New 2 Channel Set Up - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By glangford
  • 1 Post By Class A
  • 3 Post By torii
  • 1 Post By eljaycanuck
post #1 of 13 Old 05-22-2020, 12:03 AM - Thread Starter
Dfndr's Avatar
Quoted: 42 Post(s)
Liked: 6
Hi. I’m looking to get a new two channel system for a room that is 13 ft wide by 13 ft from speaker to listening position. I’m in my 70’s and pretty much disabled so listening to music(classical, jazz and female vocals) is a big part of my daily activity especially being sheltered in place for the foreseeable future. At my age and with maladiesI don’t have much else to spend money on and can afford the “drop dead bucket list “ system I’ve lusted after since first entering a stereo shop in college,(but I’m not talking tens of thousands here!).
I saw the McIntosh MA5300 Integrated Amp for $5500 and thought how cool it would be to to finally have a Mac with those big blue dials. I would just get a nice CD transport like the Cambridge for $599 and listen to all my CD’s and expand my collection.
But browsing the net, I saw the Anthem SRT Integrated Amp on sale this month for $900 off. It has twice the wattage (which I don’t think I need) and rave reviews and would cost $3600.
I don’t “need” either of these but they would be nice with my B&W CM10s2 speakers(which I didn’t “need” either, but do enjoy. I understand that I could put together a nice system for much less money, but I’m retired and mostly homebound now and this is my hobby, even tho I know one of my kids will probably be using this equipment far longer than I will!
Any advice or suggestions regarding these two amps? All suggestions will be appreciated.
Dfndr is online now
post #2 of 13 Old 05-22-2020, 02:34 AM
glangford's Avatar
Quoted: 839 Post(s)
Liked: 738
The anthem has room correction with ARC. I use it in my anthem MRX-520 and it works well even with just a 2 channel setup. But I can also sympathize with the desire for a McIntosh.
The speakers have a sensitivity of 90 db so are easy to drive. Either amp will work fine. If you really want to crank it up, I'd recommend the anthem 200 wpc at 8ohms, the Mac, 100 wpc 8 ohms. (at 70+, I wouldn't recommend cranking too much; save the hearing you have.)
I'd also note that these are heavy units, 38 and 40 lbs. So make sure you can maneuver them as you say you are disabled. There are some nice class D amps that are very efficient and much lighter. NAD masters, Lyngdorf to name a few. The Lyngdorf TDAI-3400 is 18.1 lbs. NAD M32 is 20.1 lbs. Lyngdorf has Lyngdorf Room Perfect room correction. M32 none, although the coming (August) M33 will have Dirac live room correction.
You don't mention the nature of your disability but getting up to put in CDs can be a pain. Might consider a streaming function. Lyngdorf TDAI-3400 will do airplay so you can stream music files from ripped CDs on a laptop, iPad, or iPhone to the unit. You can also load them up on USB thumb drive and play them via an app. Not sure about the NAD.
Will this also serve to amplify sound for TV and movies? If so, the NAD and Lyngdorf can be had with an optional HDMI module for connecting a blu ray player and cable box, and they pass the video on to the display.
If you want old school with meters like the Mac, you might consider the Yamaha integrated amps, 1100,2100, 3000 etc, or a Luxman. The coming NAD M33 will have digital meters via a display, but that's not the same as the allure of real meters. All of these will be pretty hefty units (except the NAD M33), so there is that to consider.
The Mac at one time was my dream amp as well. But my system came to be basically the system for mostly music, but also occasional movies, so my sources became universal players, Oppo. Hence HDMI inputs became important to me, hence, why I use the Anthem MRX-520 even in just 2 channel mode. I think my dream amp today would be the lyngdorf TDAI-3400 with optional HDMI module.
Good luck with your choices.
hhawk likes this.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #3 of 13 Old 05-22-2020, 02:38 AM
alan0354's Avatar
Quoted: 2064 Post(s)
Liked: 550
I would go for separate preamp and power amp, you have a lot more choice going separate. Your choice of high end integrated amp is very limited. I never listen to either one, I looked at the internal pictures of the Anthem, heat sink is way too small for the price, not enough filter caps. Even though its cheaper at $3500, it's just doesn't have what I consider important for a high end power amp. Can't find pictures of the Mac, so I can't comment other than the amp looks very small for the money. For that kind of money, I would be looking for one with big heatsink on both sides of the chassis.
For high end amps, things I am looking for is the size of the heatsink, how many pairs of output transistors, how many big caps inside the amp, how big the power transformer. There's no short cut on the high end Class AB amps. I would consider it NEGATIVE point on Anthem that is 200W/ch and such small heatsink and only 4 medium size filter caps. That's CHEAP.
Own designed power amp, own designed preamp, JM LAB Focal Alto Utopia and Spectral 913.1 speakers, Rythmik F12SE sub.
Not hooked up: Nakamichi Stasis PA-7 power amp, Velodyne VA1210 sub, Kef Reference Series center, Kef Bookshelf speaker, Monitor Audio bookshelf speaker, Infinity rear speakers. Acurus 3X200W amp.
alan0354 is offline
post #4 of 13 Old 05-22-2020, 03:10 PM
Class A's Avatar
Quoted: 876 Post(s)
Liked: 6282
Thumbs up
I would also look at the Luxman 505UXii integrated. Also as an add on a Bluesound Node. You'll be able to stream music from your seat. A few years ago I had a total of 7 1/2 hours of cancer surgery on my left groin. It was very hard for me to get up and the streamer was a god send for listening to music. By the way the Luxman also has meters so you'll still have that visual.
