AVR setting for 2 channel audio - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Leeliemix
post #1 of 3 Old 02-17-2020, 01:02 AM - Thread Starter
Liked: 0
I'm only using 2 floorstanders and lots of the content that I play through my OPPO-203 either displays DTS-HD:NeuralX or Multi IN and my question is will the AVR automatically play the sound correctly through both speakers or is there a setting I need to change to force 2 channel stereo audio only?
AVR is Marantz NR1609.
craigstunk is offline
post #2 of 3 Old 02-17-2020, 02:19 AM
Quoted: 529 Post(s)
Liked: 272
If you just choose stereo as the sound mode it should remember that so you dont have to worry. You might have to select it a few times as its per input and possibly input mode also.
craigstunk likes this.
Leeliemix is online now
post #3 of 3 Old 02-19-2020, 07:00 PM
Hold onto the music button and select stereo
edzyy is offline
Reply 2-Channel Audio
