 Old 12-03-2019, 04:00 PM
bear123's Avatar
Liked: 4320
Source.
bear123 is offline
Reply 2-Channel Audio
