Amp for two channel - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 41Likes
Closed Thread
post #31 of 52 Old 01-21-2020, 04:24 PM
torii's Avatar
Quoted: 3912 Post(s)
Liked: 2286
if have half a brain, fixing the amp can be done yourself for under 100 bux...or maybe not but if pinching pennies might be worth looking up a youtube how to.
Timestoo likes this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #32 of 52 Old 01-21-2020, 04:29 PM
Alex F.'s Avatar
Quoted: 987 Post(s)
Liked: 591
Originally Posted by Timestoo View Post
I can't than you enough for answering me with helpful advice. I was looking more at the Pass 250.8 over the Nu-Vista.
The Classe is going to cost about $400 to fix and I do like that amp. I had it running a pair of 703's for quite a few years. Just thought it was time to move on and upgrade my 2 channel. The repair tech said the same about trying a tube preamp. In my other thread it was suggested to look into a DAC...what's the pros and cons? thank you again
You are welcome.
There is no harm in trying different DACs and finding out whether any make a worthwhile improvement or not. But I would not make any other changes simultaneously at first or you will not be able to accurately determine which component might be altering the sound quality to your liking (or not). You could bring home both a DAC and a preamp at the same time, compare each separately with what you own now, then try the new DAC and new preamp together.
Music room: Cary SLI-80 tube integrated amplifier, McIntosh MA6500 integrated amplifier, Quad 99 preamp, Quad 909 power amp, Acoustic Research AR9 loudspeakers, Yamaha CD-N500 CD player, Teac UD-503 DSD DAC, Phase Linear 8000 II linear-tracking turntable.
Theater room: Panasonic 65S60 plasma television; Yamaha RX-A2020 (preamp section); Adcom GFA-5503 and GFA-5400 amplifiers; Polk LSi25, LSiC, and LSiF/X loudspeaker system; Velodyne FSR-18 servo-subwoofer.
Alex F. is offline
post #33 of 52 Old 01-21-2020, 04:59 PM
torii's Avatar
Liked: 2286
whether scott can afford anything is not a good point of reference. he has experience. this is valuable. scott liked the lrs by magnepan which is a product I do own and his thoughts on it are similar to mine. so I value scotts opinions. opinions are what make up forums.
Scotth3886 likes this.
torii is offline
post #34 of 52 Old 01-21-2020, 05:12 PM
Scotth3886's Avatar
Quoted: 4232 Post(s)
Liked: 2680
I had some very interesting late night mellow ethereal material on last night so slept in LR on the sofa way off axis and enjoyed them all night long. These do so well at quiet levels. Just an amazing speaker for $650.
torii likes this.
Scotth3886 is offline
post #35 of 52 Old 01-21-2020, 05:48 PM
Out-Of-Phase's Avatar
Quoted: 380 Post(s)
Liked: 342
"The Classe is going to cost about $400 to fix"
Did they tell you what specifically is wrong with it? Is it power supply caps? Soft-start relays?
Save your money.
Out-Of-Phase is offline
post #36 of 52 Old 01-21-2020, 06:32 PM
Alex F.'s Avatar
Quoted: 987 Post(s)
Liked: 591
Another consideration if you pursue a new DAC: Try to find one or more that can convert all your digital sources to DSD. I am hooked on the somewhat analog-like sound it offers.
Alex F. is offline
post #37 of 52 Old 01-21-2020, 06:59 PM - Thread Starter
Quoted: 50 Post(s)
Liked: 6
power supply caps......I think the number was 23
Timestoo is offline
post #38 of 52 Old 01-21-2020, 07:04 PM - Thread Starter
Quoted: 50 Post(s)
Liked: 6
Having "been there" what would you pursue knowing my millions but staying close to said budget?
Timestoo is offline
post #39 of 52 Old 01-21-2020, 07:16 PM
Quoted: 380 Post(s)
Liked: 342
Sounds about right. After 20 years those caps can get dried out and leak. Hopefully your tech will replace those with top-of-the-line 5000 hour 105C caps. It came originally with Nichicon of Japan.
https://www.hifishock.org/galleries/...0-1-classe.jpg
Save your money.
post #40 of 52 Old 01-21-2020, 07:44 PM - Thread Starter
Quoted: 50 Post(s)
Liked: 6
He claimed to be using the same as originals but had just diagnosed the problem. He gave me a ballpark of $400.......without pricing the caps out, I believe.