KenM10759 likes this.
Class A is offline
post #5 of 13 Old 05-22-2020, 03:15 PM
torii's Avatar
Quoted: 4371 Post(s)
Liked: 2535
just get the mcintosh if its been a dream.
eljaycanuck, leecreek and regsharp like this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #6 of 13 Old 05-22-2020, 03:19 PM
eljaycanuck's Avatar
Quoted: 2109 Post(s)
Liked: 3069
Originally Posted by Dfndr
... I’m in my 70’s and pretty much disabled so listening to music ... is a big part of my daily activity ... I don’t have much else to spend money on and can afford the “drop dead bucket list “ system I’ve lusted after since first entering a stereo shop in college ...
But ...
^ 100% this.
leecreek likes this.
eljaycanuck is offline
post #7 of 13 Old 05-22-2020, 04:56 PM
alan0354's Avatar
Liked: 550
Yeh, if the Mac is your dream amp, by all means get that. I just don't like what I saw in the pictures of the Anthem. It's $2000 cheaper.....and it really shows.
alan0354 is offline
post #8 of 13 Old 05-24-2020, 09:58 PM
Liked: 0
Just get the McIntosh, the MA5300 is fine and affordable as far as McIntosh goes, you can pick up a lightly used unit on audiogon for about 3500. This is what I'm planning to get after a lot of research and a lifelong McIntosh dream also.
Munc C is offline
post #9 of 13 Old 05-24-2020, 10:23 PM
alan0354's Avatar
Liked: 550
I never buy new, even for very expensive piece. If OP like Mac, I would buy a used Mac power amp and buy a preamp that has the latest gadgets. High end power amps have not change for the last 30 years, from the very early 90s on, they are just the same, no new technology on the high end amps, only the lower end came up with class D and all, high end still class AB or class A. I am sure you can get a older used power amp for less than 1/2 price.
I bought a Nakamichi PA-7 a few years back, it's designed by Nelson Pass and it's an improved version of his famous Threshold S300. I paid $700, original MSRP was $1800 in the late 80s, now must equal to like $3500 new today. I don't like the amp, but that's a different story for another time, it's sitting in the shed outside the yard.Bbut it's the Threshold that put Pass on the map. I almost bought a Krell KSA200 for $1900.....a 200W class A Krell!!! You are talking about the amp of amps!!!
I would never buy another amp, but from studying hundreds of circuits of amps, if I were to buy, I would seriously consider Adcom GFA565 monoblock. Second one is Parasound A21. Of cause I never listened to them, but just from the circuit and the layout inside the amp, they tell me a lot already, I'd take these two any time of the day over Krell and Mark Levinson. I've seen a pair of GFA565 as low as $1400. Name don't mean a thing to me, I look at what's in it.
alan0354 is offline
post #10 of 13 Old Yesterday, 01:07 PM
twitch54's Avatar
I agree with the others, if the 'Mac' is your dream amp, go for it.
As for your digital needs, do you have any SACD's ? If not I'd opt for the Rotel 1570
twitch54 is online now
post #11 of 13 Old Yesterday, 04:47 PM
mbroadus's Avatar
Quoted: 1359 Post(s)
Liked: 571
I’m currently upgrading my 2 channel and looking and looking at the Naim Uniti Nova or and Luxman L-505uXII. I’ve always wanted a McIntosh too and was looking at the 8900 but I’m hesitant after the last listening session with my current speakers. How do you like the 5300?
Panasonic P60VT60 Calibrated by Chad B
Anthem MRX-720, Oppo UDP-203, Bluesound Node 2i
Focal Aria 936/CC900, SVS SB-3000
MacBook Pro, AppleTV 3 & 4K, Sony PS4 Pro
Zero Surge 8R15W-I
mbroadus is online now
post #12 of 13 Old Yesterday, 05:31 PM
mbroadus's Avatar
Liked: 571
The Anthem STR integrated is considered a very well engineered product that runs cool and does not need the large heat sinks. At normal listening volume, it may be using 5-6 watts.
Zero Surge 8R15W-I
post #13 of 13 Old Yesterday, 06:22 PM
alan0354's Avatar
Liked: 550
That's the problem, when comes to high end amplifiers, they are all either high bias Class AB or class A. both require burning power and getting hot. There is no low bias class AB amps that can be that good. I design quite a few power amps and I keep up with studying books and studies a lot of schematics of good amps. Really it comes down to how big the heatsink, how heavy the amp is, how much filter capacitance, how many output big transistors. There is no other way.
The Anthem has only 4 medium size capacitor, very small heatsink. You just cannot get high quality class AB from that. I actually experimented changing one of my amp to get rid of two pairs of output transistors ( from 9 pairs to 7 pairs), design to reduce the bias current to 1/3 the original bias of 1A. Everything else are exactly the same. Big difference in the richness of the sound. I literally tried all the tricks in the book and not in the book, I yet to find any short cut............Neither are the top brand amps like Krell, Mark Levinson etc.
I attached two internal pictures of high end power amps. The inside are packed to the brim!!! Look at the size of the heatsink, the size of the transformer. Those are like this for very good and valid reason.
ID:	2733918   Click image for larger version
alan0354 is offline
Reply 2-Channel Audio
