Help me get the best from my setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-22-2020, 07:19 AM - Thread Starter
tbaucom's Avatar
Quoted: 417 Post(s)
Liked: 128
I have mirage omd-28, I am currently powering them with a gen 1 emotiva xpa-5. These speakers have an F3 of 25hz measure flat to 20hz in my setup with room gain. Music is a high priority in my setup. I usually run the speakers full range and l listen to music in 2 channel only without my subs active. I have never been able to get a a smooth blend with my subs because the speakers aren't rolling off at all and the crossover slopes in typical home theater equipment don't match( typically 24db/octave low pass and 12 db/octave high pass). This mismatch causes too much overlap in the frequencies being played by the 28s and my subs.
I have been considering a few options to improve my combined setup. I could add a minidsp to set a 24db/octave high pass high pass filter slope and set my prepro to LFE plus main to use it's 24db/octave low pass. That would insert an ADA conversion and the minidsp does't measure all that great. I also was considering one of the crown class D amps. It would give the benefit of both more powerful amplification and built in high pass filter. The crown would also add an ADA and doesn't measure that well.
The other option would be to add a nice class D amp like Nord or KJFAudio or class A/B emotiva xpa-dr2. They measure better with significantly more power (500 watts per channel) and avoid the ADA. I would still be running the OMD-28 full range and that goes against conventional AVS wisdom. I have dual subwoofers in a 7.2.4 setup with a marantz 8805. I use subwoofers for the LFE track in movies and cross the other speakers in my setup (smaller mirage sealed speakers from the OMD line) over to them.
Do you guys think add a more powerful amp for the 28s and leaving things as currently configured would be a significant upgrade? Would I be better off to add something like the mindsp and crossover to my subs? Every review I have read say the mirages need gobs pf power and sound better with it. In the years I have had them they have always been used with the gen 1 xpa5. I want to get the best I can for both music and movies with this combined setup.
tbaucom is offline
post #2 of 3 Old 05-25-2020, 07:52 PM - Thread Starter
tbaucom's Avatar
Quoted: 417 Post(s)
Liked: 128
Any thoughts at all? Sound and Vision measurements below.
https://www.soundandvision.com/conte...m-measurements
tbaucom is offline
post #3 of 3 Old Yesterday, 04:22 PM
RayGuy's Avatar
Quoted: 3468 Post(s)
Liked: 3278
Have you considered a sealed sub? That might blend better with your speakers due to the different slope of the low bass output. Alternatively, use an outboard product to handle the crossover region with alterable slopes for both high-pass and low-pass filters. I don't think changing your amps will solve the stated problem. Using LFE + Main (i.e. Double Bass) is also problematic and may be exacerbating the problem.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
Reply 2-Channel Audio
