Best WiFi/Bluetooth streamer for Outlaw RR2160? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By hpp8140
post #1 of 7 Old 12-27-2019, 10:18 AM - Thread Starter
activestatic's Avatar
Quoted: 28 Post(s)
What’s the best WiFi and or Bluetooth streaming device for the Outlaw RR2160?
activestatic is online now
post #2 of 7 Old 12-27-2019, 10:35 AM
qirex's Avatar
Quoted: 195 Post(s)
Liked: 157
For what value of "best?" What's your budget? What devices are you using? Local music or all streamed? Are you planning on using the 2160's DAC? You do know wifi and bluetooth aren't interchangeable, right?
Short list off the top of my head would be the Bluseound Node 2i, the Sonos Port if you don't need high res or the Cambridge CXN v2 if you want something that looks like a normal component.
qirex is online now
post #3 of 7 Old 12-27-2019, 11:31 AM - Thread Starter
Quoted: 28 Post(s)
I’m looking for something in the $250 to $500 range. This is to stream from iTunes and Amazon Prime. An iOS app to control everything would be nice. I’m currently using my Yamaha’s Music Cast app and I like it. So something similar in functionality would be nice. I’d be streaming from my iPhone, iPad and laptop but mostly from my iPhone.
post #4 of 7 Old 12-27-2019, 03:23 PM
qirex's Avatar
Quoted: 195 Post(s)
Liked: 157
I use Sonos and the app is nice, especially since they have tablet and desktop apps as well so I can control them from anywhere. Some companies only have phone apps. I don't have experience with the Bluesound system but maybe look for youtube videos that review it and show the interface. I'd say for your budget the Sonos Port and Bluesound Node 2i are pretty much the best options especially with iTunes since they both support Airplay 2.
edit: I just remembered one hardware difference is that Sonos doesn't support Bluetooth while the Node 2i does. not sure that's worth $150 when you can get a separate BT dongle for $50 and connect it directly to your receiver.
qirex is online now
post #5 of 7 Old 12-27-2019, 03:30 PM
postrokfan's Avatar
Quoted: 832 Post(s)
Liked: 6005
There are desktop and phone apps for Bluesound. They work pretty well from my experience.
2-channel: PSB Imagine T, Music Fidelity M2si, B&W ASW610, Rega RP1, Pro-Ject Phono Box, Marantz CD5004, Lenovo Ideapad, AQ DF Red, Zen Blue
Living Room: Deftech Demand D9, Deftech CS9040, SVS SB-1000, Yamaha Aventage RX-A2030
Desktop: KEF Q150, Nuforce DDA-120, Lenovo Ultrabook
BR: MA Silver 2 (5th Gen), NAD 326BEE, B&W ASW608
postrokfan is offline
post #6 of 7 Old 12-27-2019, 03:35 PM
hpp8140's Avatar
Quoted: 368 Post(s)
Liked: 139
https://www.crutchfield.com/p_022WXC...ha-WXC-50.html
activestatic and postrokfan like this.
Paradigm PW AMP, KEF Q100, Emotiva B1, Rythmik L12
hpp8140 is online now
post #7 of 7 Old 12-30-2019, 03:53 PM
crn3371's Avatar
Quoted: 317 Post(s)
Liked: 274
Bluesound Node 2i.
crn3371 is offline
Reply 2-Channel Audio
