marantz NR1200 users? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-10-2020, 04:29 PM - Thread Starter
gentlejax's Avatar
Quoted: 51 Post(s)
I may have the model wrong...looking for users of the stereo receiver with pre-outs from marantz. is it any good? or should I stick with my high dollar older Cary Audio pre ? im going to use external amps no matter what.
gentlejax is offline
post #2 of 5 Old 06-10-2020, 05:06 PM
Hoary's Avatar
I have it but I do not use pre-outs. I like it but I do not have much experience to compare it with anything.
I was looking for something inexpensive, stereo but at the same time being able to connect all stuff around TV: Xbox One X, Nintendo Switch (both for my son), NVIDIA Shield, and be able to listen to the music. I also needed a relatively slim device to fit into the cabinet. At the end of the day this was the only one.
Hoary is offline
post #3 of 5 Old 06-11-2020, 06:44 AM
mlknez's Avatar
Quoted: 661 Post(s)
Liked: 221
it does a decent job. what are your sources and speakers?
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is online now
post #4 of 5 Old 06-11-2020, 12:20 PM
qirex's Avatar
Quoted: 261 Post(s)
Liked: 228
From other threads I've seen discussing it the only major caveat seems to be that the pre-outs are always full frequency range, so even if you have a subwoofer it will not cross them over. If you're using the pre-outs you can easily use a MiniDSP for that anyway.
qirex is offline
post #5 of 5 Old 06-25-2020, 11:46 AM - Thread Starter
gentlejax's Avatar
Quoted: 51 Post(s)
I ordered a Parasound P6 instead. already had multiple amps to run.
Reply 2-Channel Audio
