Connecting 1 CDP to 2 amps, - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Ratman
post #1 of 16 Old 05-23-2020, 04:27 AM - Thread Starter
Liked: 3
As the title says, can anyone help me solve this
Sent from my SM-G950F using Tapatalk
Stewart Godfrey is offline
post #2 of 16 Old 05-23-2020, 04:37 AM
Ratman's Avatar
Quoted: 2772 Post(s)
Liked: 2784
What's a CDP?
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #3 of 16 Old 05-23-2020, 04:38 AM - Thread Starter
Liked: 3
Cd player
post #4 of 16 Old 05-23-2020, 04:41 AM
Ratman's Avatar
Liked: 2784
One amp or two simultaneously?
post #5 of 16 Old 05-23-2020, 04:42 AM
Quoted: 358 Post(s)
Liked: 510
Via what connection? You can't hook up a CDP directly to any amp unless you mean a receiver, in which case you'd need a splitter of some kind but again, we need to know what connection you're trying to use.
Gary Mertz is online now
post #6 of 16 Old 05-23-2020, 04:44 AM - Thread Starter
Liked: 3
I have 1 amp hooked up to a Yamaha DSP so I get 4 channel sound output.
The other amp is my dedicated 2ch with the turntable and cdp connected.
On occasions i would like to listen to the cd via the sound processor withour the hassle of swapping over cables
Hope that explains it better
post #7 of 16 Old 05-23-2020, 04:47 AM
Ratman's Avatar
Liked: 2784
From CD player:
Use optical/coax for the 4 channel system.
Use analog (red/white) for 2 channel system.
post #8 of 16 Old 05-23-2020, 04:47 AM - Thread Starter
Liked: 3
Both amps are analogue as is the sound processor, so only have the option of RCA output.
I have a rca splitter but it only has 1 output ( to amp) with 3 inputs ( from source)
post #9 of 16 Old 05-23-2020, 04:48 AM - Thread Starter
Liked: 3
Originally Posted by Ratman View Post
From CD player:
No digital inputs on amps, they are both vintage 70s.
post #10 of 16 Old 05-23-2020, 04:48 AM - Thread Starter
Liked: 3
Think i may need to buy a cheap ext DAC
post #11 of 16 Old 05-23-2020, 04:50 AM
Ratman's Avatar
Liked: 2784
... or a second CD player.
Stewart Godfrey likes this.
post #12 of 16 Old 05-23-2020, 05:47 AM - Thread Starter
Liked: 3
Sorted
A) Connected CDP to Tape 1 input Amp 1
B) Connected Amp Tape 2 Rec Out to DSP Line input
C) Connected DSP IN/OUT to Amp 2 Tape 1 In /Out
For 2ch listening through better amp/speakers play CD and select tape 1 input.
For 6 channel sound process
Select tape 1 > 2 copy and i have a pretty good DSP 6 channel controlled by 2 amps
Brain now hurts and going for a lie down
post #13 of 16 Old 05-23-2020, 07:54 AM
Speedskater's Avatar
Quoted: 66 Post(s)
Liked: 44
A splitter would have 1 input and 3 outputs.
Unless it's powered, using it in reverse is bad news.
Kevin
Speedskater is offline
post #14 of 16 Old 05-23-2020, 08:01 AM
Quoted: 700 Post(s)
Liked: 369
check this out - there are cheaper versions. Search under " RCA distribution amplifier)
https://www.amazon.com/TC-7240-Route...0246006&sr=8-7
easy peasy
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Ascend Acoustics Duo,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #15 of 16 Old 05-23-2020, 08:50 AM - Thread Starter
Liked: 3
easy peasy
Sorted it with some slow brained thinking, using the 2nd tape rec out to DSP line in which feeds 2nd amp.
Fortunately my Sony amp has tape copy function
Stewart
post #16 of 16 Old 05-23-2020, 11:56 AM
Alex F.'s Avatar
Quoted: 1031 Post(s)
Liked: 618
Unless I am misunderstanding what you are attempting to do, just split the CD player's left and right channel analog outputs to feed the stereo inputs of your two separate analog components. I'm assuming your "Yamaha DSP" is an integrated amp and the other unit is a receiver or another integrated amp--you are vague on this. It would've been helpful to provide the specific models.
Use these or something similar:
https://www.amazon.com/Cable-Matters...s%2C304&sr=8-7
Music room: Cary SLI-80 tube integrated amplifier, McIntosh MA6500 integrated amplifier, Quad 99 preamp, Quad 909 power amp, Acoustic Research AR9 loudspeakers, Yamaha CD-N500 CD player, Teac UD-503 DSD DAC, Phase Linear 8000 II linear-tracking turntable.
Theater room: Panasonic 65S60 plasma television; Yamaha RX-A2020 (preamp section); Adcom GFA-5503 and GFA-5400 amplifiers; Polk LSi25, LSiC, and LSiF/X loudspeaker system; Velodyne FSR-18 servo-subwoofer.
Alex F. is offline
Reply 2-Channel Audio
