DVD - Audio - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By Rgb
  • 2 Post By glangford
  • 1 Post By Rgb
post #1 of 12 Old 01-15-2020, 03:47 AM - Thread Starter
Bndck's Avatar
Question DVD - Audio
Hi guys,
I want to create high quality DVD-Audio from my albums so that I can play them on car DVD player. my audio format is .wav ripped from original CD. can someone recommend me the software to burn Audio - DVD's or the method to do so. I do not want MP3. I want keep Audio Quality as it's original. that's why ripped as wav. I have Cyberlink Power2Go, bue it does not have that facility. advices are most welcome..
Bndck is offline
post #2 of 12 Old 01-15-2020, 04:10 AM
Rgb
Rgb's Avatar
Quoted: 727 Post(s)
Liked: 977
I assume those are wma lossless, or else there would be no point to creating a DVD Audio disc (DVD-A, lossless high res)
Most DVD players can read pictures and mp3/wav files from a Data DVD.
Try burning a DVD Data disc with the files (Wav, flac, wma, etc) you want, albums in folders, and test it in the DVD player
IMGBurn can make Data DVDs
https://www.imgburn.com/
Just drag the wma files onto IMGBUrn gui then burn- set to 4x burn for most reliable/readable in all drives.
Rgb is online now
post #3 of 12 Old 01-15-2020, 04:25 AM
Rgb
Rgb's Avatar
Quoted: 727 Post(s)
Liked: 977
If you want to make a DVD Video music disc with menus showing the songs, Roxio and other commerical apps can do it
http://img.roxio.com/enu/pdf/creator...music-disc.pdf
SuperFist likes this.
Rgb is online now
post #4 of 12 Old 01-15-2020, 07:45 AM
glangford's Avatar
Quoted: 767 Post(s)
Liked: 682
Originally Posted by Bndck View Post
Hi guys,
I want to create high quality DVD-Audio from my albums so that I can play them on car DVD player. my audio format is wma ripped from original CD. can someone recommend me the software to burn Audio - DVD's or the method to do so. I do not want MP3. I want keep Audio Quality as it's original. that's why ripped as WMA. I have Cyberlink Power2Go, bue it does not have that facility. advices are most welcome..
I you specifically want DVD-A format (no video) I use Burn, a free program for Macs.
https://sourceforge.net/projects/burn-osx/
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #5 of 12 Old 01-16-2020, 07:34 AM - Thread Starter
Bndck's Avatar
Angry
Thanks for your advice. I am a windows guy. no alternate for windows ((
Bndck is offline
post #6 of 12 Old 01-16-2020, 10:10 AM
glangford's Avatar
Quoted: 767 Post(s)
Liked: 682
I'd recommend you burn one disc of wma files as a data disc and see if that can be read. The native window SW should do that just fine. I also wouldn't rule out MP3 particularly at a high bit rate like 320 kb. Sure it's not lossless, but to be honest the car is not a great acoustic environment to begin with. I use 256 kb AAC for usb music files in my car and that is just fine. I save lossless and high rez for inside the house.
Ratman and Bndck like this.
post #7 of 12 Old 01-16-2020, 08:39 PM - Thread Starter
Bndck's Avatar
Hi Guys,
Thanks for your advises. as glangford suggests convert to wma is best bet. but can someone suggests me a better converter that converts nearly lossless. My main idea is to keep orginal CD quality in-tact. many thanks
Bndck is offline
post #8 of 12 Old 01-16-2020, 08:47 PM - Thread Starter
Bndck's Avatar
Red face
Hi Rgb,,
yes it should be lossless. correction my current audio format is wav(lossless) rather wma.
Bndck is offline
post #9 of 12 Old 01-16-2020, 10:31 PM
Mike in NC's Avatar
Quoted: 56 Post(s)
Liked: 51
I admire your desire to have great sound in the car. Still, a couple of questions to think about.
1. Actual DVD-A is a dead and rarely supported format. Have you already tested your car player to make sure it can read the DVD-A format? (I know mine won't.)
2. Do you have a VERY quiet car? In mine, I can't tell the difference between a 320 mpg and FLAC at redbook quality. My car player won't do high res, so I can't talk to that. And I should add, at home the difference is very apparent. I have a decent system in a quiet room; but in the car, not so much. So, have you done such a comparison while driving?
I think there is a Windows command-line program that will burn DVD-A format, but no longer have the link to it.
Good luck!
Mike (Portland, Oregon -- Long gone from North Carolina)
Main 2.2 system: Auralic Aries G1 streamer, Anthem STR preamp, Bryston 4B3 amp, Janszen Valentina mains, 2x JL Audio F112 subs. Desktop 2.1 system: JRiver Media Center, Classé CP-800 DAC-preamp, Marsh A400s amp, Harbeth P3ESR, B&W ASW610.
Mike in NC is online now
post #10 of 12 Old 01-17-2020, 05:20 AM
Rgb
Rgb's Avatar
Quoted: 727 Post(s)
Liked: 977
Hi Rgb,,
If CD rips, then they are 44.1Khz. Authoring a DVD requires conversion to 48Khz in general, so the resampling would again defeat the point of lossless.
Just burn a DVD data disc with IMGBurn , putting albums into folders and drag the folders to IMGBurn.
Then try the disc in the car player and see if it recognizes the files/folders and plays wav files.
If it recognizes the disc but does not play wav files, then try flac, alac, aiff lossless formats and as a last resort highest bitrate lossy MP3 or aac.
Rgb is online now
post #11 of 12 Old 01-17-2020, 06:18 AM
Rgb
Rgb's Avatar
Quoted: 727 Post(s)
Liked: 977
Don't know if OP actually meant DVD-Audio
https://en.wikipedia.org/wiki/DVD-Audio
or just a DVD data or video disc with audio files.
Again, simplest path is to try lossless file formats burned as files to a data DVD.
Also Google around for the make/model/year of your car and DVD player- we are assuming the DVD player is integrated into your dash.
Ratman likes this.
Rgb is online now
post #12 of 12 Old 01-17-2020, 06:21 AM
Rgb
Rgb's Avatar
Quoted: 727 Post(s)
Liked: 977
Never tried this, but here is a web based audio file convertor.
.m4a = .aac generally, and may play in the car player
Rgb is online now
Reply 2-Channel Audio
