Can I get a center speaker out of my 2.1 setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-23-2019, 07:18 PM - Thread Starter
Liked: 0
Just a thought I had. Don't know much about speaker wiring. Wondering if this would harm anything?
ID:	2658140   Click image for larger version
ID:	2658142   Click image for larger version
timgustin96 is offline
post #2 of 10 Old 12-23-2019, 07:25 PM
Kal Rubinson's Avatar
Quoted: 1399 Post(s)
Liked: 1351
Not entirely clear but not likely. You cannot connect the outputs to the L/R speakers to each other to make a "center" channel. Also, by shorting them together, you will lose any separation between L/R and all speakers will play mono.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 10 Old 12-23-2019, 07:32 PM - Thread Starter
Liked: 0
Thanks! Saved me the time.
post #4 of 10 Old 12-24-2019, 06:20 AM
Wayne A. Pflughaupt's Avatar
Quoted: 468 Post(s)
Liked: 390
Probably saved your amp, too. I’m pretty sure that shorting two output channels together (which is ultimately what you’re accomplishing) will do nothing good for it.
Wayne
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #5 of 10 Old 12-24-2019, 08:06 AM
Liked: 1351
I cannot be certain but it looks like he is splicing amp inputs.
Kal Rubinson
post #6 of 10 Old 12-24-2019, 11:28 AM
gajCA's Avatar
Quoted: 9547 Post(s)
Liked: 6589
What receiver or amp are you using.
If it has pre outs/main ins you can do what I did in my secondary room as I had an old amp laying around.
Pre outs to outboard amp, outboard amp in mono bridged mode back to receiver which drives the left and right.
Added a center speaker with the outboard amp that plays in mono.
Works well in 3.2 and to listen to music in stereo just turn the gain down on the outboard amp.
Geoff A. J., California
gajCA is offline
post #7 of 10 Old 12-24-2019, 03:30 PM
m. zillch's Avatar
Quoted: 5775 Post(s)
Liked: 4114
Although it was written about car stereo, the methods described in this article can be used at home too:
How To Install A Center Channel
m. zillch is offline
post #8 of 10 Old 12-24-2019, 04:55 PM
Liked: 1351
Just to be clear. You can derive a signal for a center speaker but it is not really a center channel source. If it works for you or you need it, OK.
Kal Rubinson
post #9 of 10 Old 12-24-2019, 10:31 PM
3db
3db's Avatar
Quoted: 696 Post(s)
Liked: 477
What are you trying to achieve? A center channel in the AVR world is in itself another channel separate just like the keft or right channel of a stereo. It carries unique information to it alone along with common information from either left or right channels or both left and right.
3db is offline
post #10 of 10 Old 01-01-2020, 10:35 PM
RayGuy's Avatar
Quoted: 3089 Post(s)
Liked: 2884
You cannot just connect stuff up and call it a center channel. You must have the receiver that can process the center channel separately from the L&R channels. In order to do this, you need a 5.1 channel home theater receiver and a source that has the channels encoded separately. If your receiver is just a stereo receiver, forget it, because you won't end up with what you want (but you will probably end up with a smoking and dead receiver).
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
Reply 2-Channel Audio
