Best turnable under 500 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By teachsac
  • 2 Post By twitch54
post #1 of 27 Old 05-30-2020, 09:37 AM - Thread Starter
Quoted: 35 Post(s)
Liked: 0
hi everyone!
I'm planning to buy a turntable, my budget is 500 usd, any recommendations?
I've been doing my research and found that the Fluance RT85 it's a great option. The thing about this turntable is that it doesn't have an integrated preamp, only a phone connection.
I have a marantz SR5013 that in the back has an integrated special phono connection. Having this, do I need a turntable with integrated preamp or its not necessary?
Thanks !!
[email protected] is offline
post #2 of 27 Old 05-30-2020, 09:53 AM
otlbum's Avatar
Quoted: 51 Post(s)
Originally Posted by [email protected] View Post
hi everyone!
Thanks !!
I think you meant to say that the turntable doesn't have a phono preamp, not integrated. The onboard phono preamp found in turntables would be good if you had a receiver that didn't have a phono input. Since your receiver has a phono input, just connect the table to it with the included RCA and ground cables. The fact that it comes with an Ortofon 2M Blue is not bad. Good sounding cart. It will take a good 50 hours to break in.
If I were looking to get into turntables again, this might be a good one to try. It gets very good reviews.
I prefer older, vintage fully automatic turntables myself like the Denon DP-47F, Pioneer Pl-707 or the JVC QL-Yxxx models. I owned at one time the Pl-707 and the QL-Y55F. The QL-Y55F was a great sounding table.
McIntosh MX121 McIntosh MC7205 Arial Acoustics Model 6 / Model 5 OPPO BDP-103
otlbum is online now
post #3 of 27 Old 05-31-2020, 01:35 PM
Kothoga's Avatar
Quoted: 189 Post(s)
Liked: 257
I'd recommend the Rega Planar 1, Planar 2 if you can swing the few extra bucks.
Theater: JVC RS540U, 2.35:1 142" screen, Onkyo RZ1100, Panasonic UB820, Outlaw Audio M2200 Monoblock x3, Klipsch RF7II, RC64II, RS62II, 5800CII x4 Atmos, PSA V3611 Subwoofer x2.
2 Channel: Parasound P6, Parasound A23+, Rega Planar 6 with Ortofon 2M Bronze, Klispch La Scala II.
Kothoga is offline
post #4 of 27 Old 06-01-2020, 02:35 AM
glangford's Avatar
Quoted: 874 Post(s)
Liked: 777
hi everyone!
Thanks !!
You might get more responses and recommendations in the 2 channel forum. Most people post there for turntable info.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #5 of 27 Old 06-01-2020, 03:51 AM - Thread Starter
Quoted: 35 Post(s)
Liked: 0
Thanks !!
post #6 of 27 Old 06-01-2020, 04:36 AM
Liked: 3
Hi If your amp has a phono input then use it as its prib better than a built in one on a TT.
Also check if this TT preamp can be turned off, if not you will have to connect it to the CD/Aux/Tape in inputs on your amp.
Have you considered looking at vintage 2nd hand turntables, you will get a lot more bang for your buck especially with $500 budget
All the best
Stewart
Sent from my SM-G950F using Tapatalk
Stewart Godfrey is offline
post #7 of 27 Old 06-01-2020, 04:37 AM
Super Moderator
teachsac's Avatar
Quoted: 1444 Post(s)
Liked: 2525
Duplicate threads merged.
Stewart Godfrey likes this.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #8 of 27 Old 06-01-2020, 02:10 PM
twitch54's Avatar
Quoted: 38 Post(s)
Liked: 34
All the best
Stewart
what needs to be checked is while having a phono input does not guarantee there is in fact a gain stage associated with it. it may be in fact just an 'input'.
In which case either a TT with one built in or adding one to the mix
twitch54 is offline
post #9 of 27 Old 06-01-2020, 04:55 PM - Thread Starter
Quoted: 35 Post(s)
Liked: 0
Hi!
Thanks for your reply.
How can I check if there is a gain stage associated with my marantz SR5013?
*Analog
Input sen*si*tiv*ity:
200 mV
Fre*quency re*sponse:
10 Hz – 100 kHz — +1, –3 dB (Di*rect mode)
S/N:
100 dB (IHF–A weighted, Di*rect mode)
*Phono equalizer
2.5 mV
RIAA de*vi*a*tion:
±1 dB (20 Hz to 20 kHz)
S/N:
74 dB (IHF-A)
Dis*tor*tion fac*tor:
0.03 % (1 kHz, 3 V)
post #10 of 27 Old 06-01-2020, 11:13 PM
Liked: 3
Do not understand this comment.