Timestoo is offline
post #41 of 52 Old 01-21-2020, 07:51 PM
Alex F.'s Avatar
Quoted: 987 Post(s)
Liked: 591
I do not stream, but there seems to be many DACs that convert streaming to DSD.
I use the now discontinued Teac UD-503 to convert CDs to DSD. Its replacement, the new UD-505 (and its sibling, the NT-505), is about twice the retail price of the UD-503 (and NT-503) at $2k. Yikes!
Since I purchased the Teac from B&H in 2017 (on sale for $800) I have not kept up with what current units convert various sources to DSD. Sorry that I thus cannot recommend any specific DSD DACs available today.
Have the butler do the research for you.
Alex F. is offline
post #42 of 52 Old 01-21-2020, 09:44 PM
markmon1's Avatar
Quoted: 5904 Post(s)
Liked: 3977
Do you know how well it pairs with the 702 s2's? Lovely sounds good
B&W with McIntosh is a magical pairing. MC152 would even be sufficient.
torii likes this.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #43 of 52 Old 01-21-2020, 09:52 PM
torii's Avatar
Liked: 2286
bw sounds even better with simaudio moon.
torii is offline
post #44 of 52 Old 01-21-2020, 09:57 PM
markmon1's Avatar
Liked: 3977
I've never experienced that. But something about the McIntosh tames the highs which many think the B&W benefit from. Does simaudio moon have a reputation for a warmer sound?
markmon1 is offline
post #45 of 52 Old 01-22-2020, 06:13 AM
Quoted: 380 Post(s)
Liked: 342
Is that what I said? Where?
Sorry, I guess that was someone else on another thread.
Save your money.
post #46 of 52 Old 01-22-2020, 06:19 AM
torii's Avatar
Liked: 2286
I dont think warmer is best adjective. I honestly cant describe it but that brand just makes all highend speakers just sound sweet to my ears. and thats not a knock vs mcintosh. just saying if get a chance listen to simaudio stuff.
torii is offline
post #47 of 52 Old 01-22-2020, 07:15 AM - Thread Starter
Quoted: 50 Post(s)
Liked: 6
How can this be with what we've learned on page 1 from phase -out:
"I don't know what you hear, but I know why you think you hear differences in power amps. Cognitive Bias is a fact. Comparing audio components with your eyes open creates errors".
Is it that only some of the beautiful people can hear differences? I swore I heard a difference and my eyes were open...is that the difference? Should my eyes be closed when shopping for amps?
Seriously, is this a can of worms here or am I receiving two different facts? I've read many an amp review..are they all smucks? Thanks for all the help so far.....
Timestoo is offline
post #48 of 52 Old 01-22-2020, 07:20 AM
torii's Avatar
Liked: 2286
if you are happy is all that matters. we wouldnt have 99% of these forums if was so simple.
torii is offline
post #49 of 52 Old 01-22-2020, 07:53 AM - Thread Starter
Quoted: 50 Post(s)
Liked: 6
Life is good!
If what was so simple? It is a simple question tho, can you hear the difference in an amp or not? If the answer is not, all these people just pretending as if they were children?
I think it is a fair question having been told, and confirmed, I only think I heard more fullness in the mids, and better balance with the nu-vista. I'm not here to argue but for answers and this has me scratching my head. Why would there exist a second type of amp is all are equal?
Timestoo is offline
post #50 of 52 Old 01-22-2020, 08:19 AM
torii's Avatar
Liked: 2286
I can hear differences in some gear and others not so much. I believe everything matters...to even include cables.
torii is offline
post #51 of 52 Old 01-22-2020, 10:10 AM
Scotth3886's Avatar
Liked: 2680
If your system resolves well enough, and you're in a quiet enough space, you're likely to hear differences.
torii likes this.
post #52 of 52 Old 01-22-2020, 12:39 PM
_tk
Quoted: 688 Post(s)
Liked: 316
It's because differences actually exist in amps and sometimes this comes out more with different speakers. Cognitive bias is a thing, but so are amps that sound different.
And it can be both ways, much to the chagrin of the guy who spent $400 for an AVR and tries to tell us that there's no difference between his unit and much more expensive ones. A lot of this is also people trying to "defend/justify" their purchase of inferior equipment.
_tk is offline
Closed Thread 2-Channel Audio
