what do you think of this speaker wire - AVS Forum | Home Theater Discussions And Reviews
 93Likes
Closed Thread
post #1 of 58 Old 05-26-2020, 01:46 AM - Thread Starter
Quoted: 337 Post(s)
Liked: 269
What do you think about 12 ga Cullen Copper Speaker Cables 120.00 for 6 feet a pair compared to other wires in the general same price bracket?
stngray72 is offline
post #2 of 58 Old 05-26-2020, 02:04 AM
Quoted: 2094 Post(s)
Liked: 1720
I think that you can get a 100 ft roll of 12 gauge OFC for $40 from many different brands off amazon.
If you want spades or banana plugs, add $10 to find some that you like how they look.
Leave it at 8 ohms and call it a day :)
Russdawg1 is offline
post #3 of 58 Old 05-26-2020, 02:11 AM - Thread Starter
Quoted: 337 Post(s)
Liked: 269
You are kind sir but i get your point you dont think premium speaker cables make a difference but ive already bought silver back 12 ga wires and heard a difference but im looking for more.
post #4 of 58 Old 05-26-2020, 02:30 AM
Liked: 1720
Just buy the ones that look the best sounding or the ones that have the most audio jargon on their website, they’ll make you think they sound the best.
It’s really all looks, and you can attain those same looks with some time on your end and not end up spending $500 for some cables that promise chocolatey smooth midrange with a 4D soundstage.
Time and time again, if this technology they promise actually made some sort of difference in the way electrons moved, then you’d see it somewhere else than the snake oil audio market.
Another way to look at it is why are you using cables to supposedly EQ your system? Why wouldn’t you just EQ it to sound like the more expensive nicer sounding cable?
post #5 of 58 Old 05-26-2020, 04:33 AM
Ratman's Avatar
Quoted: 2877 Post(s)
Liked: 2939
Overpriced.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #6 of 58 Old 05-26-2020, 04:58 AM
DanPackMan's Avatar
Quoted: 543 Post(s)
Liked: 1453
Wire you asking?
DanPackMan is offline
post #7 of 58 Old 05-26-2020, 06:55 AM - Thread Starter
Quoted: 337 Post(s)
Liked: 269
It makes my head shake for the amount of controversy this topic makes. And I wonder why its so hard to not comment if you dont believe in speaker wire making a difference. Having said that I went with for 56 bucks a pair 6 feet long.
Canare 4S11 Star Quad 11 AWG
post #8 of 58 Old 05-26-2020, 07:03 AM
Mocs123's Avatar
Quoted: 628 Post(s)
Liked: 413
Just make sure you get the directional arrows going in the correct direction or the electrons won't work right
As you can tell I think cables are snake oil, but if it makes you happy, go for it. I'm sure they won't sound any better or worse than 12/2 OFC from Monoprice but they look nice, and that can be worth something. Is your room properly treated? If not that might be something you could spend money on that would have a real difference in sound.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, Dual Driver VBSS
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is offline
post #9 of 58 Old 05-26-2020, 07:46 AM
hhawk's Avatar
Quoted: 46 Post(s)
Liked: 45
The better the sound system the easier it is to tell differences in cables and wires. Many people own receivers and bookshelf speakers which makes it difficult to hear the differences. But owning high quality separates can make many differences easy to hear. As the advice says, wires and cables should be auditioned only after the system is where you think you want it.
Tex_Thai likes this.
hhawk is offline
post #10 of 58 Old 05-26-2020, 08:08 AM
DanPackMan's Avatar
Quoted: 543 Post(s)
Liked: 1453
Originally Posted by hhawk View Post
The better the sound system the easier it is to tell differences in cables and wires. .
Of course. If you can't hear the difference, just blame it on the equipment... such an easy out to excuse a lack of results. But why would the 'better' sound systems be so sensitive to such things? Seems like a poorly designed system if it is so intolerant of the cables that work perfectly fine on 'not as better' systems.
Meanwhile, we are still waiting on someone that actually measures a sound difference resulting from these high end cables, and will keep speaking up so as to help educate those that are susceptible to unsubstantiated claims that could lead to wasting money. Claims are easy, substantiation is hard.
m. zillch, Mikkle, khcoach and 1 others like this.
post #11 of 58 Old 05-26-2020, 08:17 AM
Quoted: 68 Post(s)
I would love to see someone do a side by side comparison be between something as simple as 14ga zip wire against different price range cables. Not just a side by side can you hear the difference, but one where all the frequency data is captured and charted out.
