Cerwin-Vega VS-120 speaker parts. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-18-2020, 07:14 PM - Thread Starter
Liked: 0
Look for a set of factory grills
Megadeath is offline
post #2 of 5 Old 06-18-2020, 07:19 PM - Thread Starter
Liked: 0
Wanted: Cerwin-Vega Vega AT-10 parts.
I need a pair replacement woofers and, the grills I don’t mice if the woofers need reform inning.
post #3 of 5 Old 06-21-2020, 11:29 AM
bluewizard's Avatar
Quoted: 2412 Post(s)
Liked: 1592
First and most obvious is contact Cerwin-Vega.
If that doesn't work, check the used marked for low cost speakers that you can salvage. The used speakers don't have to be perfect, they just need the parts you require.
Once done, depending on the cost, just trash everything else.
Steve/bluewizard
bluewizard is offline
post #4 of 5 Old 06-21-2020, 12:09 PM
Ratman's Avatar
Quoted: 2869 Post(s)
Liked: 2914
https://www.google.com/search?client...ga+AT-10+parts
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #5 of 5 Old 06-23-2020, 09:02 PM
A9X-308's Avatar
Quoted: 2035 Post(s)
Liked: 1750
If you need the woofer surrounds need refoaming there are lots of places that can do that and CVs should not be a problem to get parts. Orange County Speaker for example.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
Reply 2-Channel Audio