If the OPs amp has a Phono Input, there will be a gain stage in built in the amp. If the TT hes looking to buy already has a phono preamp he needs to plug into a line level input, unless it can be bypassed.
post #11 of 27 Old 06-02-2020, 05:44 AM
twitch54's Avatar
Quoted: 38 Post(s)
Liked: 34
no, not true, just because a given AVR has a 'phono input' does it mean there is gain associated with it. it can merely be an input 'so marked', I had a Pioneer Elite AVR a few years back that was configured just like that. That's why I said he needs to check his AVR to see
twitch54 is offline
post #12 of 27 Old 06-02-2020, 05:53 AM
twitch54's Avatar
Quoted: 38 Post(s)
Liked: 34
Hi!
Ok, I took the time to look up the manual for your AVR, page 60 of it states that your input does in fact have gain but only for use with a moving magnet / iron cartridge. If you choose to use a moving coil cartridge (lower output voltage) then step up device will be needed.
I'm assuming given the $$ range that your looking for in your analog start up that you will be using the higher output moving magnet type of cartridge. In which case you should be good to go.
twitch54 is offline
post #13 of 27 Old 06-02-2020, 09:07 AM
CurtP's Avatar
Quoted: 32 Post(s)
Liked: 25
I just went through this and ended up with a Fluance RT85. I like it, but I'm not sure I love it. Undecided if I'm going to keep or send back. It's not bad, but there are compromises on a $500 turntable that I'm not sure I can live with.
CurtP is offline
post #14 of 27 Old 06-02-2020, 09:30 AM - Thread Starter
Quoted: 35 Post(s)
Liked: 0
Hi curtp
What do you mean by this? "There are commitments on a $ 500 turntable that I'm not sure I can live with."
Have you handled any other option?
Thanks!!
post #15 of 27 Old 06-02-2020, 09:30 AM - Thread Starter
Quoted: 35 Post(s)
Liked: 0
Thanks a lot twitch54!!!
post #16 of 27 Old 06-02-2020, 09:45 AM
twitch54's Avatar
Quoted: 38 Post(s)
Liked: 34
Hi curtp
Thanks!!
Couple more thoughts / questions on your TT quest ..........
do have a collection of LP's to start with ?
do you have cleaning / maintenance supplies ?
Knowledge regarding table / tonearm / cartridge setup and integration ?
twitch54 is offline
post #17 of 27 Old 06-02-2020, 10:08 AM - Thread Starter
Quoted: 35 Post(s)
Liked: 0
Twitch
Gather more thoughts / questions about your TT search ..........
Do you have an LP collection to start with?
No, at that time I don't have any LP, but I will start soon.
Do you have cleaning / maintenance supplies?
No, what do you recommend?
Knowledge of table / arm / cartridge configuration and integration?
I've watched many videos and will follow the manufacturer's recommendations.
As you have seen, I am entering to this vinyl world, so any recommendation will be excellent for me.
post #18 of 27 Old 06-02-2020, 10:12 AM
Ratman's Avatar
Quoted: 2923 Post(s)
Liked: 2995
Hi curtp
Thanks!!
He stated "compromises", not "commitments". Hopefully he will clarify.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #19 of 27 Old 06-02-2020, 12:01 PM
twitch54's Avatar
Quoted: 38 Post(s)
Liked: 34
Twitch
Ok, so it's ground zero..........
You're doing this because it's popular I suspect not because you're gaining a sonic advantage over digital, because you won't be. So if you plan shopping thrift / Goodwill for record bargains and just having fun, Ok that's a whole different matter.
I've been spinning LP's for well over 50 years and while my collection is modest(1500 LP's + or -) if I were start from scratch today would I ...... probably not. The commitment to analog requires not only a sizable amount of $$ but space, time and a whole lot of patience.
I'm not trying to rain on your parade, just pointing a few things that this old man has learned along the way
twitch54 is offline
post #20 of 27 Old 06-04-2020, 06:24 PM
citizen arcane's Avatar
Quoted: 577 Post(s)
Liked: 23675
I have the same experience as t54 - and the same advice. Will add......forget shopping thrift/Goodwill.... that's a waste of time; hard to find VG+ quality albums of your (or any) genre as LPs have become a commodity on the used market.