That being said, there can be audible differences due to poor selection of wire gague over long runs(50'-100') due to capacitance and impedance issues. I have and a hard time believing the 14 gague cable A or cable B would make a difference over short runs. Copper wire is still copper wire, you can't change the physics of it. If they are making the conductors out of silver or gold vs copper, then that could possible change things.
reburg99 is offline
post #12 of 58 Old 05-26-2020, 08:46 AM
hhawk's Avatar
Quoted: 46 Post(s)
Liked: 45
Nah, just common sense. When you take a photo with higher resolution, the more detail you will see. Similarly, the better the quality of your components, the more details that get through. These are subtle, you do have to be the type of person who closes their eyes and LISTENS to music.
What you are doing is pretending to be special and have all the knowledge. You want to save people who do not need saved. No one should be spending lots of money for cables and wires for a modest system. Most people realize that.
Your nonsensical references to lack of science to defend your beliefs is ridiculous to those who have better equipment as well as those who make a living reviewing audio equipment.
hhawk is offline
post #13 of 58 Old 05-26-2020, 09:03 AM
Class A's Avatar
Quoted: 907 Post(s)
Liked: 6617
Thumbs up
Talking about cable on AVS Forum is like being at the Spanish Inquisition. You will be found guilty and burned at the stake If you want to find sanctuary and other opinions try some other forums.
Tex_Thai, Jonas2 and leecreek like this.
Class A is online now
post #14 of 58 Old 05-26-2020, 09:09 AM
DanPackMan's Avatar
Quoted: 543 Post(s)
Liked: 1453
Unfortunately, what you assume is your 'common sense' does not have any technical or scientifically demonstrated rationale. It used to be 'common sense' that the earth is flat. We do have proven science that explains perception biases, and we have tools to measure sound well beyond what humans can hear, and yet we don't have any evidence that miniscule difference posed by these 'high end' cables impacts speaker output in any way that might be shown as an improvement in sound.
I am OK with people that believe they hear these differences, and attribute them to their fine quality component selection and superior hearing skills. I wish those same people would admit that perception biases may be at play rather than make claims about the cables that cannot be meaningfully substantiated. Denial of the proven science of perception bias, and insistence that they are somehow not susceptible to it, is a typical attribute I've observed in most who make these claims.
So go ahead and believe there is a difference, and go ahead and let others know you believe it. Just admit the possibility of perception bias, and that there is no technical substantiation for your belief.
BTW, Lake Ontario looks more vivid now that I've dumped a cup of blue food coloring into it. I asked others if they thought the lake looked more vivid after telling them I thought it did, some of them said yes. Those must have been the people with good vision like me.
post #15 of 58 Old 05-26-2020, 09:14 AM
Hoary's Avatar
A Wiki article on this subject has a link to an essay written by Roger Russell, a former engineer and speaker designer for McIntosh Labs:
http://www.roger-russell.com/wire/wire.htm
Very interesting read...
m. zillch likes this.
Hoary is offline
post #16 of 58 Old 05-26-2020, 09:20 AM
Ratman's Avatar
Liked: 2939
If it always makes your "head shake", then why ask here? You should expect most opinions to differ from yours.
Jonas2 likes this.
Ratman is offline
post #17 of 58 Old 05-26-2020, 12:15 PM - Thread Starter
Quoted: 337 Post(s)
Liked: 269
What i expect is respect the same as anyone else on here deserves...end of discussion (close thread if you like admin)
post #18 of 58 Old 05-26-2020, 01:12 PM
Ratman's Avatar
Liked: 2939
Try to enjoy your new speaker wire. If the wires have "arrows", be sure to they point in the proper direction. Also, give them a few weeks to "break in".
Ratman is offline
post #19 of 58 Old 05-26-2020, 01:41 PM
A9X-308's Avatar
Quoted: 2035 Post(s)
Liked: 1751
Probably because after all these decades I'm still looking for the evidence that these fancy cables make any sonic difference beyond RLC.
Excellent cable, as are the Belden and Mogami equivalents. I'd hate to think of how many kms of this stuff I've run over the years.
Jonas2 likes this.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #20 of 58 Old 05-26-2020, 01:46 PM
Ratman's Avatar
Liked: 2939
At 6'... it would be tough to compare (prove?) "sonic/audible" improvement(s).
Ratman is offline
post #21 of 58 Old 05-26-2020, 02:36 PM
DreamWarrior's Avatar
Quoted: 1445 Post(s)
Liked: 959
It's fine, we all respect your right to be wrong , just respect our right to point it out . Though, it looks like you bought a reasonable cable, so....? End of discussion, indeed.
