Speaker selector channel to power 2nd amp? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By m. zillch
post #1 of 11 Old 05-02-2020, 08:15 AM - Thread Starter
G-force's Avatar
I have an unusual audio setup in my barn/shop. The hub consists of an adcom gfa 555 going int a gfs 6 channel selector. I have a 2nd adcom amp I would like to add 50 ft away in my shop but it only has rca inputs. Can I just run a line out converter on a set of speaker leads from the selector to get signal the the 2nd amp? Is there any specific model i will need based on a high wattage signal? Thanks!
President and active member of the A.D.F.F. (Anti-Dakota Fanning Foundation)
G-force is offline
post #2 of 11 Old 05-02-2020, 01:05 PM
m. zillch's Avatar
Quoted: 6438 Post(s)
Liked: 4639
I guess theoretically it would work but I have to ask why not just split the signal arriving at the first GFA-555 amp with simple Y-cables and send that RCA split off to the 2nd amp? That would be a cleaner more direct path.
Remember the rule Rane teaches us when it comes to Y cables: it is safe to split an output to send two signals but not a good idea to split an input so it can receive two sources. What I am proposing adheres to the rule.
hhawk likes this.
m. zillch is offline
post #3 of 11 Old 05-03-2020, 03:01 PM - Thread Starter
G-force's Avatar
I really want the 2nd amp to be selectable as one of the zones on the GFS. So the first amp runs through the selector then distributes signal to 6 zones. One of which will be the 2nd GFA. Powering a different room with more demanding speakers. Hopefully that makes sense. I pretty much always stream compressed music so not to worried about a small loss of Fidelity, I just don’t want to fry anything.
So is the a special line out converter needed to handle potential higher wattage?
G-force is offline
post #4 of 11 Old 05-03-2020, 03:39 PM
m. zillch's Avatar
Liked: 4639
This is an example of a high power LOC, line out convertor, which can accept up to 400 watts. It is typically used in automotive sound so to use it at home you'd need either a 12V battery or a power supply, however it uses very little current to a simple 12V DC wall wart transformer would work to power it.
https://www.amazon.com/AudioControl-.../dp/B00IIL0LW0
post #5 of 11 Old 05-03-2020, 07:54 PM - Thread Starter
G-force's Avatar
I love audiocontrol’s stuff, but really dont want to complicate things with 12v unless absolutely necessary.
G-force is offline
post #6 of 11 Old 05-03-2020, 08:04 PM - Thread Starter
G-force's Avatar
I may need to rethink this as it may not be possible. If I send a 50+ watt high level signal to the rca inputs im afraid something disasterous might happen. Somebody has to have come up against this scenario i would imagine.
G-force is offline
post #7 of 11 Old 05-03-2020, 08:55 PM
m. zillch's Avatar
Liked: 4639
I have no experience with this one but as I understand it no electricity is needed and it takes high power ins.
https://www.ebay.com/itm/Jensen-Tran...-/400666311152
I think they make more than one. I don't know what the differences are so you are on your own. Good luck.
post #8 of 11 Old 05-04-2020, 08:55 AM - Thread Starter
G-force's Avatar
That looks promising. I’ll give them a call. Thanks!
G-force is offline
post #9 of 11 Old 05-22-2020, 09:14 PM - Thread Starter
G-force's Avatar
These guys arent taking calls due to the pandemic
G-force is offline
post #10 of 11 Old 05-22-2020, 09:47 PM
m. zillch's Avatar
Liked: 4639
Well that was just a random link. I'd assume there's more than one vendor of the product.
More info: https://www.jensen-transformers.com/product/sp-2sx/
post #11 of 11 Old 05-25-2020, 10:11 AM - Thread Starter
G-force's Avatar
Thats who I am talking about. I called Jensen direct. Apparently corona can go through a phone now. Who knew?
G-force is offline
Reply 2-Channel Audio
