DAC replacement - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 2 Post By Mike in NC
  • 1 Post By JimMeader
  • 1 Post By exander
  • 1 Post By zielin
  • 1 Post By exander
post #1 of 12 Old 06-11-2020, 10:50 AM - Thread Starter
exander's Avatar
Quoted: 33 Post(s)
DAC replacement
I currently have my computer hooked up to a MicroMega MyDac then to a Jolida hybrid tube amp. I'd like to replace the MyDac with a new DAC. Any suggestions on something that would be an "upgrade" to the MyDac? I tend to like a warmer sound....
exander is offline
post #2 of 12 Old 06-12-2020, 07:35 AM
crn3371's Avatar
Quoted: 321 Post(s)
Liked: 278
Budget?
crn3371 is offline
post #3 of 12 Old 06-12-2020, 07:46 AM - Thread Starter
exander's Avatar
Quoted: 33 Post(s)
Originally Posted by crn3371 View Post
Budget?
Well, that's a moving target. :-) I'd say $300 right now. I'm also deciding whether I should just replace the amp or replace both......
exander is offline
post #4 of 12 Old 06-13-2020, 10:47 AM
Mike in NC's Avatar
Quoted: 105 Post(s)
Liked: 95
Try the Schiit Modius ($199)
I think I'd probably give the new Schiit Modius a try. Their stuff typically pleases owners, it's not said to be hard and brittle (as reviews say about the MyDAC), and the Modius measures well, too. If you don't like it, Schiit offers a 15-day money-back trial (I don't know the terms & conditions).
The only caution is that the USB input doesn't work with versions of Windows lower than 10, because they didn't have Class 2 USB drivers, and Schiit doesn't supply one. Linux, Mac, or W10, you're all set.
Have fun!
exander and zielin like this.
Mike (Portland, Oregon)
Spoiler!
Mike in NC is offline
post #5 of 12 Old 06-23-2020, 08:02 AM
Quoted: 46 Post(s)
Liked: 31
another option would be the SMSL SU8 about $250 RCA and XLR out with volume control and remote very convenient and sound great
Mike in NC likes this.
Jim Meader
Audirvana on Win 10 PC, USB out to SMSL SU8 DAC, XLR out to Crown XLI 1500 amp, full range signal sent via RCA to 12 inch Klipsch sub, Audirvana accesses FLAC Music files on USB Drive
JimMeader is offline
post #6 of 12 Old 06-23-2020, 10:51 AM
jrampoldi's Avatar
Liked: 5
here are 2 more options:
Geshelli ENOG2 Pro $180
JDS Labs EL DAC II $300 (new)
or $250 (b-stock)
I own the Schiit Modius have Windows 10 & have been unable to use 1 USB cable (audio+power) so I use optical instead. The Geshelli was unavailable when I purchased the Schiit otherwise I may have purchased that instead.
jrampoldi is offline
post #7 of 12 Old 06-23-2020, 11:51 AM - Thread Starter
exander's Avatar
Quoted: 33 Post(s)
Ended up getting a Topping D70. Thanks for all the suggestions.
jrampoldi likes this.
exander is offline
post #8 of 12 Old 07-01-2020, 04:59 PM
zielin's Avatar
Quoted: 374 Post(s)
Liked: 255
I'm always confused by the love of Topping. They are so meh... maybe measuring well but sound like a cellphone dac. (well.. not that bad, but close.)
at the price point the modius is pretty amazing. But if you are happy with the D70, then that is all that matters. Don't listen to the internet.
TV: LG OLED77C9 | Receiver Denon X8500H | AMP: PrimaLuna EVO 400 | Speakers: ELAC Vela FS407.2, CC401.2, BS403.2, Carina BS243.4, 2x SVS SB-3000
HTPC: i9-10980XE @ 5.0ghz, DDR4 32gigs, Intel Optane 960gb x2, Nvidia 2080 ti (SLI)
Sources:Oppo UDP-203,Tivo Bolt+,Xbox One X,PlayStation 4 Pro,Switch,Bluesound node 2i
CalMan Enthusiast, SpectraCal C6-HDR, VideoForge Pro | Control: Logitech Harmony Elite
zielin is offline
post #9 of 12 Old 07-01-2020, 05:34 PM - Thread Starter
exander's Avatar
Quoted: 33 Post(s)
I ended up returning the D70. I got caught up in all of the measurements thinking that was most important and then later learned that measurements don't matter if I don't like the sound.
I just bought a used Ayre Codex on eBay. Should be here tomorrow.
exander is offline
post #10 of 12 Old 07-02-2020, 06:19 AM
zielin's Avatar
Quoted: 374 Post(s)
Liked: 255
hrmm.. don't know that one. Hopefully you like it.
just note, if you end of looking for something else, don't be blinded by the chip in it. It is the total package that matters. Power and isolation are very important.
I personally like multi-bit dacs (ladder dacs) but those are more costly. That said, because of all the extra engineering for ladder dacs it is likely that something wasn't cheaped out.
The suggestions for the Modius is still a good (cheap) choice even it is isn't a ladder dac.
A resource i'd suggest for helping you pick between dacs is www.superbestaudiofriends.org. They have a nice mix of measurements and how it sounds. (I dislike the cultish ASR)
EDIT:
if you are looking for an all in one (with headphone amp) (which you might not want as a the thing you'd change the most is the dac, but tech for amps isn't going to be changing much)
check out the schiit Lyr:
https://www.schiit.com/products/lyr-1
It can come with a dac multi or not. (the multibit is better)
You can play with tubes too. Even if you don't want to tube roll, it looks cool.. haha which is something.
zielin is offline
post #11 of 12 Old 07-02-2020, 10:05 AM
m. zillch's Avatar
Quoted: 6725 Post(s)
Liked: 4931
Since some cellphone DACs sound perfect to the ear, meaning the sound passing through them is completely indistinguishable from the direct signal, when tested under scientifically controlled conditions to preclude expectation bias, this sounds like a good brand to buy if you ask me. Perfect transparency is indeed exactly what I want in a DAC.
m. zillch is offline
post #12 of 12 Old 07-02-2020, 01:10 PM - Thread Starter
exander's Avatar
Quoted: 33 Post(s)
Just got the Codex. So far, pretty happy with it. Still very detailed but not as bright as the D70. Even sounds good in Roon without any adjustments. Aurdirvana sounds good as usual.
zielin likes this.
exander is offline
Reply 2-Channel Audio
