Quality 2-channel room correction...On a budget. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By torii
post #1 of 4 Old 05-23-2020, 10:17 AM - Thread Starter
Quoted: 30 Post(s)
Liked: 7
I know room correction is often frowned upon by 2 channel music audiophiles, but after playing around and listening to some music this weekend in my theater room, I want to give it a try in with my two channel set up. Unlike my semi dedicated theater room, my 2-channel music set up is a living space first and ideal speaker placement with audio treatments are eschewed in favor of having a happy wife.
Though I don't have a set budget so to speak, as you can see below, my equipment isn't overly pricey and I try to always find that price/sound sweet spot.
It seems like the cheapest option by far would be to grab a Minidsp DDRC-24 as I already have a UMIK-1. That said, if there was something else out there that cost more but would also improve/recplace one of the weaker links in my set up below, I wouldn't be opposed to spending quite a bit more than a DDRC-24.
I'd love to hear your thoughts/suggestions,
Troy
My current set up is as follows:
Sources:
Rega Planar 3 w/ Neo TT-PSU (70% of the time)
HD Audio files over USB (PC) (30% of the time
Processor:
Emotiva PT-100 (serves as DAC and as Phono Pre-amp)
Amp:
Adcom GFA - 535
Speaker (rotation):
LS50's
Emotiva Airmotiv 6's
Classix II's
S2000's
Helix MT's (ordered)
Troy Fagan is offline
post #2 of 4 Old 05-26-2020, 07:22 PM
Quoted: 145 Post(s)
Liked: 88
Here you go.. Paradigm PW Link with Anthem’s Room Correction (ARC)- considered to be almost as good as Dirac. Note I have no experience with the product. I just remembered the review, and being significantly cheaper than the MiniDSP
https://audiosciencereview.com/forum...amer-dac.7763/
thebrieze01 is online now
post #3 of 4 Old 05-26-2020, 07:44 PM
torii's Avatar
Quoted: 4371 Post(s)
Liked: 2535
just use REW to get best positioning of 2 speakers.
Mike in NC likes this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #4 of 4 Old 05-27-2020, 08:03 PM
Mike in NC's Avatar
Quoted: 91 Post(s)
Liked: 76
That's a great first step. Depending on the room and speakers, it may or may not get the OP far enough along to be the last step.
Mike (Portland, Oregon)
Spoiler!
Mike in NC is offline
Reply 2-Channel Audio