¿lɐɯɹou ǝq ʎɥʍ
citizen arcane is offline
post #21 of 27 Old 06-05-2020, 09:22 AM
mrjinglesusa's Avatar
Quoted: 14 Post(s)
I appreciate these comments because I've been considering entering the TT world and have been researching a lot by reading threads in this forum.
Based on your advice, I think I'll pass as I'd be starting from scratch. I'll stick to streaming my lossless digital music.
mrjinglesusa is offline
post #22 of 27 Old 06-05-2020, 02:01 PM
Quoted: 570 Post(s)
Liked: 378
Good decision. Don’t expect a quality vinyl experience at a low price point. First there are some excellent moving magnet cartridges but not at a low price point. You’d be better off with an inexpensive phono preamp and lower end moving coil cartridge. Expect to spend at least $1000.00 for the package. My Dynavector 10x5 cartridge now retails for about $750.00 and sounds really good. There are good less expensive MC cartridges as well.
It’s worth it to get a decent vinyl setup. The sound can be more organic and rich than digital in my opinion.
Most larger metro areas have used record stores which are a great resource.
You don’t have to spend a lot on cleaning accessories but a good record cleaner like a Record Doctor for $200.00 is valuable if you buy used. Otherwise a $20.00 carbon fiber brush can do a decent job. You need this no matter what.
Jolida Fusion Preamp, Jolida JD1000P Amp, VPI Scout turntable with Dynavector 10X5 cartridge, Paradigm Studio 100 v.5 speakers, Sonica DAC streaming lossless files. Furman Elite 15 Power Conditioner.
MSchott is online now
post #23 of 27 Old 06-05-2020, 02:18 PM - Thread Starter
Quoted: 35 Post(s)
Liked: 0
Hi Twitch54!
Yes, I am doing this because I always wanted to have my own vinyl system. When I was a child I used to play records with my grandfather and I have the best memories of that, so now that I have a good audio system and I can, I thought it would be a great idea to enter this world.
My apologies for the other thread about the different turntable options that I am managing, the idea was to put it in this thread so I can have opinions about it but I made a mistake, I am trying to delete it but I'm not finding the way to do it.
Thank you very much for your comments, I really appreciate it.
I take advantage of this reply to put to put the another thread here that I will delete as soon as posible.
"Which of these three is a better option:
1- Fluance RT85
2-Rega Planar 2
3- Project Debut Carbon Espirit SB.
The Fluance RT85 is the only one with Ortofon 2M Blue Cartridge, but maybe that's not the only thing that's matters"
post #24 of 27 Old 06-05-2020, 05:51 PM
CurtP's Avatar
Quoted: 32 Post(s)
Liked: 25
Hi curtp
What do you mean by this? "There are compromises on a $500 turntable that I'm not sure I can live with."
Thanks!!
I've posted several times and end up coming back and deleting it. There's a lot of people who feel strongly about this TT and I don't want to crap all over it. The main issue is mine had horrible feedback that was getting worse the more it played. I tried different interconnects, ground wires and even moved it to a different system and the problem persisted. It was most notable with the dust cover up, but it was still there even with it removed. I've opened a ticket with Fluance, and received an automated email, but no real support. I haven't heard back on my request for return either. Not impressed with their customer support so far.
I have other issues with it too, but I'll refrain.
CurtP is offline
post #25 of 27 Old 06-06-2020, 06:11 AM
twitch54's Avatar
Quoted: 38 Post(s)
Liked: 34
Hi Twitch54!
1- Fluance RT85
2-Rega Planar 2
Given Curt's recent experience and from what I know of the three you have listed I'd go with the Rega. With that being said I'd take a deep breath, remain patient and save some more $$ towards the Rega 3, IMO, that's where it really begins in the Rega lineup
twitch54 is offline
post #26 of 27 Old 06-06-2020, 11:10 AM
Quoted: 194 Post(s)
Liked: 127
When I went through my journey, everything I read pointed me in the same direction as well. And with the overwhelming acclaim of the unit compared to any of it’s competitors, I eventually bit the bullet and got it.
That said, what would you say is what makes the Rega 3 special? Is it the cartridge, tone arm, or the overall package etc that makes it better than the others?
thebrieze01 is online now
post #27 of 27 Old 06-06-2020, 11:37 AM
twitch54's Avatar
Quoted: 38 Post(s)
Liked: 34
The tonearm of the Rega P3 (RB330) just might be one of if not the best tonearm on a sub 1k table. I'm not knocking the Op's other choices just making a point that to me makes sense to save a few extra $$ and come in at a much better starting point.
CurtP and thebrieze01 like this.
twitch54 is offline
Reply 2-Channel Audio