CharlesJ likes this.
DreamWarrior is offline
post #22 of 58 Old 05-28-2020, 08:50 AM
Jonas2's Avatar
Quoted: 3328 Post(s)
Liked: 2202
Wire you asking?
Ha, ha....nice one...
I think that's reasonable, though some will argue. (Sure, you could get even cheaper, but....) The other ones for $120.00, yeah, a bit more out there. So you got these for less than half that price. Canare is good stuff, I doubt you'd hear any difference between this and the Cullen.
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #23 of 58 Old 05-28-2020, 09:50 AM
Ryan Statz's Avatar
Quoted: 1297 Post(s)
Liked: 1092
Just get 100' of Monoprice or Amazon Basics OFC for less than $50.
Home Theatre: Marantz SR6014 | KEF Q750 | KEF Q650c | KEF Q150 | HSU ULS-15 MK2 | Sony XBR55X900E | PS4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Fluance RT85 | Ortofon 2M Blue | Cambridge Audio AXC35 | Neat Motive 3
Ryan Statz is offline
post #24 of 58 Old 05-28-2020, 11:13 AM
m. zillch's Avatar
Quoted: 6743 Post(s)
Liked: 4962
Plus they have CL-2 rated versions at that price which as I understand it need to adhere to certain NEC?, CSA?, UL? codes.
Ryan Statz likes this.
m. zillch is offline
post #25 of 58 Old 05-28-2020, 11:23 AM
twitch54's Avatar
Quoted: 35 Post(s)
Liked: 34
more importantly, what color is your C3, coupe or vert, SB or BB ?
I guess by now you've learned that most posters around here have little regard for expensive wire discussion, to which I basically agree. It's sometimes more fun to get them started on the difference or lack there of in the way amps can sound ..............
twitch54 is offline
post #26 of 58 Old 05-28-2020, 11:26 AM
Ryan Statz's Avatar
Liked: 1092
Because it largely doesn't - whether you spend $120 on 6 feet or $50 on 100 feet, if it's the same 99% Oxygen-Free Copper, you will not hear a lick of difference between the two.
post #27 of 58 Old 05-28-2020, 12:50 PM
alan0354's Avatar
Quoted: 2271 Post(s)
Liked: 609
No different from any other 12 gauge wires that are a lot cheaper. Copper and silver coated copper don't mean a thing. You want to really make a different......AND if your amp can be stable to drive high capacitance cable, try Kimber Kable type of knitted multiwire cables. There are other brands, the important thing is multiwire knitted cables. Kimber is NOT the only one. Type of metal is NOT important, just marketing hype.
Own designed power amps, own designed preamps, JM LAB Focal Alto Utopia and Spectral 913.1 speakers, Rythmik F12SE sub.
Not hooked up: Nakamichi Stasis PA-7 power amp, Velodyne VA1210 sub, Kef Reference Series center, Kef Bookshelf speaker, Monitor Audio bookshelf speaker, Infinity rear speakers. Acurus 3X200W amp.
alan0354 is offline
post #28 of 58 Old 05-28-2020, 01:03 PM
m. zillch's Avatar
Liked: 4962
The job of a speaker wire is to make a difference? In my hobby, high fidelity, the job of a speaker wire is to faithfully/accurately transmit the signal perfectly without any discernible alteration or difference, aka "transparently". If the sound is audibly different the wire is low fidelity.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
post #29 of 58 Old 05-28-2020, 01:32 PM
DanPackMan's Avatar
Quoted: 543 Post(s)
Liked: 1453
Knitting is for hats and sweaters. Multi strand wire from monoprice is the smart choice for speakers. These cables provide the exact same amount of sound improvement as the most expensive cable out there. No manufacturer has ever demonstrated better performance when it comes to sound quality or sound improvement.
m. zillch, jt7272 and Ryan Statz like this.
post #30 of 58 Old 05-28-2020, 01:42 PM
twitch54's Avatar
Quoted: 35 Post(s)
Liked: 34
wait a minute boys both of you are 'liking' each other posts yet when I read them you're not in agreement .......... 'Z' states that speaker wire is to transmit the signal perfectly without alteration yet PacMan you clearly talk of 'sound improvement', sounds like an alteration to me !!
LOL, just pokin' a bit of fun on a rainy afternoon !
twitch54 is offline
Closed Thread 2-Channel Audio
